#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Code 172 after changing O2 sensors.
Reply
Thread Tools
Old 06-15-2010, 01:16 AM   #1
mechjames
Richmond, BC
mechjames's Avatar
1994 Explorer XLT
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
HEGO sensor circuit indicates system lean (right side)
I did reset the computer before I changed the o2 sensors. I thought it might be a good thing to do because i'm approaching 300,000 km and i'm unsure if they have been done in the past, and the concensus on here is that it seems to reduce mileage and power and not throw a CEL, because the EEC-IV has too much tolerance in O2 sensor readings, or the sensors just get lazy.
I left the battery unplugged the night before I changed them. All seems well and it drives well but it throws a Code 172 a few minutes after driving. CEL seems to come and go as you're driving at first, but after that first few minutes when it comes on, it seems to stay on now.
No KOEO off codes.
Do I have a dud o2 sensor? Or is it just detecting a lean condition on the passenger's side? It seems to drive really great, but I won't know if i'm saving gas until I fill up the tank.
__________________
-1994 Explorer XLT Green, 208,000km, 5.5" duff lift, 35" BFG All Terrains, 4.0L 5 speed, manual shift T Case, KKM Air Intake
-1994 Explorer XLT Black.[298,100km]
Retired
mechjames is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-15-2010, 01:26 AM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Did you check the wiring to see if any insulation is melted, and shorted to the exhaust system?
BrooklynBay is offline   Reply With Quote
Old 06-15-2010, 01:32 AM   #3
mechjames
Richmond, BC
mechjames's Avatar
1994 Explorer XLT
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Quote:
Will check in the morning. Wiring from the connector to the harnesses were fine when I changed it.
I'm assuming you mean the wires that run from the connector to the sensor itself.
I don't think that the wires would have shorted so quick, because even on my first test drive, the CEL came on pretty quick. I will check it tomorrow.
I didn't have a CEL before doing the O2's.
__________________
Retired
Old 06-15-2010, 03:36 AM   #4
rhauf
Ca
'93 and '91 explorer
Vehicle Specs
Quoted: 0 Post(s)
make sure the connectors, where the o2 sensors plug in are making a good connection. sometimes they get corroded and don't connect well. plug them in and out a few times, use dielectric grease etc.
rhauf is offline   Reply With Quote
Old 06-15-2010, 09:06 PM   #5
TedJ
Fair Lawn, NJ
'94 Sport
Vehicle Specs
Quoted: 1 Post(s)
What brand sensor did you use?
Try putting the original back in and see what happens. After all the pre-broken for my inconvenience parts I have gotten I would not be surprised if it was defective or something.
TedJ is offline   Reply With Quote
Old 06-15-2010, 10:55 PM   #6
mechjames
Richmond, BC
mechjames's Avatar
1994 Explorer XLT
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Bosch Premium Direct Fit. Bosch supposidely makes the OEM sensors for Ford. They looked damn near identical.
__________________
Retired
Old 06-16-2010, 01:22 PM   #7
Reejerey
SLC UT
92 XL 2 dr 4x4 manual
Vehicle Specs
Quoted: 0 Post(s)
possibly an exhaust leak in around the o2 sensor
Reejerey is offline   Reply With Quote
Old 06-16-2010, 02:06 PM   #8
TedJ
Fair Lawn, NJ
'94 Sport
Vehicle Specs
Quoted: 1 Post(s)
Obviously check for an exhaust leak.....
Bosch should be good, but it's hard not to suspect the replacement part if you have a problem you didn't before installing it. Try swapping them side for side or with the old one. If the code changes to one for the other side or goes away with the old one back in, go and complain that it is a dud.
Old 06-16-2010, 02:56 PM   #9
mechjames
Richmond, BC
mechjames's Avatar
1994 Explorer XLT
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
I do have a tiny exhaust leak, but it's downstream of the O2 sensor. I had to cut the Y pipe 2 years ago to get the transmission out and welded it back together. Just a tiny little tick, but it's not before the o2 sensor, it's after.
I will just go and exchange it, the parts store is good to me. It wouldn't be worth my time to switch the sides, it's hard enough trying to unplug and plug it back in behind the engine.
If it still shows a code with a new sensor, then i'll switch sides and see if the code follows.
__________________
Retired
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
