Aircon Fan Fix | Ford Explorer Forums
Aircon Fan Fix
jcasey007
Stratford Upon Avon, Warwickshire
Jeep Commander 5.7L HEMI
You know the symptoms, the aircon fan will only work on very slow or full speed.:(
The fix is to replace the resistor unit located under the aircon fan unit.
Problem is I've done this 3 times this year, replacing with good second hand units as no new ones are available in the UK.
I've kept all the ones I've removed and the thought of skinning my knuckles again tomorrow changing it, got me thinking.
"which part of this simple assembly is failing"? so I started looking at the replacement ones (thanks Chris) and the three 'broken ones' I've kept.
When you actually look closly at these assemblies all they consist of is three coils of resistance wire (very low resistance) and a fuse link.
None of them had burnt out coils or a blown fuse and then I found the common problem.
All of them had corrosion on the wiring socket terminals, you can't see very well because of the plastic housing. So I set about refurbising a couple.
By the way you can tell if the resistance coils are shot, use a digital ohm meter, across the three different coils and you should get 2.2 ohms, 2.9 ohms and 3.1 ohms.
So the refurb.
Step one - Carefully drill out the two rivets that hold the plastic socket to the back-plate this is what you see. Note the corrosion on all the terminals. The one in the middle is always the worst.
Step two - Use a small fine grinding wheel (no bigger than 5mm diametre) from a dremmel , carfully grind and polish each side of each connection until you see bright metal as in Picture two.
Step three - Pop rivet the plastic cover back on to the base plate, total time - 10 mins a unit, good as new if fact so good I did all of my broken ones.:D
A few years ago I built a home nickle electric plating set for replating these typs of components, I wish I still had it.
cheers
Jim
Nice write up Jim.
A photo speaks a thousand words.
Kev.
to save your knuckles cut a access hole in the plastic under wing shield and fit a cover then if it goes again you can get to it easily. also apply grease to terminals as they sit right under the water/ condensation outlet from heater motor. cheers chris
