| Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well. |
Thread Tools |
#1 |
Wannabe Elite Explorer
ontario
Ranger XLT 96
96 Ranger - Where do I start with fixing these codes
Hey Everyone!
Just looking for some suggestions on where to start trying to fix the following codes. I should point out that I'm pretty sure I'm experiencing a misfire as the truck shakes a lot and when I initially start up. Also (probably related to one of the codes) when I first start up the truck I give it gas but get no response from the engine (as if there are no gears) the first few times I give it gas, but then it goes back to normal... It's as if the vaccum or the fuel injection isn't working... I'll put my foot on the gas... nothing, then it will get some gas and go, then nothing then get some gas and go, repeat... Hopefully this makes sense. And hopefully you all can suggest how I should attack these codes, as in what order, etc? Any details would be very helpful! P1443 - Evaporative Emission System Control Valve (low/no flow) --I wonder if this explains the fuel injection problem i get when first starting the truck. Could it by my after market gas cap? P0136 - O2 circuit (Bank 1 sensor 2) (see P2270, P2271) P0141 - O2 Heater Circuit (Bank 1 Sensor 2) --after a visual inspection it looks like the top have popped off where the wire goes into the sensor, so I'm planning to replace. Question. The stock O2 sensor doesn't have a plug like 10 inches away from the sensor like the after market one does... how do I plug the new one into the wire that comes from the ECM to the sensor? do i need to put a plug on that wire somehow? P0401 - Exhaust Gas Recirculation A Flow Insufficient Detected --no idea about his one, maybe due to having that bad o2 sensor and now the cat isn't working properly? i'm guessing. P1000 - OBD Systems Readiness Test Not Complete -- i've read that this is because I unhooked the battery and will go away P0741 - Torque Converter Clutch Solenoid Circuit Performance/Stuck Off -- i wonder if this explains the flashing o/d light that comes on periodically and seems to come on i've been driving for a while and after I've accelerated then took my foot off the gas (coasting) Wow another novel, sorry about that guys... As you can see it's an up hill battle with my 96 3.0L XLT 2wd 236,121miles Please help. Thanks! |
#2 |
ontario
Ranger XLT 96
Oh I should also mention that there's a hold in the muffler at the moment and the truck has failed it's emissions test.
I'm starting to think I should start with a compression test?? What do you all think? |
#3 |
ontario
Ranger XLT 96
Performed a compression test and found couple bad cylinders. Took it to the machine shop and they sad that the exhaust value seats needed to be fixed/replaced/reseated.
So this might explain a few of the codes. So I'm thinking once I get the engine back together, replace the muffler, and O2 sensor... Then clear the codes and see if anything comes back? Good idea? What do you guys think? Should I replace the TCC solenoid while I'm at it? Or could that and the other codes all be related to my engine problems? Thanks in advance for all your help! |
#4 | |||||
Michigan
03 Ranger FX4 LII 5.0 S/C
Quote:
Quote:
Quote:
Quote:
Quote:
__________________ Bob 2003 Ranger FX4 Level II, 5.0L V8, 4R70W, BW4406 T/C, Aussie Locker front, Torsen rear Torque Monsters, Magnaflow, duals; Explorer EATC, steering wheel controls, consoles Bilstein 7100 reservoir shocks, Cadillac/Mustang SVO rear discs, Duff traction bars CarDomain Ford owners' manuals ONLINE, then click on "Glovebox" |
#5 |
ontario
Ranger XLT 96
thanks for the response rwnezing!
Very helpful response, in fact I've been able to fix all the codes with the exception of the transmission related codes. Here's how I fixed these. O2 codes = replace post cat O2 sensor = fixed EVAP codes = replaced rubber cracked hoses with new ones = fixed EGR = replaced DPFE sensor with one from wreckers = fixed As for the transmission code... A new TCC solenoid is WAY too expensive, so I'm trying to find a cheaper alternative. I'm also getting another code to go along with it. P0760 - shift solenoid c performance or stuck off I've cleared the codes several times, but it keeps coming back... I have to drive it for 5-10miles before the o/d light starts flashing, which makes me think it's a heat issue. Anyone have any ideas? TTC ? EPC? Please help... Time to start searching this site for more info. Thanks in advance! |
| Thread Tools | |
