EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
4r55e shifting problem
Reply
Thread Tools
Old 07-19-2010, 09:58 AM   #1
bmisch
northern wet virginia
1996 xlt /1997xlt
Vehicle Specs
(Original Poster)
Roll 4r55e shifting problem
just rebuilt 4r55e in my 96 ex. now its won't shift out of first unless you let up on the throttle shifts into thre other gears just fine it seems to down shift ok , just hard shifting out of first
bmisch is offline   Reply With Quote
Old 07-20-2010, 09:02 AM   #2
PopRichie77
Quakertown, PA
1999 Explorer XLT 4X4
Vehicle Specs
Did you have the valve body apart?
PopRichie77 is offline   Reply With Quote
Old 07-20-2010, 11:55 AM   #3
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Check the bands. It sounds like you have a broken band.
BrooklynBay is offline   Reply With Quote
Old 07-21-2010, 08:38 AM   #4
bmisch
1996 xlt /1997xlt
Vehicle Specs
(Original Poster)
i INSTALLED NEW SEP. PLATE & GASKETS & BLOW OFF VALVE , READJUSTED BANDS, IT SEEMS TO SHIFT FINE NOW ,BUT , NOW HAVE A CODE FOR SHIFT SOLENOID C STUCK
Old 07-21-2010, 08:46 AM   #5
BrooklynBay
Brooklyn, NY
Vehicle Specs
What's the code number? Did you use a torque wrench to adjust the bands, and tighten the valve body bolts?
Old 07-21-2010, 09:47 AM   #6
bmisch
1996 xlt /1997xlt
Vehicle Specs
(Original Poster)
yes vb bolts tightened to specs, & bands to 10 inch lbs 1 1/2 turns out, are shift solenoids in a 5r55e the same as 4r55e
Old 07-21-2010, 09:53 AM   #7
MBeaston
Dunkirk, MD
95 Explorer XLT 4X4
Vehicle Specs
Quote:
I personally had the same problem with one of my explorers befor and it turned out to be the servo piston for the band was seized up because where the heat shield is for the exhaust is right over the servo pistons and it causes them to get hot and harden up... my advise would be to check your servo pistons for signs of cracking or hardening and if found to replace them... you can get them for around 15 usd each
__________________
1995 Exploder XLT
MBeaston is offline   Reply With Quote
Old 07-21-2010, 09:55 AM   #8
BrooklynBay
Brooklyn, NY
Vehicle Specs
# 4 in my list of useful threads has the specifications for the band adjustment: http://www.explorerforum.com/forums/...d.php?t=158160
Old 04-08-2012, 09:37 AM   #9
LV_PRERUNNER
henderson nv
Ford Ranger
Vehicle Specs
I know this is old!!!
i really need to know what you ended up fixing that was the problem....was it the solenoid or bands or etc.... this same thing happened to my ranger and my obd2 wont read at all ...please help
LV_PRERUNNER is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
