Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
how many gallons is our gas tank?
Reply
Thread Tools
Old 05-30-2010, 02:50 PM   #1
KobeJ05
Marina, CA
1994 explorer 157k miles
Vehicle Specs
(Original Poster)
i was gasing up before work last night and i put 40 bucks in cash figureing it was gonna fill it up but it didnt and added another 16 bucks. added all together was 16 gallons and its not evenfilled up. so all together i spent 56 bucks and its 3.07 a gallon. does this sound right? im thinking i spent topo much and it's not even full. yes i filled from empty it started missing like i was running out of gas. (gas gauge doesnt work). thanks!
KobeJ05 is offline   Reply With Quote
Old 05-30-2010, 03:00 PM   #2
jaschlum
Kenmore , WA
jaschlum's Avatar
1992 Explorer XLT
Vehicle Specs
i have a 1st gen explorer and they have a 19.3 gallon gas tank.
__________________
"jake"
my 92 xlt
jaschlum is offline   Reply With Quote
Old 05-30-2010, 03:03 PM   #3
jaschlum
Kenmore , WA
jaschlum's Avatar
1992 Explorer XLT
Vehicle Specs
so if you were dead empty it would cost ya 59.251 bucks to fill it up.
__________________
"jake"
my 92 xlt
Old 05-30-2010, 03:03 PM   #4
Willard
Elite tree-smasher
Bloomington, Indiana
Willard's Avatar
04 Ranger Edge
Vehicle Specs
That sounds right, I've gotten 18 gallons in mine before and I could tell it was running out. When gas was more expensive ($3.50+), I regularly put $65 or more into it for a normal fill up, and that was usually 16-17 gallons.
__________________
Jesse
'94 Eddie Bauer DD/Beater
"Old Faithful" RIP
'04 Ranger Edge DD "Black Knight"
You want to see my face?
Willard is offline   Reply With Quote
Old 05-30-2010, 04:02 PM   #5
KPSquared
Wetaskiwin, Alberta
'92 XLT
Vehicle Specs
Just hold the trigger until it clicks off... then you know your full... simple solution...
But ya, should hold around 19 gallons if it was right empty... probably at least a gallon or even more left in the bottom when the truck starts to sputter...
I would think with $56.00 in the tank, you would have been awfully close to full. That's 18.24 gallons... you must have been pretty empty...
It was a long, LONG time ago that $40 could fill an Ex from empty...
__________________
1992 XLT
| 5.5" Superlift | SOA | SJ Extended Brake Lines | Rancho RS 5000 | 35x12.50x15 Cooper STT | 15x8 AR767 | Dana 35 Nitro 4.88 |
| Ford 8.8 Yukon 4.88 | Aussie Lockers Front and Rear | Cherrybomb Vortex | 8" Pro-Comp 130's |
Still To Come: Custom Bumpers & Roof Rack, More Lights, Winch, OD GREEN
KPSquared is offline   Reply With Quote
Old 05-30-2010, 04:41 PM   #6
92exp4x4
Covington, Kentucky
92exp4x4's Avatar
92 XL 2-door and others
Vehicle Specs
When gas was about 3.75 around here, it cost me about $125.00 to fill my FS Bronco. 9 mpg and a 32 gallon fuel tank puts a hurtin on the ol' billfold.
__________________
My stable:
2 doors - '91 Eddie Bauer; '92 XL 5 speed; '92 Sport 2WD 5 speed
4 doors - '91 XLT; '93 XLT; '94 XLT, 6" lift, 33's; '94 Eddie Bauer 5 speed; '94 Limited
Others - '22 Model T, '48 8N tractor, '62 Fairlane 500, '93 F-Superduty 460, '97 F250 Powerstroke, '04 F550 service truck (company owned)
92exp4x4 is offline   Reply With Quote
Old 05-30-2010, 05:08 PM   #7
jaschlum
Kenmore , WA
jaschlum's Avatar
1992 Explorer XLT
Vehicle Specs
Quote:
jeez, thats a huge tank, and a crazy bill.
__________________
"jake"
my 92 xlt
Old 05-30-2010, 08:27 PM   #8
Blacksheep Josh
Slinky+Escalator=Fun
Statesboro, GA
Blacksheep Josh's Avatar
1993 Ford Explorer XLT
Vehicle Specs
Make sure you aren't pumping gas out of the top of the tank or somewhere around it. In my Explorer whenever I "fill up" (especially when it's cold, not so much when its warm) it'll click off, but by that point there's gas coming out of the top of the tank. That's why I haven't filled up in years, usually just run like 20-30 bucks at a time.
But if you aren't leaking gas, more than likely you just didn't fill it up, take a peak underneath the truck and look how large that damn tank is. It's a BEAST
__________________
"Thunder" Registry R.I.P. 2005-2012
2001 Ford Ranger (New!!)
"You can hear me when I'm coming" - Yung Joc
Blacksheep Josh is offline   Reply With Quote
Old 05-30-2010, 08:27 PM   #9
briwayjones
Sykesville, MD
briwayjones's Avatar
'00 XLS, '03 Sport
Vehicle Specs
The early first gens were 18.3, not sure if the '94s still are.
__________________
2000 XLS, 4DR, 4x4, OHV, Manual ; 2003 Sport, 2DR, 2WD, SOHC, Manual
Mobil 1 & Amsoil Synthetic Fluids, 2WD switch Brown wire mod, KKM air intake, overhead console, lighted sunvisors, custom 2nd HU install, '03 Ranger Fog lights, Hurst short-shifter, 75MM MAF, BBK 66MM Throttle Body
My 2000 Explorer
briwayjones is offline   Reply With Quote
Old 05-30-2010, 08:46 PM   #10
KobeJ05
Marina, CA
Vehicle Specs
(Original Poster)
cool i never put more than 40 bucks in my explorer latley. except when i was living in wa when it was over 4 bucks a gallon i was putting close to 70 bucks in. thanks for the replies.
Old 05-30-2010, 08:47 PM   #11
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Also, keep in mind different pumps pump differently.
For example, in California I can't fill the front tank on the van. It will shut off about 2 gallons early and it just won't take any more. I've only tried 3 pumps in Ca though.
In Arizona, on the lower pressure pumps I can fit 17 gallons in my 16 gallon tank on the van. With the higher pressure ones its right at about 16 or a little less where it shuts off.
On the X, in Arizona I have fit almost 21 gallons in the tank more than once which means I was filling the air pocket and the fill hose. With the caster like it was on the X until recently, when I turned the wheel all the way to the left it would left the left side of the X which would allow me to put more fuel into it.
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is online now   Reply With Quote
Old 05-30-2010, 08:48 PM   #12
safn1949
Mankato, Minnesota
safn1949's Avatar
M60A1 my first offroader
Vehicle Specs
I have put just over 18 gals in my 94 a couple of times,I think 18.7 or so was the most.
__________________
1994 XLT,4.0,3.73 LS
149,000 miles.
Need a Panasonic Toughbook? I have them,email me for details.
safn1949 is offline   Reply With Quote
Old 05-31-2010, 10:23 AM   #13
mawrazen
Atlanta, Ga
94 Eddie Bauer
Vehicle Specs
The 1994 I have is rated at 19.4 gallon capacity.
I have been able to squeeze in over 20 gallons at a time. Ouch!
Best mileage on a tank was 433 miles.
__________________
Faith is the evidence of things hoped for, the substance of things not seen.
Ford count: 94 EB Ex (303K miles) , 94 Mustang Convertible,
"Don't touch the TRIM!" Freedom IS NOT Free!
Sometimes I'm here, but mostly I'm gone.
mawrazen is offline   Reply With Quote
Old 05-31-2010, 11:12 AM   #14
huntman58
Raisin city calif.
1993 xlt 4x4
Vehicle Specs
I also would have to agree as with my 93 that’s what it was to fill it last time I did that some thing that almost never happens any more unless I am on a trip some place.
What I hate is how I get crappy MPG from this stupid Calif. gas compared to say Oregon gas. Last trip it made a defiance of almost 2 MPG be it the 93 EX or the 2001 Taurus! GRRRRRR. I also know the Reno NV gas is just as bad as Calif gas but get out side that area and then ya get the good stuff!
huntman58 is offline   Reply With Quote
Old 06-01-2010, 02:29 AM   #15
Delta_1980
livingsville, California
92' exploder
Vehicle Specs
i have to run premium or the ol' girl starts a knock-in'
Delta_1980 is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
