EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Classifieds: Explorer / Ranger / Bronco II Parts For Sale and Wanted > Auto & Truck Parts For Sale > Used Ford Explorer - Ranger and all other Vehicles For Sale
Notices
Used Ford Explorer - Ranger and all other Vehicles For Sale Elite Explorers - Sell your used Ford Explorer, Ranger, Mountaineer, Navajo, Bronco II or any other used vehicle here. Private sales only! Complete vehicles only in this forum. No parts.
1996 Explorer Limited - $550
Reply
Thread Tools
Old 06-10-2010, 09:57 PM   #1
DavidEBSmith
Chicago, IL
'07 Mountaineer
Vehicle Specs
(Original Poster)
1996 Explorer Limited - reduced $475
This truck deserves a good home. Somebody who is willing to put some sweat equity into it will get a bargain. I listed it on Craigslist but nobody there appreciated it. I’m hoping somebody from Explorer Forums will.
It’s a 1996 Explorer Limited, V6, 4WD, 238,000 miles.
All the BAD first:
The big issue is that the output shaft on the transfer case has play in it. What this means in the short term is that it tears up the speedometer gear and the speedometer stops working. The problem is, the transmission uses the speedometer signal to know when to shift. Without it, it guesses, usually badly. It will probably get you around town if you never get out of second gear but you would not want to take it on the highway as-is. Eventually the transfer case will fail. A transfer case is expensive to have somebody else put in, not too bad if you can do it yourself.
The alternator may be bad. It didn’t want to charge when I started it in cold weather after it sat, but after keeping it on a battery tender, it’s working.
It has the air ride suspension. It’s not working, so I cut the wire to the
message center to turn off the warning. I’ve replaced the shocks twice and the compressor once over the life of the truck, so there’s some good parts there. If I were you, I’d replace the shocks with the cheapest non-air shocks you can get from Pep Boys.
Last time I tried to open the hood it was stuck. (edit - its open now)
There's probably other stuff that could fail at any time. It's 14 years old and has over 238,000 miles.
THE GOOD: Other than the stuff that’s broken, this truck runs good. It’s been maintained by a really good Ford dealer mechanic. It passed the emissions test 2 years ago, and had no codes last time I checked, so it should pass again. I've replaced lots of stuff over the years so there's a lot of relatively new parts.
It had new tires last year, they only have about 3000 miles on them. It had a new radiator last summer. It had a new flywheel last spring. The transmission was rebuilt a couple of years ago and should be good for the rest of the truck’s life. It’s fairly recently had new pads and rotors.
It was a Nevada car for most of its life, so the body is in great shape. There’s some rust starting by one of the rear wheels and a few surface spots here and there, but the body is solid.
This is a Limited, so it has all the fancy features for 1996. It has leather upholstery which is worn but not torn (although the switch panel on the driver’s side power seat is dangling). It has alloy wheels. It has power and automatic everything – power sunroof, power windows, power locks, power mirrors, power memory seats, remote access with keychain remotes, keypad on the door. It has the climate control where you just set the desired temperature. I fixed the blend door so you shouldn't have to worry about that breaking. It has automatic headlights, auto-dimming rear view mirror, heated rear window, heated outside mirrors, electronic message center. It has the factory audiophile sound system with the subwoofer in the back, cassette that works, CD changer (that doesn’t work), and power antenna (that is broken). I’ll even throw in a spare head unit for the audio. Clear title.
If you can fix this yourself it would make a great work truck. If you have an old Ex and want parts this is a great source. I just don’t want to put money into it, I don’t want to have it sitting in the backyard while I sell parts on eBay, I don’t really need a charitable deduction, and I’d rather see it (or at least parts of it) running around on the road.
I’m asking $475. The wheels and tires are worth that. You have to tow it away (it’s in Chicago, Illinois). I won't deliver it, you can't test drive it beyond driving it back and forth in my driveway.
Email to explorerforum@davidebsmith.com if you’ re interested or have questions.
DavidEBSmith is offline   Reply With Quote
Old 07-18-2010, 05:50 PM   #2
DavidEBSmith
Chicago, IL
'07 Mountaineer
Vehicle Specs
(Original Poster)
I got the hood open, I'll throw in a Haynes manual and a service CD and 3 keychain remotes, for the $475 I'm listing it for on CL.
Old 07-19-2010, 02:56 AM   #3
pugulis
Vehicle Specs
Why are all the nice Explorers 1000 miles away from me. Wish I could buy it. But I'm from Long Island NY and it's a bit far. I can't believe your having trouble selling it.
pugulis is offline   Reply With Quote
Old 08-11-2010, 03:22 PM   #4
DavidEBSmith
Chicago, IL
'07 Mountaineer
Vehicle Specs
(Original Poster)
Down to $450, the only calls I get from Craigslist buyers ask "Is it a good car for driving to work?" or "Can I test drive it?" or "Will you take $250?" or "If you pay me $200 I'll tow it away."
Old 08-11-2010, 03:46 PM   #5
damarble
CdA, ID
01 Sport, minor mods
Vehicle Specs
I'd buy it just because, if you were local. Can't beat the price and I could have the t-case fixed for $60. It looks cush, I'd totally DD it.
__________________
01 Sport SAS'd (35s, FW D44/8.8, 3.9L Turbo Diesel, Tilt Front Clip in progress)
91 Sport SAS'd (34s, D30/8.8 super low budget, done and wheeling but a 5.8L swap is in the works)
damarble is offline   Reply With Quote
Old 09-01-2010, 09:00 PM   #6
pauley
Madison, Wisconsin
93 xlt
Vehicle Specs
for what he is asking some one could buy it ship it and fix it and have a hell of a nice truck for under 1500.
pauley is offline   Reply With Quote
Old 09-11-2010, 12:17 AM   #7
majorboot
Brisbane
1997 Ford Explore Limited
Vehicle Specs
AU parts
How much for just the manual, CD and remotes?
Quote:
majorboot is offline   Reply With Quote
Old 09-27-2010, 05:57 PM   #8
joebluefish
Plymouth mass
2000 ltd
Vehicle Specs
since the arc is not working will you sell me the lower bracket from axle to sensor? 02360
joebluefish is offline   Reply With Quote
Old 10-03-2010, 12:16 AM   #9
Elessar65
Wichita, Ks
Elessar65's Avatar
98 Sport, 95 Ranger SAS
Vehicle Specs
Quote:
I am working the numbers on that right now. I would love to buy this and give it a good home.
How much would need to be done to it to get it to drive the 800 miles to Ks? Semi-reliably, if I go get it I have my 98 sohc sport with a bad tranny to scavenge parts from to get it here.
__________________
Wheel it, Break it, Fix it, Repeat...
Elessar65 is offline   Reply With Quote
Old 10-03-2010, 12:26 AM   #10
pearly
07 xlt
Vehicle Specs
I can't believe you're having a hard time getting rid of it. Put a for sale sign on it and sit it down on the south side somewhere - somebody somewhere needs a cheap vehicle.
What kind and size tires are on it, with only 3k miles? I may be interested (i'm in Chicago).
pearly is offline   Reply With Quote
Old 12-17-2010, 11:29 AM   #11
Flippindabird
The Pocono Mountains
1999 AWD V8 Mountaineer
Vehicle Specs
wanna sell the subwoofer enclosure w/ amp??
__________________
1999 Mountaineer Monterey V8 130K. It's the wife's, forged 5.0L 10:1 cr with a H.O. Cam, ported gt40p heads and ported lower intake, needs headers ...slowly but surely
Flippindabird is offline   Reply With Quote
Old 01-02-2011, 01:31 AM   #12
mrbeefy
neopit , wisconsin
91 explorer
Vehicle Specs
If I had the money to go down there and buy it, I'd bring a transfer case and swap it out in a parking lot lol
__________________
91 EB all stock...
mrbeefy is offline   Reply With Quote
Old 01-14-2011, 11:39 AM   #13
Dre
Chicago
Dre's Avatar
94 Limited
Vehicle Specs
tell me it's still available?
__________________
4x4 Werks by Dre
My Gallery
Dre is offline   Reply With Quote
Old 04-11-2011, 01:09 PM   #14
Wrathchild74
Twin Falls,Id.
'96 Limited 4.0
Vehicle Specs
Is explorer still available
Will have cash june 3rd if still available. Would have it first of may but mass bills. I am moving to Oregon 1st of june and would look at having it shipped.by the 3rd of july.
Wrathchild74 is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
