Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
99 Ford Explorer with no reverse gear.
Reply
Thread Tools
Old 06-02-2010, 04:34 PM   #1
joe.o
rochester ny
99 ford explorer xpl
Vehicle Specs
(Original Poster)
any one can help me i have to install a transmission on my 99 ford it wont go back words but it will drive for words.help please
joe.o is offline   Reply With Quote
Old 06-02-2010, 08:55 PM   #2
Joe Dirt
Living in Greenland
Holland, MI
Joe Dirt's Avatar
'00 V8 XLT
Vehicle Specs
joe- what sort of help do you need? Do you have the transmission already, or are you looking for one?
__________________
Quote:
Originally Posted by FIND View Post
Also, every time you use an apostrophe for a plural, Jesus kills a kitten.
My registry
Joe Dirt is offline   Reply With Quote
Old 06-02-2010, 09:25 PM   #3
joe.o
rochester ny
Vehicle Specs
(Original Poster)
99 for explorer
i dont know how to take a trany out and no i dont have a trany yet what is ur price and can u give some detail on how to take it out
Old 06-02-2010, 10:41 PM   #4
Joe Dirt
Living in Greenland
Holland, MI
Joe Dirt's Avatar
'00 V8 XLT
Vehicle Specs
Well, in all honesty, if you don't have any idea what you're doing down there, I'd take it to a shop. I would find a small independant shop that will install a trans that you bring to them- save the markup by not letting them buy it for you... You can search through www.car-part.com to find a transmission (used) to replace yours with. But you'll have to do some searching on the forum for directions to do a swap by yourself, it has been documented a few times.
__________________
My registry
Old 06-02-2010, 11:51 PM   #5
joe.o
rochester ny
Vehicle Specs
(Original Poster)
99 for explorer
thanks for the help but i do have to say i have the money to by the trany but dont have the money to take it to a shop i would have to do it my self.could u give me advice and may be walk me threw it.
Old 06-03-2010, 08:37 AM   #6
Joe Dirt
Living in Greenland
Holland, MI
Joe Dirt's Avatar
'00 V8 XLT
Vehicle Specs
Here is a writeup...
http://www.explorerforum.com/forums/...d.php?t=126647
__________________
My registry
Old 06-03-2010, 05:08 PM   #7
joe.o
rochester ny
Vehicle Specs
(Original Poster)
99 for explorer
do u think it is thr reverse band on my trany my gord will drive for word but when i go to put it in reverse it wont go back words it must be the band.what could be wrong with it.
Old 06-03-2010, 09:44 PM   #8
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Welcome to this forum! I've renamed your thread, and moved it into the transmission section. Do you have manual first gear? Is your vehicle is 2WD or a 4WD? Did you check the fluid level?
BrooklynBay is offline   Reply With Quote
Old 06-03-2010, 09:58 PM   #9
joe.o
rochester ny
Vehicle Specs
(Original Poster)
99 for explorer
its 4 wheel drive and yes i check my fluid and it dont need no more fluid.and no i dont have manual first gear.
Old 06-03-2010, 10:23 PM   #10
BrooklynBay
Brooklyn, NY
Vehicle Specs
Check the low/reverse servo for a chip on the tip, and the O rings for signs of wear.
Old 06-03-2010, 11:00 PM   #11
joe.o
rochester ny
Vehicle Specs
(Original Poster)
99 for explorer
where is the low and reverse servo and the o ring and what is a servo i dont no much about trany.
Old 06-03-2010, 11:14 PM   #12
BrooklynBay
Brooklyn, NY
Vehicle Specs
I suggest that you read the sticky thread in the transmission section called the 5R55E rebuild diary. The low/reverse servo is a piston that engages the low/reverse band. The O rings are around it to make a seal.
Old 06-03-2010, 11:39 PM   #13
joe.o
rochester ny
Vehicle Specs
(Original Poster)
ok how will i konw if thats what causing my truck not to go in reverse. dose my truck have a pressure sensor.
Old 06-03-2010, 11:43 PM   #14
BrooklynBay
Brooklyn, NY
Vehicle Specs
Remove the pan, and take the square cover off. It has 4 bolts holding it on. The servo is inside the bore. Test the band with a long phillips screwdriver.
Old 06-04-2010, 02:06 AM   #15
joe.o
rochester ny
Vehicle Specs
(Original Poster)
ok. now if i buy the tranie off car parts ,com will i have to send my old one befor i get my use one i search around but could it finde anything on it.
Old 06-04-2010, 08:38 AM   #16
Joe Dirt
Living in Greenland
Holland, MI
Joe Dirt's Avatar
'00 V8 XLT
Vehicle Specs
car-part.com is really just a search engine which shows a bunch of different junkyards and parts resellers that have the parts you're looking for. It will depend on the place you buy a transmission from as to if they will want your old transmission or not. When you call them, you'll have to ask them if they require it. Also, most of the places on there will ship also, if that is needed...
__________________
My registry
Old 06-04-2010, 11:38 PM   #17
joe.o
rochester ny
Vehicle Specs
(Original Poster)
hey do u know of anyone that is selling a cheap tranie for my 99 ford xpl or do think i can find one for about 100.00 to 200.00 with out a core
Old 06-16-2010, 10:19 AM   #18
joe.o
rochester ny
Vehicle Specs
(Original Poster)
joe how hard do u think it would be if i put the reverse band in my self what would i have to take out on the traine to do i know i have to drop the traine.
Old 06-16-2010, 05:47 PM   #19
BrooklynBay
Brooklyn, NY
Vehicle Specs
The low/reverse band is deep inside, so you have to remove everything to get to it.
Old 06-17-2010, 03:20 AM   #20
joe.o
rochester ny
Vehicle Specs
(Original Poster)
where can i go on line to see how its done or is there any books i can read up on
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
