| Stock 2006 -2010 Explorers Stock 2006 -2010 Ford Explorer Forum. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#1 |
Wannabe Elite Explorer
installing factory nav
so i was looking at my radio today which is just a single disc mp3 player and i have two same connections as the nav radio expect for the one circle in red, what happens if i leave that unplugged, i was told by techician that connection is just for the amp built in the radio, and can do without it... is that true or no?
#2 |
Where did you buy and how much?
#3 |
NEPA
2006
Try it out and see.. No harm in that, takes 5 minutes and you'll answer your own question.
I'd guess it's the GPS antenna though, since that would be something needed for the navigation, along with your regular connections? |
#4 | |
Bear Gap, PA
'97 XLT
Quote:
=Vic= |
#5 |
Toronto, Ontario
2004 CTS-V, 2008 X LTD V8
GPS antenna is the pink circle connector
__________________ 2004 Cadillac CTS-V - 222/226 cam, Z06 FRCs, B&B LT headers, cats, X-pipe, mufflers Hotchkis swaybars, gForce axles, etc. 2009 Cadillac CTS 3.6 DI 2004 Cadillac CTS 3.6 2013 GMC Yukon Denali |
#6 |
NJ
2006 Explorer
I was told by Ford serv dept, that since I have Sirius now with my single cd/mp3, and the Sirius antenna is on the roof already, that the factory gps uses the same antenna.
Is that so? |
#7 |
Bear Gap, PA
'97 XLT
I understand that the satellite radio and GPS do use the same antenna. Not sure what the connector arrangement is for that to supply to the GPS, though.
=Vic= |
#8 |
Minneapolis, MN
'06 XLS
That is incorrect. the "unit" is 1, but the actual antenna's are seperate.
#9 |
Bear Gap, PA
'97 XLT
According to the service manual, regarding removal/installation of the roof-mounted GPS antenna:
"This procedure is the same as the satellite radio antenna procedure, as a combination satellite radio/GPS is utilized for vehicles with navigation." The only cable routing I saw was for the satellite antenna, though. It seems to use the same connector in the a-pillar, but appears to terminate in the satellite received in the passenger sidewall. Nothing is shown going to the GPS connector on the back of the radio, so as I said, not sure how that is routed. Either the signal is provided through the satellite receiver harness, or perhaps you can include a separate antenna somewhere. Mounting a separate antenna under the dash probably won't work if you have the electronic windshield defrost option. =Vic= |
#10 | |
Toronto, Ontario
Quote:
One is for Sirius only. The other is Sirius and GPS. You will need to replace yours with the latter. That's what I had to do. __________________ 2004 Cadillac CTS-V - 222/226 cam, Z06 FRCs, B&B LT headers, cats, X-pipe, mufflers Hotchkis swaybars, gForce axles, etc. 2009 Cadillac CTS 3.6 DI 2004 Cadillac CTS 3.6 2013 GMC Yukon Denali |
| Thread Tools | |
