Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
A question about EPC solenoid compatibility between 4R55E transmissions...
Reply
Thread Tools
Old 06-11-2010, 12:55 PM   #1
J.Rovirosa
Socal
1995 & 2003 Limiteds
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Smile A question about EPC solenoid compatibility between 4R55E transmissions...
Hey guys,
Getting ready to dive into updating a few of the common problem areas on my 255K mile '95 Limited's trans. (adding drain plug, shift kit, updated separator plate gaskets, updated solenoid bracket, band adjustment, etc) and figure that I might as well replace the EPC solenoid while I'm at it. The trans is a Ford remanufactured unit and has roughly 55K miles since I had it installed, and I'm assuming they didn't replace the solenoids on the rebuild.
Shifting seems okay, if not a little soft, but occasionally the rpm will rise quite a bit and the trans will refuse to upshift if the gas is floored at freeway speeds and a downshift occurs, which I guess is a shift flare issue? Also, around every 10K miles, the trans will go into limp mode and throw a code, which until recently I didn't know I couldn't read with my OBD2 scanner. Hasn't happened recently, so I have no idea what the code is. The trans does start to shift firmer just before it happens. I do get the off-throttle, downshift clunk when coasting to a stop and there's also a slight delay when going into reverse. Fluid looks okay, but I think I'll avoid getting it flushed (third transmission it's had, first two were flushed religiously and both still died around 100K freeway, no-towing, miles).
Finally, on to my question I'm assuming the transmission is correct internally for a '95 Explorer. I haven't torn into it to see what's in there...just gathering parts right now. But if it's for a later model Explorer that uses the red-banded EPC solenoid, should I use the green-banded solenoid that's correct for a '95? In other words, are there other internal differences in later model year transmissions that would dictate I use anything other than the correct solenoid for a '95? I'm guessing that the type of solenoid used is only determined by the PCM used, but I want to make sure before I buy the solenoid.
Thanks
__________________
'95 Limited 2WD (white/gray, stock DD, 302K miles and counting....)
'83 T-Bird (silver/red, 5.0 CFI/AOD, SEFI swap in-progress)
'97 Cobra (black/black, bolt-ons, garage queen #1)
'04 Lightning (black/gray, stock, gas guzzler, garage queen #2)
J.Rovirosa is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-11-2010, 01:18 PM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 411 Post(s)
The EPC & TCC solenoids on the 4R55E (95-96) are different than the ones used on the 5R55E (97-01). The range sensors are different as well.
BrooklynBay is offline   Reply With Quote
Old 06-11-2010, 02:00 PM   #3
J.Rovirosa
Socal
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Thanks for the reply. I was under the impression that the 4R55E was used after '96.
__________________
Old 06-14-2010, 12:21 AM   #4
IronIndian
Glendale, CA
1991 Mazda Navajo
Vehicle Specs
Quoted: 0 Post(s)
My 96 xlt has a 4r55e with the green band EPC. I tried to "upgrade" my green to red and it backfired. The trans shifted funky and just felt wrong. Put the green one back in and all went back to normal...
__________________
Jeremy S.
01 Excursion PSD w/MPT81's
IronIndian is offline   Reply With Quote
Old 06-14-2010, 12:38 PM   #5
J.Rovirosa
Socal
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Much appreciated...I'll order the green one.
__________________
Old 06-14-2010, 03:23 PM   #6
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 411 Post(s)
Check WWW.800700Tran.Com.
Old 07-30-2010, 08:32 AM   #7
PUR PONY
CT
96 LTD, 96 XLT, & 98 XLT
Vehicle Specs
Quoted: 0 Post(s)
question to this... i have a 96 limited with a rebuilt ford tranny as well. It has 60K on it and is flaring up.
I put a rebuilt valvebody in it 10K miles ago that helped the flare but its now back!..... Im pretty sure the rebuilt valvebody i but in was late model... so im guessing its a 5r55 valvebody??? I just put the superior shift kit in and and all the indications from the directions show i have a 5r55 transmission int he truck.... does this sound correct? The EPC solenoid thats in it now is a RED band and it was working fine... so I am guessing i want to replace it with a RED banded one.... correct?
__________________
--1996 Explorer Limited V6 - X-Spec suspension, Daily Driven (194K miles)
--1996 Explorer Limited - Supercharged V8, -Sold @ (135K miles) and Missed
--1996 Explorer XLT 4x4 - SOLD @ (198K miles)
--1998 Explorer XLT - V8, AWD Wifes ride (78K miles) -- FOR SALE
--2006 Explorer EB 4x4 - Loaded... Just Purchased 3/16/12
--1996 Mountaineer - Smashed parts truck.
PUR PONY is offline   Reply With Quote
Old 07-30-2010, 10:59 AM   #8
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 411 Post(s)
It sounds like you put a 5R55E valve body into the 4R55E transmission.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
