Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Modified 2002 - 2005 Explorers
Notices
Modified 2002 - 2005 Explorers Questions related to modified 2002 - 2005 Explorers and Mountaineers. For Sport Trac and Sport models use the 1995-2001 forum. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap.
Check Charging System
Reply
Thread Tools
Old 06-23-2010, 12:04 PM   #1
Fordy55
2005
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Dk Exp Check Charging System
Yesterday I was driving, and the "Check Charging System " message popped up on my message center and also a light came on. It went away seconds later, but then came back two more times but they went away after a few seconds. This used to pop up often, and when my car was getting another problem fixed at the Ford Dealership they replaced my alternator (few months ago).
Today when I was driving a heard the beep (the beep that goess off when there is a message or low fuel level), but no lights came lit up on the dashboard and no message came up. I heard this beep a few times...
Any ideas what the beep is or why it said Check charging system?
__________________
2005 Black Explorer: Sirius XM Radio, Kenwood Amp, Sony Xplod Sub, Pioneer door speakers, 6000k HID Headlights, 3000k HID Fog Lights, Billet Grill Combo, Clear Corners
Fordy55 is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-23-2010, 12:28 PM   #2
Squirrelmaster
St. Paul, MN
'04 Explorer Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
My first guess would be a failing battery, second would be corrosion build-up, and third would be worn cables (since you had the alternator recently replaced, it doesn't make the list). Check your battery's voltage when off, cranking, and running. Then inspect it for cracks, leaks, bulges, or fluid level (if it is serviceable). Along with that, check the terminals for corrosion buildup, as well as the ends of the cables going to/from the battery, alternator, and engine block. Then also check ground cables for corrosion, as well as verifying there are no split, cracked, fractured, or cut cables in any of the above. That should give you a good baseline to start with. Good luck.
Tom
__________________
2001 Chevy 2500HD 6.0L 4x4 - sitting in Texas
2004 Ford Explorer Sport Trac Adrenalin 2wd - also in Texas
2004 Ford Explorer Eddie Bauer 4x4 V8
2007 Jeep Wrangler Rubicon
Squirrelmaster is offline   Reply With Quote
Old 06-29-2010, 08:59 PM   #3
Fordy55
2005
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
Battery Voltage with multimeter = CHECK
Cables were replaced 2-3 weeks ago = CHECK
Corrosion = Check
Tightness = Check
all the wiring = Check
Maybe a belt problem? I'm not too good with engines so I don't know how to check the belt. I heard that might be the problem...
__________________
Old 06-30-2010, 07:30 AM   #4
Squirrelmaster
St. Paul, MN
Vehicle Specs
Quoted: 0 Post(s)
Have you scanned your Explorer for diagnostic trouble codes?
Tom
__________________
Old 11-02-2010, 03:56 PM   #5
db04
wilmington ohio
2004 eddie bauer
Vehicle Specs
Quoted: 0 Post(s)
My check charging comes on to and I replaces the cables terminal and had the battery check and alter. Check yet it still comes on any help would be great thanks
db04 is offline   Reply With Quote
Old 11-02-2010, 06:14 PM   #6
Ronin8002
Virginia
2008 XLT Ironman
Vehicle Specs
Quoted: 127 Post(s)
check the connectors going into the back of the alt...sometimes they get corroded inside.
Ronin8002 is offline   Reply With Quote
Old 11-02-2010, 08:15 PM   #7
jaydez
Hartford County, CT
2005 XLT V6 4x4
Vehicle Specs
Quoted: 0 Post(s)
check to make sure your batter cables are tight. Last time I had work done at a dealership on my Fusion they didn't tighten the cable and I kept getting the message when I would hit a bump.
jaydez is offline   Reply With Quote
Old 03-07-2011, 02:42 PM   #8
phouse
Phila PA
1991 Explorer
Vehicle Specs
Quoted: 0 Post(s)
DB04 and Fordy55,, what fixed the problem?? This forum only works when we follow up with solutions to our problems
__________________
1991 Explorer 4WD 4DR 4.0 V6 Pushrod 196K blown head gasket.. RIP
2005 Explorer XLT
1998 Mercedes Benz E 430 Sport
1987 Oldsmobile Cutlass Salon V8 Factory Bucket seats
phouse is offline   Reply With Quote
Old 03-07-2011, 02:48 PM   #9
fedyfedz
Suffolk County, NY
2002 limited v8
Vehicle Specs
Quoted: 4 Post(s)
not sure if this is relevant or not but , i heard that same beep twice and it was driving me crazy, i found out my back hatch wasn't closed securely and every time i went over a bump it would beep but wouldn't say door ajar it was weird..also when i was low on brake fluid when i would floor it or go over a bump i would hear the same beep but no message displayed. i refilled brake fluid and it went away. Both situations it was the same beep as stated in first post. sorry if this is off topic.
__________________
Sold 2002 explorer v8 limited
Current Ride:2001 Dakota v8
*Registry*
fedyfedz is offline   Reply With Quote
Old 03-18-2011, 02:06 PM   #10
phouse
Phila PA
1991 Explorer
Vehicle Specs
Quoted: 0 Post(s)
Update.. 2005 Explorer V8 XLT Battery light on and The "CHECK CHARGING SYSTEM" on the message center was on after using a refurb from Auto Zone
AutoZone alt. was returned,, I was getting a full charge, but i don't think it was talking back to the truck to turn the the battery light off in the truck even though everything else was working, meaning 14volts and charging.. got a full refund..
took that money to the Ford dealer and got one from them..
Part # F8OZ-10V346-CARM This one had a 3 terminal connection I believe the AZ one only had a 2 terminal connection, even though the cable from the truck had only two wires the green and orange one.. The middle connection was not being used i guess.. any way all is well..
Got 14 Volts on the B+
Got 14 Volts on the Batt terminals
The "CHECK CHARGING SYSTEM" on the message center is off
The Battery Light is off as well..
__________________
2005 Explorer XLT
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
