Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
Air conditioner rattling
Reply
Thread Tools
Old 06-04-2010, 01:09 AM   #1
Car-Dog
Fresno, California
1998 Ford Ranger 4X4
Vehicle Specs
(Original Poster)
when I turn my air conditioner on any setting it rattles like crazy. The odd part is that if I put the car in park it stops. It only does it if the car is in drive or reverse. At first I thought my tranny had just self destructed but When I turned the air off the noise stopped. Any Ideas?
Car-Dog is offline   Reply With Quote
Old 06-04-2010, 12:31 PM   #2
Car-Dog
Fresno, California
Vehicle Specs
(Original Poster)
Bump?
Old 07-16-2010, 01:39 AM   #3
Car-Dog
Fresno, California
Vehicle Specs
(Original Poster)
No one knows why my air con might be rattling itself to death?
I know nothing about air conditioners so I am kind of lost.
Old 07-16-2010, 01:43 AM   #4
rhauf
Ca
rhauf's Avatar
'93 and '91 explorer
Vehicle Specs
take a video and post it on youtube. i can probably figure out what it is if you do that. be sure to walk around the vehicle with the camera, so i can hear where the sound is coming from, what it sound slike in different places, etc. also slowly raise and lower the RPM and shift in and out of drive etc.
without the video ill take a couple guesses....
if the rattle is coming from the compressor, you may just need to add oil to the refrigerant (oil charge)
if the rattle is coming from somewhere other than the a/c system, it probably just puts a slight load on the engine, changing it's "vibrations" or whatever, exciting some resonance in a loose part, heat shield, or something and causing it to rattle.
__________________
Check out my Youtube page, many explorer and 4wheelin' videos
http://www.youtube.com/user/rhauf1
rhauf is offline   Reply With Quote
Old 07-22-2010, 07:12 PM   #5
mbagley
Semmes, ALA
2006 Ranger STX,3.0,2wd
Vehicle Specs
compressor rattle
check the four compressor mounting bolts, that attach it to the bracket. I had a 94 Ranger that did the same thing and drove me crazy until I bumped the compressor one day and saw it move!
mbagley is offline   Reply With Quote
Old 08-01-2010, 02:39 PM   #6
Car-Dog
Fresno, California
Vehicle Specs
(Original Poster)
Thanks. Ill check that stuff out and try to get a video of the problem.
Old 08-14-2010, 04:00 PM   #7
Car-Dog
Fresno, California
Vehicle Specs
(Original Poster)
Well I finally got a video of the rattle, and it almost sounds like it is coming from the Alternator. Anyone recognize this sound?
Old 08-15-2010, 06:00 PM   #8
Car-Dog
Fresno, California
Vehicle Specs
(Original Poster)
know one knows what the rattle might be?
Old 08-15-2010, 06:13 PM   #9
ratgp
port elgin,ont,canada
97 xlt
Vehicle Specs
yup, check you belt tensoiner and idler pulley
ratgp is offline   Reply With Quote
Old 08-16-2010, 02:26 PM   #10
Car-Dog
Fresno, California
Vehicle Specs
(Original Poster)
I checked the tensioner, and even swapped it out for another tensioner i had, but it is still rattling. It really sounds like the alternator is rattling. is that possible? has anyone ever heard of a rattle in an alternator?
Old 08-16-2010, 04:11 PM   #11
ratgp
97 xlt
Vehicle Specs
Smile
yes it is possible that the alternator has a bad bearing,i would pull the belt and check each individual pulley for roughness or movement
Old 08-18-2010, 01:58 PM   #12
Car-Dog
Fresno, California
Vehicle Specs
(Original Poster)
So I replaced the alternator (it had been making odd noises for awhile) hoping that it was what was rattling. I checked all of the pulleys their all fine( I replaced the idler and tensioner a few months ago) it still rattles just as obnoxiously as before. At this point I I am lost as to what it might be. and am getting ready to take it to my mechanic. Unless someone here as a brilliant idea in the next couple hours.
Old 08-18-2010, 03:06 PM   #13
Car-Dog
Fresno, California
Vehicle Specs
(Original Poster)
I watched a couple videos on youtube and I am now convinced that my timing chain is what is making the noise. what do you think?
Old 08-18-2010, 06:19 PM   #14
ratgp
97 xlt
Vehicle Specs
ok car dog,first step,does it make noise with the belt off running,that`s how i would test it in our shop,if it doesn`t rattle, then it won`t be timing chain,next step would be to find someone with a special stethescope to pin point the noise, if you can`t find one of them i can suggest a lenth of garden hose around 18 inches long,put on end to your ear and start placing it be the alt a/c ect... to see where it`s the loudest,i hope this helps you find the problem
gary
Old 08-18-2010, 11:09 PM   #15
Car-Dog
Fresno, California
Vehicle Specs
(Original Poster)
Thanks for your help, but I wound up taking to my family's trusted mechanic. I go back to college on monday and just ran out of time to do it myself. Once I start school again it has to running great or i am screwed because I have a daily 2 hour commute. I did try taking the belt off but the noise only occurs if you allow the engine to idle for 5-10 min and I didn't think my battery would like that very much. I also tried the old use a screw driver as a stethoscope and as far as i could it sounded like it was coming from the alternator I really appreciate your input and will post on here when I find out what the problem is. Oh and welcome to the board!
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
