| Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Nashville, TN
'92 XLT
Iffy ignition
Recently, upon turning the key the truck will start (or almost start), then get weak and stop. I'll turn the key again, and it starts no problem. This startup failure only happens the first time I try to start it in a day; the rest of the day it works like a charm. Is this an electrical problem or what? and how do I fix it?
Thanks |
#2 |
Courtenay, BC
99 B4000 4.0L OHV
I would do a fuel pressure test (KOEO) before first start. When was the last time you changed your fuel filter?
#3 |
Nashville, TN
'92 XLT
Replaced it last summer with an oil change
#4 |
Nashville, TN
'92 XLT
I did a fuel pressure check and it was pretty low (31 psi). After I shut off the engine, pressure dropped pretty rapidly back to practically zero. I'm under the impression that it should stay pressurized for a few minutes, correct?
So what are the likely candidates: pressure regulator, pump, filter? |
#5 |
Spanish Fork, UT
92 XLT and '87 Bronco II
Was it 31 psi with the pump running or was that after the pump shut off?
I forget exactly what the spec is (if you have a Chiltons, they have a nice fuel pressure diagnosis chart in there), but the system should not drop more than a few psi after 2-5 minutes. Usual culprit is the check valve in the pump. __________________ Mr. Shorty 92 XLT 4x4 87 Bronco II XLT 4x4 '98 Chev K1500 Suburban SLT 4x4 |
| Thread Tools | |
