Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
1995 Explorer with a temperature gauge problem.
Reply
Thread Tools
Old 06-10-2010, 08:12 AM   #1
sigihagen
Chaska, MN
1995 Explorer Limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I picked up a 1995 EXP Limited with 200K miles on it and have been driving it a few weeks now. When I was hauling some furniture around the temp gauge went to hot/overheating. Rested the car and it went away. Drove back and it never went hot again for about 2 weeks. Then it came back and red lined. We changed the thermostat and sensor but it is still redlining. The hoses read 150 degrees so it is not overheating. Coolant is fine and there is no air in the system. So it must be the gauge itself. Had a mechanic check it out and he agrees. Wants $250+ to fix it! Right.
I prefer to replace the gauge in the dash myself but do not know how to do it. I hear it is hard on blogs but is it? Is worth it. I prefer to not put in an external gauge but will if I must.
Can anyone help me with instructions?
sigihagen is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-10-2010, 08:14 AM   #2
sigihagen
Chaska, MN
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I found this but it is for a 1992.
http://truckexplorer.com/?s=ford+exp...ge+replacement
Old 06-10-2010, 08:42 AM   #3
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 411 Post(s)
Welcome to this forum! I've moved your thread into the stock 95-01 section.
BrooklynBay is offline   Reply With Quote
Old 06-10-2010, 10:06 AM   #4
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
Engine temperature sender
I suggest testing the engine temperature sender before replacing the indicator in the instrument panel. The sending unit is more likely to fail than the indicator. BrooklynBay has a useful thread that lists the resistance vs temperature for the sender.
2000StreetRod is offline   Reply With Quote
Old 06-10-2010, 10:11 AM   #5
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 411 Post(s)
An easy way to check the gauge is to disconnect the sending unit to see if it drops to cold, then ground the wire to see if it goes into the maximum (overheating) range.
Old 06-10-2010, 04:06 PM   #6
sigihagen
Chaska, MN
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Sending unit advise
We replaced the sensor as we found out that by grounding it the gauge went hot too. We replaced the thermostat as well at the same time.
Is the sending unit different then the sensor that sits just above the thermostat?
Old 06-10-2010, 04:23 PM   #7
2000StreetRod
Greenville, SC
Vehicle Specs
Quoted: 45 Post(s)
ECT sensor vs engine temp sender
The engine coolant temperature (ECT) sensor reports the engine temperature to the PCM for air to fuel ratio computations. The engine temperature sender output drives the instrument panel indicator. On my 2000 SOHC V6 the units have different threads to prevent incorrect installation. The sensors screw into a bushing in the plastic housing. There is a compression ring between the sensor and its seat to prevent coolant leaks. The bushing can spin in the housing if the sensor was previously over tightened. If the bushing spins then the expensive housing must be replaced. Use care when removing and do not overtighten when installing the sensors.
Old 06-10-2010, 04:26 PM   #8
ProjectAviator
SE, WY
2005 Explorer v8 XLT 4x4
Vehicle Specs
Quoted: 21 Post(s)
I had a problem with the temp gauge in my 95 Ex. I solved the problem I installed an Autometer electric temp gauge far more reliable than the stock one. I have noticed that the stock will still read something occasionally
Tim
__________________
2005 Explorer XLT V8 4x4
1998 Explorer XLT 4x4 trail truck project
95 Explorer XLT "Columbus" R.I.P
2013 Focus ST, "Pugsley"
ProjectAviator is offline   Reply With Quote
Old 01-12-2011, 02:16 PM   #9
Ford-Exploder
Canada
96XLT
Vehicle Specs
Quoted: 0 Post(s)
Question
Quote:
Ok doing this , Disconnect-Cold / Ground Overheat . If it does these 2 things does that mean the Sending unit is ~OK~ or ~Needs Replacing~ ??
Thanks for any help .
Ford-Exploder is offline   Reply With Quote
Old 01-12-2011, 02:19 PM   #10
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 411 Post(s)
Welcome to this forum! If it works, it means that the gauge is working, and the sending unit might be bad.
Old 01-12-2011, 02:27 PM   #11
Ford-Exploder
Canada
96XLT
Vehicle Specs
Quoted: 0 Post(s)
Thumbs up
Thank you brooklynBay for your quick reply , and your warm welcome to this site .
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
