Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Ranger - Mazda B-Series Forum > Ford Ranger - Mazda B-Series Forum
Notices
Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well.
remove&replace lower ball joints(2004 ford ranger)
Reply
Thread Tools
Old 07-03-2010, 08:19 PM   #1
tedshreds
san clemente,california
2004 ford ranger
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i wanna remove and replace my lower ball joints on 2004 ford ranger.. anyone got any tips or instructions?
tedshreds is offline   Reply With Quote
( Join the Elite Explorers )
Old 07-04-2010, 11:10 PM   #2
McCormack
S.E. WI
2000 Ranger
Vehicle Specs
Quoted: 3 Post(s)
Quote:
They're a bear to do, so give yourself plenty of time so you don't have to rush things. Also, make sure your replacement ball joints are equipped with zerk fittings for greasing... I put new non-greasable ball joints in my '00 at around 80,000 mi, and at 140,000 mi they already need replacing again.
McCormack is offline   Reply With Quote
Old 07-04-2010, 11:30 PM   #3
Jack Flash
Ethel, MS
(3) '88 BII's, '99 Ranger
Vehicle Specs
Quoted: 2 Post(s)
I replaced all 4 ball joints on my ranger last year. the bottom ones were easy and pressed out and in with one of those "borrowed" c-clamps from the "Zone". the uppers were another story...had to take the a-frames off and put them in a shop press to get the suckers out.
J...like McCormack said, get the greasable ones when you replace them.
__________________
Jack of All Trades
Retired From Most
www.internationalcuemakers.com
www.jimboarmy.com
Latest Project: '86 Ranger 4X4
Jack Flash is offline   Reply With Quote
Old 07-11-2010, 12:36 AM   #4
dmac0923
Yorktown
2002 ranger xlt
Vehicle Specs
Quoted: 1 Post(s)
i just did the uppers and lowers in my 02 4x4 ranger. they are the same as the explorer so you can hop over to that forum and look at one of the how to's
the lowers have to be pressed out/in. with the uppers, if you are still running the factory control arms, you need to replace the control arms. the aftermarket control arms have servicable upper ball joints but the original equiptment do not.
__________________
2002 Ford explorer 4dr eddie bauer 4.0 auto 4wd
2002 ford Ranger 4dr XLT 4.0 auto 4wd
1995 ford explorer 4dr XLT 4.0 auto 4wd
1969,1970 Mustangs
dmac0923 is offline   Reply With Quote
Old 07-11-2010, 12:42 AM   #5
dmac0923
Yorktown
2002 ranger xlt
Vehicle Specs
Quoted: 1 Post(s)
here is a basic overview of the process
remove wheel.
remove brake caliper and bracket and rotor
remove dust shield.
disconnect abs wire
remove all cotter pins from castle nuts
remove castle nuts from upper and lower joints
remove upper ball joint pinch bolt from knuckle
take mini sledge and whack upper control arm/ball joint out of knuckle
knock knuckle off of lower ball joint
press lower ball joint out of lower control arm
remove upper control arm from fram
press new lower ball joint into lower control arm
install new upper control arm.
take knuckle and place on lower ball joint first, then align stud for upper ball joint
secure/tighten nuts install cotter pins
install dust shield, brakes, connect abs wire
get alignment
__________________
1969,1970 Mustangs
Old 10-15-2010, 08:30 PM   #6
davidg25
Wake Forest, NC
2000 Ranger XLT 3.0L Flex
Vehicle Specs
Quoted: 0 Post(s)
Ball joing replacement procedure?
Quote:
remove wheel.
remove dust shield.
disconnect abs wire
get alignment
Did you not have to compress the spring and remove the strut? I have a 2000 and the Haynes manual says that I have to do that (as well as support the assembly with a jack).
Anyone? If there's a 'fast track' (all things considered), please point me in that direction.
tx,
dave
davidg25 is offline   Reply With Quote
Old 10-16-2010, 11:49 AM   #7
McCormack
S.E. WI
2000 Ranger
Vehicle Specs
Quoted: 3 Post(s)
Quote:
Use your lower A-arm as your jacking point* and then the weight of the truck will keep the spring compressed and you can then undo your spindle and change out the ball joints.
*Or else jack your truck up and then lower it onto blocks that are placed under the lower A-arms.
Old 10-16-2010, 12:10 PM   #8
davidg25
Wake Forest, NC
Vehicle Specs
Quoted: 0 Post(s)
Got it - it just looked like it was better to deal with the steering knuckle than taking out the spring and lower control arm as the Haynes manual said to do.
Now I'm just trying to get the lower ball joint separated - it's really a mess.
THANKS !!!!!
dave
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
