anarky321
- May 10, 2010
- Jacksonville, NC
- 1998 Explorer Sport
1998 Ford Explorer Sport
battery dies just from listening to music for half an hour with the engine off
is the voltage across the battery terminals with the car running dependent on whether the battery is good? im getting 12.5V running, wouldn't a running voltage that low be considered a bad or failing alternator? trying to figure out whether i need to replace the battery of the alternator
car doesn't die while running so the alternator is putting out enough voltage to keep everything going including AC and stereo, although sometimes the car will die when put into reverse, which i attributed to other causes but maybe its related
edit: also i get a whine on acceleration from the front, i havent diagnosed it yet because i dont mind the noise at all, i will check tomorrow whether its the alternator making the noise, i remember reading somewhere that a bad voltage regulator would cause whine
on a related note, can i somehow turn off the timer that keeps my headlights on for 5 min after the engine is shut off? a bad charging system and a 5min headlight timer are a bad combination
