Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Tow Rig Forum
Notices
Tow Rig Forum Towing, hauling, boats, campers, trailers etc... Trailer hitches, weight distribution, hitch ball, safety chains, tow bar and brake controllers. Discuss it all here!
Flat tow with drive shaft in.
Reply
Thread Tools
Old 05-31-2010, 11:16 AM   #1
austin bronco11
Austin Texas
1985 eb bronco11
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I got a 1985 Bronco 11 that I want to use at the deer lease about 200 miles away from my house .it has the 2.8 v6 and auto matic trans .do not want to pull the drive shaft every time .Can I flat tow with every thing in neutral .
austin bronco11 is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-31-2010, 04:35 PM   #2
dogfriend
Human-Animal Hybrid
Carmichael, CA
dogfriend's Avatar
'97 Sport 4x4
Vehicle Specs
Quoted: 5 Post(s)
Do you have 4wd or 2wd? Most Bronco II's are 4wd, but they did make a 2wd version.
If you have 4wd, I believe that you can shift the transfer case to N and flat tow with no other issues. If you still have the owners manual, it should tell you if you can.
If you have 2wd, you are going to need to disconnect the driveshaft. Remco makes a device that you can install so that you can disconnect by remote cable. If you install the remote cable, you just disconnect by moving a lever from inside the truck.
http://www.remcotowing.com/node/7
dogfriend is offline   Reply With Quote
Old 05-31-2010, 06:59 PM   #3
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 427 Post(s)
Welcome to this forum! I've moved your thread into the towing section.
BrooklynBay is offline   Reply With Quote
Old 06-06-2010, 01:29 AM   #4
GreenMando
Columbia, CA
'08 Sport Trac XLT 4x4 V8
Vehicle Specs
Quoted: 1 Post(s)
I have seen trucks with locking hubs on the rear for towing.
GreenMando is offline   Reply With Quote
Old 06-06-2010, 02:50 AM   #5
rhauf
Ca
'93 and '91 explorer
Vehicle Specs
Quoted: 0 Post(s)
the trans should never be spinning without the engine running. if things are correct, it should be in PARK when towing. the transfer case should be in neutral IF capable.. keep in mind that some transfer cases will not self-oil with only the rear output shaft turning (they require trans-side rotation to oil. although some will oil with front-shaft rotation too) of course, if it's an electronic t-case, you're screwed.
rhauf is offline   Reply With Quote
Old 06-06-2010, 07:30 AM   #6
dogfriend
Human-Animal Hybrid
Carmichael, CA
dogfriend's Avatar
'97 Sport 4x4
Vehicle Specs
Quoted: 5 Post(s)
Quote:
Actually, the Gen 2 Control Trac can be converted to have a selectable N for towing although it isn't equipped that way from the factory. I'm debating with myself whether to pay the money to have my Sport converted (the dealer has to reflash the GEM, so it isn't a DIY type of thing), or to sell it and get something that will be lighter and easier to tow.
Old 06-22-2010, 07:16 PM   #7
gyoungbmw
Chambersburg, PA
2008 Sport Trac Ltd
Vehicle Specs
Quoted: 0 Post(s)
Towing behind your RV
The Ford part is all of $27-, which electronically makes sure that the transfer case is in neutral, to allow you to tow your Explorer behind your RV-----but only the 4X4 version.
gyoungbmw is offline   Reply With Quote
Old 07-02-2010, 11:54 AM   #8
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
Vehicle Specs
Quoted: 10 Post(s)
Keep in mind we're talking about a BII, not a late-model Explorer... That makes a difference.
IIRC, there was a neutral tow kit available back in the day for the BII, but the odds of finding one today (if it ever existed) are somewhere between 'not good' and 'no way'. If you have the automatic trans with the electronic shift, you will need the neutral tow kit (or disconnect the driveshaft). There is no other way short of a trailer.
Now, if you have either a manual trans or a manual transfer case (which were both available in a BII), you can place either of them in neutral and flat-tow it without an issue. The t-case is lubed by the rear shaft, and the manual transmission is splash-lubed and will be fine.
Good luck!
__________________
-98 Explorer Sport, 4.0 SOHC, K&N drop-in, LEMON in progress!
-'00 F-150, mucho mods
"We need to allow Darwinism take it's course and let the idiots weed themselves out of existance." ~ Rick Horwitz
We must believe in free will we have no choice.
~ Isaac Bashevis Singer
I'm not smart, just a resourceful idiot. ~ Me
gijoecam is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
