#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
help cant get the fan cluch off
Reply
Thread Tools
Old 06-16-2010, 06:58 PM   #1
motorhead7635
york Maine
02 sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i cant get the fan cluch off of my 02 sport, the bearing is complety blown out and i cant get it off. what do i do the get it off?
motorhead7635 is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-16-2010, 07:12 PM   #2
Xplorer82
OH.
'97 XLT... '98 Eddie...
Vehicle Specs
Quoted: 1 Post(s)
Quote:
either go rent or buy the tools necessary. autozone rents them out.
that or get creative and fab some tools up from scrap metal. thats what i did so i dont have to bother my buddy for his real set of tools..
__________________
┌П┐(-_-)┌П┐
'98 Eddie Bauer. 4x4, 4.0L SOHC. 190k miles and counting, Flowmaster 50 series, Amsoil Ea air filter, 31x10.5" Sumitomo All-Terrain & the dreaded rattle.
R.I.P : '97 XLT - it was a good 8yrs..
Xplorer82 is offline   Reply With Quote
Old 06-16-2010, 07:25 PM   #3
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
Special tool
You can rent one of the special tools shown below. I've also used a 15 inch long adjustable wrench on the clutch nut and a very long box wrench on one of the pulley bolts while pressing against a second pulley bolt.
11 Fan & clutch removal
2000StreetRod is offline   Reply With Quote
Old 06-16-2010, 07:27 PM   #4
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
What kind of tool did you use? Did you turn the shaft in the correct direction?
BrooklynBay is online now   Reply With Quote
Old 06-16-2010, 09:01 PM   #5
eagles350
Woodleaf NC.
1999 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
I just popped mine a little with an air chisel. didn't take much at all.
__________________
1999 Explorer XLT 4x4, 4.0 sohc, auto
1996 F-350 XLT 4x4 C/C SRW ,7.3 PS, 5 Spd. Man.
1994 Ranger XLT Xcab 4x4, 3.0, 5 spd. man.
eagles350 is offline   Reply With Quote
Old 06-16-2010, 09:18 PM   #6
Blee1099
Evil Asian
Elkridge, MD
Blee1099's Avatar
91
Vehicle Specs
Quoted: 10 Post(s)
Use the fan clutch tool.. preferrably the set with 2 long wrenches.. Sometimes having another person hold one wrench while you turn the other helps.. Remember they are reverse threads. We did a fan clutch swap at All Ford Nationals in under 10 minutes between 3 of us working on it.
Blee1099 is offline   Reply With Quote
Old 06-16-2010, 09:19 PM   #7
Blee1099
Evil Asian
Elkridge, MD
Blee1099's Avatar
91
Vehicle Specs
Quoted: 10 Post(s)
Quote:
That don't make sense.. Its threaded onto the water pump.. How can air chisel remove it?
Old 06-16-2010, 09:25 PM   #8
motorhead7635
york Maine
02 sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
dose the cluch come of the shaft coming from the water pump or dose the shaft come off the water pump pully? if it comes off the shaft how dose the the cluch spin of with the bearing blown apart? or how do you keep the pump from spinning?
Old 06-16-2010, 10:23 PM   #9
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 380 Post(s)
One tool holds the pulley while the other turns the shaft.
Old 06-17-2010, 03:44 PM   #10
motorhead7635
york Maine
02 sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i got it the problem was every one told me it was revers thread and i got the new part and it wasnt and i did it with out the cluch tools. i put a boxed end wrench on one of the pully bolt and had it leaning against the bolt next to it and put a open end wrench on the nut.
Old 06-17-2010, 09:19 PM   #11
eagles350
Woodleaf NC.
1999 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
You just hit it a little in the nut flat in the direction of removal. It's not that tight. ( unless your going in the wrong direction) . mine moved less than an
1/8 of a flat. took it the rest of the way off by hand. Done in 30 sec.
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
