Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
Low side valve location?
Reply
Thread Tools
Old 06-08-2010, 12:48 PM   #1
George1601
Millville, NJ
2003 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Just want to make sure I have the right valve for recharging my ac on a 2003 Mountaineer. I see one on the small cannister on the passenger side next to the washer fluid fill and another on the driver side on a tube just behind the radiator and in front of the ac compressor. Which do I use?
Thanks
George1601 is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-14-2010, 09:48 PM   #2
Bikehammer
Sterling Heights, MI
1997 Eddie Bauer 5.0 AWD
Vehicle Specs
Quoted: 0 Post(s)
I, just came in from an attempt and was asking the same thing. Did someone answer you?
Bikehammer is offline   Reply With Quote
Old 08-14-2010, 10:16 PM   #3
scucci
98 Sport
Vehicle Specs
Quoted: 1 Post(s)
The low side port is usually located on the accumulator. That is a cylinder with a switch mounted on top. Usually on the passenger side.
http://www.imcool.com/articles/airco...ccumulator.htm
The low side and high side ports are also not the same size. A manifold gage will only fit on the correct port. The low side is 13mm and the high side is 16mm. The low side is used for charging the system.
scucci is offline   Reply With Quote
Old 08-22-2010, 08:10 PM   #4
jmacattack
Texas
2004 XLT
Vehicle Specs
Quoted: 0 Post(s)
I just did this on my 2004 explorer. The low side is on top of the can on the passenger side in the front. The hi side, which I didn't bother with, is on the driver side in the front.
Hope this helps.
jmacattack is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
