Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
ac low pressure switch won't cycle - 98 explorer
Reply
Thread Tools
Old 06-13-2010, 12:28 PM   #1
ddeen
Chicago, Il
1998 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Can somebody help point me to a thread that addresses subject concern if it has already been covered. Just recharged my ac system because clutch was not cycling. Charge levels look to be correct now but compressor clutch still does not engage. I jumped the low pressure switch and the clutch engages. I thought it was the switch so I replaced it with a new one but it did not fix the problem. Any ideas on what is wrong ? Thanks.
ddeen is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-13-2010, 12:56 PM   #2
safn1949
Mankato, Minnesota
M60A1 my first offroader
Vehicle Specs
Quoted: 2 Post(s)
Quote:
Check the AC pressure at the switch port and if it is good and the AC works correctly with the switch jumped you have a bad switch,just because it's new doesn't mean it's any good.
When you jump it does the AC blow cold,are the pressures correct? Post your high and low side pressures sitting and running.
__________________
1994 XLT,4.0,3.73 LS
149,000 miles.
Need a Panasonic Toughbook? I have them,email me for details.
safn1949 is offline   Reply With Quote
Old 06-13-2010, 02:25 PM   #3
ddeen
Chicago, Il
1998 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
safn1949, thanks. Just checked the low side port and pressure = 39 PSI and does not change if engine is running with AC on. Jumped the low side switch again and the air blowing inside is not cold. Now I am completely stumped. I don't have a tool to measure high side pressure.
Old 06-13-2010, 10:21 PM   #4
ranger7ltr
Great State of Texas
1999 Sport
Vehicle Specs
Quoted: 35 Post(s)
39 psi static pressure is not enough...
Are you measuring system pressure with the compressor off? If so, that is static pressure...When you jumpered the low pressure switch, did the compressor actually engage? If it did engage, there is not enough refrigerant in the system to start the cooling process...
Even with whatever gauge you are using, if the compressor kicks in, what is the pressure reading at that point? To actually start the cooling process [and close the low pressure switch]the system would need approx. 70-100 psi static pressure...And you really need to monitor the high side pressures to know the charge level before the pressures go too high and get to the level of blowing stuff up...Since jumpering the low pressure switch engaged the clutch, the electrical system for the a/c is working and you just need to get the system pressure high enough to close the switch...
Your high side should be 2.2-2.7x ambient temp and anything higher than that tells you the cooling of the condensor is not sufficient or there is a problem inside the system...
__________________
When in doubt, use a bigger hammer!
2014 Jeep Compass Limited [Company Vehicle]
2003 Ford F-150 XLT Supercab
1999 Ford Explorer Sport [new playtoy]
1983 Ford Ranger V8 [soon to be gone]
ranger7ltr is offline   Reply With Quote
Old 06-14-2010, 08:43 AM   #5
safn1949
Mankato, Minnesota
Vehicle Specs
Quoted: 2 Post(s)
Yep,sounds like a low charge.I spent all my years with R-12 but running with the AC on and cold the low side should be around 35 psi with 134A I think.But I know someone who fools with 134 will correct me if I'm wrong.
__________________
149,000 miles.
Old 06-14-2010, 09:20 AM   #6
ddeen
Chicago, Il
1998 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks. I have borrowed and better guage from work. I can now check low pressure and high pressure side. I will also check static v.s dynamic pressure. Will know more tonight.
Old 06-14-2010, 10:36 AM   #7
ranger7ltr
1999 Sport
Vehicle Specs
Quoted: 35 Post(s)
Static pressures are the same...Running or dynamic pressures will vary...
Quote:
Since R-134A runs at higher pressures what you can expect is for the high side pressures to follow the 2.2-2.7x ambient temp guideline...The low side pressures still reflect the approx. evaporator temps...
One other difference is that an R-134a system charge is more critical to being under or over charged...Where you could "top off" an R-12 charge and be close to correct, R-134a is best charged into a vacuum by weight and then not adjusted...Of course people do this and they will usually find the cooling is ok but not as cold as they would like...It does take more finesse to top off a R-134a system and not over charge it...
__________________
Old 06-14-2010, 07:58 PM   #8
ddeen
Chicago, Il
1998 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thank you all for all the good advice. The guages I borrowed from work were used and abused and leaked. I had to go to plan B. I could only measure the low pressure side. I filled it up to as much as my one can could fill. It measured to about 65PSI static and 15 PSI dynamic. The compressor now engages intermitently. At this point I really think it is just undercharged. I am satisfied with what I have done and learned and will take it to a AC shop and get it evap/filled properly.
Old 06-14-2010, 08:05 PM   #9
safn1949
Mankato, Minnesota
Vehicle Specs
Quoted: 2 Post(s)
Yep,way too low on the low side.I have a slow leak in my 94 so I just top it off every year,but I also live in Minnesota so it's not as critical.I might use it 6 times a year.For example it's June 14th and 66 F outside.
__________________
149,000 miles.
Old 06-21-2010, 01:02 PM   #10
ddeen
Chicago, Il
1998 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
quick update. I bought a 19oz can and got it to fully load. low pressure is running at around 34PSI. Fixed the problem. System is running good. Thought I would post an update to help folks that are going through the same problem. Saved a couple $ trouble shooting this myself.
Old 06-26-2012, 10:40 PM   #11
Drew_Rymer
Sacramento, CA
1998 Ford Explorer 4x4
Vehicle Specs
Quoted: 0 Post(s)
US 98 Explorer AC is Not Blowing out Cold air Please Help
I'm having a similar problem with my AC for my 98 Explorer. The AC is working just not blowing out cold air and when I set the AC on Max AC and then accelerate it stops blowing air out of the vents and starts blowing air up out of the defroster vents...I Don't know why maybe the AC Clutch??
I purchased one of those shitty recharge kits w/ a gauge and when I attach it to my Low Pressure Port the PSI goes from the green (not sure what PSI exactly I think about 20 - 30 PSI) to over 100 - 120 PSI (The Red) then the compressor engages and it goes back down to about 20 - 30 PSI (the Green on the gauge) and it just keeps idling back and forth while the engine is running. So how the hell do I know if I can recharge the system w/o possibly damaging one of the hoses and sending myself up shit creek w/o a paddle? I live in Sacramento CA and luckily it's not hot for now but it will get back up to the 90's and 100's soon. Any tips or suggestions would be much appreciated. Thanks
Drew_Rymer is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
