#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
2001 SPORT TRAC engine swap: you use a standard 4.0 explorer engine?
Reply
Thread Tools
Old 07-13-2010, 02:02 PM   #1
polhovsky
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I just purchased a 01 Ford Explorer with a "seized" engine. Prior to purchasing I thought it would be an easy swap, because the EXP 4.0 motors are a dime a dozen. HOWEVER, I am not sure the the EXPLORER 4.0 and EXPLORER SPORT TRAC 4.0 have the same engine? Is this correct? Can a SPORT TRAC take a standard EXP motor. If not, what are the limitations? I have seen a lot of motors on Ebay, stipulating 01 4.0 motor VIN "E", EXCEPT sport trac. Is this correct. Does anyone have any knowledge on this and has anyone tried this? Please send some answers/ideas.
polhovsky is offline   Reply With Quote
( Join the Elite Explorers )
Old 07-13-2010, 04:03 PM   #2
matdap
va
2001 sport trac
Vehicle Specs
Quoted: 0 Post(s)
there was a job 1 and job 2 sport trac in 2001 with some minor changes in the 4.0, not sure if there is electrical hook up changes in the two but the pvc valve is changed, the oil fill is on the other side. So I think you might need to see which one you have.
matdap is offline   Reply With Quote
Old 07-13-2010, 05:33 PM   #3
ncranchero
Co-moderator
Denver,NC
ncranchero's Avatar
'94 F150 4x4 SWB 4.9L
Vehicle Specs
Quoted: 27 Post(s)
Check the door sticker and post the date of manufacture. Where are you located? Any where near NC? I have an '01 Job 2 motor.
__________________
'14 Transit Connect 2.5L 16 Valve DOHC Duratec
'02 Escape XLT 3.0L 24 Valve DOHC Duratec 160k
'94 F150 4x4 4.9L/5-speed 160K miles,
How to post photos
ncranchero is offline   Reply With Quote
Old 07-13-2010, 11:25 PM   #4
JohnnyO
Moderator Emeritus
Pittsburgh, PA
JohnnyO's Avatar
'08 Sport Trac
Vehicle Specs
Quoted: 13 Post(s)
It depends. Earlier Explorers have a 4.0 OHV engine and later ones have a 4.0 SOHC and for a few years you could get both. All '01-'05 Sport Tracs have the 4.0 SOHC engine.
__________________
'08 Sport Trac, Gibson exhaust, Firestone Destination A/T's, Steelers swag.
"It is not the multitude of ale-houses that occasions a general disposition to drunkenness among the common people; but that disposition arising from other causes necessarily gives employment to a multitude of ale-houses." -- Adam Smith, 1776
JohnnyO is offline   Reply With Quote
Old 02-19-2013, 12:51 AM   #5
SteFin
nashville tn
99 Explorer
Vehicle Specs
Quoted: 1 Post(s)
I have an 02 Explorer 4.0 SOHC donor engine low milage ran good, I'm putting in a 01 Sport that had a bad SOHC 4.0 engine. Can I use my 01 wiring harness on the 02 engine? The 02 engine wiring harness was cut up too bad to use. Anyone know where the 02 and 01 differ? Thanks Stefin
SteFin is offline   Reply With Quote
Old 02-19-2013, 01:58 PM   #6
05dakotatrac
Ellsworth AFB, SD
05 sport trac 4X4
Vehicle Specs
Quoted: 17 Post(s)
01 had a cut off in july for job 1 vs. job 2. job 2 has passenger side oil fill and job 1 is on drivers side. thats the easiest way to tell the difference.
__________________
Mike Lyons, USAF active duty
05 sport trac: 4X4, 3.73 LSD, 2" TT/add a leaf, 265/75R16 MT, 1.25" spacers, Henson X-cal3, hunter running boards (not nerfs), ZAPV #26
05dakotatrac is offline   Reply With Quote
Old 02-19-2013, 02:06 PM   #7
SteFin
nashville tn
99 Explorer
Vehicle Specs
Quoted: 1 Post(s)
Will the 02 4.0 Sohc engine fit as a plug and play into the 2001 Sport?
Old 02-19-2013, 04:25 PM   #8
05dakotatrac
Ellsworth AFB, SD
05 sport trac 4X4
Vehicle Specs
Quoted: 17 Post(s)
as long as your 01 has the job 2 it should
__________________
Reply
Tags
sport trac engine, sport trac engine swap, sport trac removal
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
