Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
"Overdrive Off" light flashing
Reply
Thread Tools
Old 06-07-2010, 08:51 PM   #1
Green '01
South Carolina
1995 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Can anyone suggest where I need to start looking to solve this problem? The truck has been running fine and then the dash light that indicates the "Overdrive is off" started flashing constantly (no pauses). Pressing the O/D off button on the shifter stalk does nothing anymore.
It's a 1995 Explorer XLT 4.0L V-6.
Thanks in advance for any help.
Green '01 is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-08-2010, 02:46 PM   #2
Shawshank
Texas
1997 XLT 4.0 SOHC
Vehicle Specs
Quoted: 0 Post(s)
Is your check engine light on?
If not, do you know for sure the check engine light works?
Have you checked for codes yet using a code reader?
Shawshank is offline   Reply With Quote
Old 06-08-2010, 04:38 PM   #3
Green '01
South Carolina
1995 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Check engine light does work, and is not on. Cannot read trouble codes if the "Check Engine" light is not on - has not stored any trouble codes. I have a code reader, but it's for OBDII computers and would not help me with a '95, anyway.
Any ideas?
Old 06-08-2010, 05:44 PM   #4
chapsdeva
Richmond, Va
2008 XLT
Vehicle Specs
Quoted: 2 Post(s)
That O/D light flashing on and off is a signal that a problem with the transmission has been detected. You need to get that code read to determine what the issue is. It could be something simple or a major problem. I'm far from being a tranny expert, so I can't even begin to suggest what may be wrong. I would suggest finding a reputable transmission shop (Not always easy to find unfortunately....) to give you a diagnosis. You can then post what they say on this site and let the guys who know about tranny issues give you some advice. Just my $.02!!
chapsdeva is offline   Reply With Quote
Old 06-08-2010, 05:55 PM   #5
CypherSTL
St. Louis, MO
2000 Sport
Vehicle Specs
Quoted: 0 Post(s)
This is also happening on my '00 Sport. No check engine codes related to the transmission, or power train.
Right before mine comes on, I'm usually accelerating and going from 2nd into 3rd. Does a hard shift into third, and then when slowing down it does another hard shift from 3rd to 2nd, or 2nd to 1st, forgot which one exactly.
A few other threads on here have said to check out the range sensor, shift linkage on the drivers side of the transmission to make sure they're good and aligned. Also, the transmission is operating in "Limp Mode" while the O/D light is flashing.
CypherSTL is offline   Reply With Quote
Old 06-08-2010, 07:37 PM   #6
Green '01
South Carolina
1995 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Okay, thanks guys. Guess I'll be looking for a good shop. I'll let you know what I find, but it'll be a while before I do.
Old 06-11-2010, 02:52 PM   #7
greg883
96 XLT
Vehicle Specs
Quoted: 0 Post(s)
Been reading here for a couple of years and have saved some serious $$$ from the advice, so my turn to pay some back to the forum-
Had the same on my 96' AWD a few months back - "Clunk", WTF? Flashing O/D light. Park it and plug in the reader, code says bad transmission speed sensor.
Carefully drive to to the dealer. Replacing the speed sensor with a new unit didn't fix and the original sender tested out OK. It took three hours of diagnosis and it finally led to a bad main computer.
Nothing wrong with the tranny or its sensors, but it (the main computer) stopped processing the data from the transmission and triggered the flashing light/"limpback mode".
So it might not be a transmission problem.
greg883 is offline   Reply With Quote
Old 06-11-2010, 02:56 PM   #8
blueka
Elite Pickler
Saskatchewan, Canada
blueka's Avatar
97 UK XL & 99 Sport V8
Vehicle Specs
Quoted: 66 Post(s)
before driving off, take the OD off, so the light is on. put it in D and go... see if this stops the problem.
Or try driving off in 2, then shifting to D when you're going fast enough.
If you drive with OD off and the light stays off, then there's a problem with the OD solenoid I think...
Si
__________________
'97 Explorer XL 4.0 SOHC V6 "Betty"
'99 Explorer Sport Limited 5.0 OHV V8 "Pickle"
My "Betty" Registry My "Pickle" Registry
blueka is offline   Reply With Quote
Old 06-11-2010, 03:05 PM   #9
FloridaState
Tallahassee, FL
'97 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
This happened to mine.
Ended up being the torque converter. I also got the tranny rebuilt.
FloridaState is offline   Reply With Quote
Old 06-11-2010, 04:34 PM   #10
Green '01
South Carolina
1995 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks for the ideas. I have a small code reader, but it's for OBDII and won't work on a '95. Pressing the O/D off button on the shifter stalk does nothing anymore. The "O/D Off" dash light flashes all of the time - no matter what you do with the Overdrive button. Still haven't been able to take it to a repair shop to get the code read.
Old 06-11-2010, 05:51 PM   #11
CypherSTL
St. Louis, MO
2000 Sport
Vehicle Specs
Quoted: 0 Post(s)
Si
I tired that with my 2000 Explorer a while back, just turning off the Overdrive before leaving the house, got about 5 miles and it started flashing at me.
I haven't tried the starting off in 2nd, then shifting it into Drive.
Old 06-12-2010, 07:10 AM   #12
blueka
Elite Pickler
blueka's Avatar
Vehicle Specs
Quoted: 66 Post(s)
We had problems with the fil's tranny when he got it last November. Got the codes read (his is a 96) and it said that solenoid 1 was out and 1st gear range. So after swapping solenoids (we couldn't get the exhaust off to swap the tranny) we got it fixed. It was a long process of investigation, but it worked in the end.
Si
__________________
Old 06-12-2010, 10:35 AM   #13
Green '01
South Carolina
1995 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Finally got to drive it today. I can feel it shift from 1st to 2nd, from 2nd to 3rd, can feel the converter go into lock-up in 3rd (and see RPMs drop), can feel it go from 3rd to 4th (Overdrive) - but I can't feel the converter lock-up in Overdrive. It's still holding right at 2,000 RPMs at 60 MPH.
If the converter goes into lock-up in 3rd like it should, it's strange that it won't in overdrive (4th). Also, it feels like it may have developed a slight shudder at highway speed - maybe because the converter won't go into lock-up?
If the "Check Engine" light is not on, but "O/D Off" light is flashing, the computer should still have some trouble code stored, right?
Looking into getting codes read.
Oh yeah, forgot to mention that the overdrive button on the shifter does work. Pressing the button will turn off OD, and pressing it again will turn it back on.
Old 07-12-2010, 04:35 PM   #14
Dino61
Sydney NSW
97 XLT
Vehicle Specs
Quoted: 0 Post(s)
My newly purchased 97 was putting the flashing light on during highway running, and was shifting pretty 'sloppily".I cleared the light flashing once by clearing the codes with a cheap reader, but when it came back on again I did the band adjustment as per the details here, and this seems to have cured the light from coming on as well as tightening up the shifting.
Dino61 is offline   Reply With Quote
Old 07-12-2010, 08:28 PM   #15
imp
Missouri Ozarks
2004 XLT
Vehicle Specs
Quoted: 122 Post(s)
Later gen. transmissions have speed sensors on 3 locations, which allows pinpointing a problem more closely. For example, my '04 is flashing the "OD OFF" light because the computer does not "see" equal speeds between the engine and trans. input shaft: that can only mean the torque converter clutch (TCC) is NOT engaged when it should be.
You can check the TCC yourself, at speed, say 50 mph cruise on level road. Slight increase in gas pedal pressure should NOT cause eng. rpm increase, if TCC is engaged. Also, climbing mild hills, no downshift happening, the tachometer should read constant rpms if car speed remains constant. imp
imp is offline   Reply With Quote
Old 11-26-2010, 11:37 PM   #16
Green '01
South Carolina
1995 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks for your input, IMP. Sorry I didn't reply sooner, but light went out on it's own and there has been no shudder, so I've been gone from the site for a while. Before the trans light issue, we just had a coolant leak fixed by milling the heads (one was warped), replaced valve stem seals, cleaned the valves and combustion chambers and installed a top-end gasket set, then just 2 months ago, had to replace the fuel pump (in-tank). All was great until this past Monday morning when my son totalled the truck. He's fine thanks to fifteen-year-old air bags still functioning properly, but the truck is trash.
Ask him how he likes riding the bus again.
Old 11-29-2010, 01:56 AM   #17
aj2005
cromwell indiana
2000 eddie baurer
Vehicle Specs
Quoted: 0 Post(s)
aj2005 is offline   Reply With Quote
Old 05-18-2011, 08:50 PM   #18
jiminohio2010
jackson ohio
1995
Vehicle Specs
Quoted: 0 Post(s)
Does your speed OD work?
jiminohio2010 is offline   Reply With Quote
Old 05-18-2011, 10:25 PM   #19
Green '01
South Carolina
1995 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
Sorry, we don't have the truck anymore. My son wrecked it back in November and even though he's okay, the truck was a total loss.
Old 07-16-2011, 04:53 AM   #20
coldon3
az
96 4d 4wd
Vehicle Specs
Quoted: 0 Post(s)
My 1996 Ford Explorer wont shift into 2nd gear on its own, it stays in first gear and wont shift, until you "manually" do it by letting off the gas pedal for a moment. When im driving it, the o/d light starts blinking at around 55mph as well. Does anyone know how to fix the problem. I love my truck i bought it for 750$ and had to replace the plugs/wires, oil pressure sensor, fuel pump and some lines. i also had to repair the vacuum pump for the a/c (it wouldn't git off defrost) I (think) i even finely got the 4wd working still have to go play. i have invested a lot of time in to her and cant believe that a little light is making me and so many other people nuts. It seams like ford would do something for the problem but no recalls yet just a bunch of mad people because they have spent the 1k for a new trannie or a rebuild. I don't have 1k lying abought so any help would be appreciated thank yall ever so much.
coldon3 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
