Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
Explorer ring & pinion question.
Reply
Thread Tools
Old 07-31-2010, 02:19 AM   #1
t.r.c
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hello, i've been doing some research and cant find the answers i'm looking for. I have a 98 explorer sport, and i found a great deal on some 4.10 gears out of a 2001 ranger, but i know the ranger 8.8's are only 28 spline, so my question is, will they work in my explorer? Thanks for any help, and a speedy response would be greatly appreciated.
t.r.c is offline   Reply With Quote
( Join the Elite Explorers )
Old 07-31-2010, 06:32 AM   #2
PopRichie77
Quakertown, PA
2001 Explorer Sport 4X4
Vehicle Specs
Quoted: 24 Post(s)
If you don't get an answer, pull an axle and count the number of splines, then you are sure.
PopRichie77 is offline   Reply With Quote
Old 07-31-2010, 08:32 AM   #3
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
It wont work - the axle shafts wont slide into the carrier and w/o the axle shafts, your vehicle isn't going anywhere. You can swap the entire axle but I think that requires some fabrication because of the difference in spring location (mounting width and SOA vs SUA).
__________________
...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 07-31-2010, 08:40 AM   #4
Albino 94LTD
Preparing for Moab 2016
Newcastle Wa
Albino 94LTD's Avatar
White 94 Limited
Vehicle Specs
Quoted: 83 Post(s)
Why can't he just swap the ring and pinion onto the carrier in the axel in his truck?
I can't think of a reason.
For that matter, he could swap everything except the housing.
__________________
KG7PKQ
The Crumudgeon
Some engine thingy's, some suspension thingy's, some interior thingy's
and some thingy's powder coated by Turdle Shell Powder Coating
I've been busy
Albino 94LTD is offline   Reply With Quote
Old 07-31-2010, 08:58 AM   #5
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
Youre correct - you can use the ring and pinion. I was talking about the carrier - which the original poster didn't even mention - doh!
__________________
Reply
Tags
4.10, explorer, gears, pinion, ranger
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
