sportrak
- May 16, 2010
- WI
I have a 2001 4.0 with auto trans. I've done an archive search but didn't find much. I think I was having problems with what terms to use for the search. Recently, I've noticed that when I shift the lever into park the trans does not "lock" on the detent and it slides backwards on the detent (dangerous). Also, it doesn't always start because the nuetral safety switch is activated. It also feels sloppy when shifting from park into drive. I'm wondering if others have experienced this problem. Is there a common problem with the shift lever, cable or ???? Thanks. It has 141000 miles on the clock!
