#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer Audio & Navigation
Notices
Explorer Audio & Navigation Audio and navigation systems. CD, DVD, MP3, GPS, Video, Mobile Computer, Speakers, Amplifiers.
98 Explorer XLT radio installation issues.
Reply
Thread Tools
Old 05-31-2010, 12:38 AM   #1
NHarris
Gillette, Wyoming
04 Wrangler, 08 Ranger
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
I'm currently installing a new radio in my 1998 Ford Explorer XLT, and i've run in to the issue of none of the wiring connectors i've used will fit. What will happen is I'll get power, signal, etc, but no sound. I know for sure the pins inside the connectors do not line up. My explorer was manufactured in May 1998 and on a long shot I looked at the 1999 connectors, but they will not fit. Also, I have looked at the 1997 explorer connectors and those seem to look like they will fit. I am going to a Car Audio shop on Monday, but any suggestions on what to get, or do?
NHarris is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-31-2010, 01:07 AM   #2
mic98xlt
West Haven, Ct.
mic98xlt's Avatar
98 XLT
Vehicle Specs
Quoted: 14 Post(s)
I'm pretty sure you have the earlier 97 type radio in your 98 (Ford mixed radio's both in 98) which has a external amplifier in the rear by the right rear wheel well. Do a forum search and look for the thread posted by "Joe Dirt" that explains the best how to install a aftermarket radio in the earlier 95-97 Explorer's. You can do it if you follow his directions which are the best I seen. Others here have explained it but his is clear and most simple. Good luck.
Edit link: http://www.explorerforum.com/forums/...d.php?t=274434
mic98xlt is offline   Reply With Quote
Old 05-31-2010, 10:41 AM   #3
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Welcome to this forum! I've moved your thread into the audio & navigation section. Double check the wiring color codes to make sure that it's wired correctly. Check WWW.The12Volt.Com.
BrooklynBay is online now   Reply With Quote
Old 05-31-2010, 01:29 PM   #4
617ricky
Boston
97 XLT
Vehicle Specs
Quoted: 0 Post(s)
If you do have the 97 setup (with the rectangle and square harness plugs), all you gotta do is connect the 2 wires for the stock amp.. The amp ground is the 9th wire on the square plug which you can just ground with the main ground connec.. Then there's an amp turn-on wire on the rectangle plug that you can connect to either the power antenna wire or remote turn-on wire coming from your new stereo..
617ricky is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
