Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
"97 SOHC Timing Chain Rattle Repair"
Reply
Thread Tools
Old 07-25-2010, 08:06 AM   #1
steadyhand
Missouri
99 Mercury Mountaineer
Vehicle Specs
(Original Poster)
First off I can't thank you enough for posting this information. I saved this thread so that I can read over it again and look at the pictures several times so I know what I'm looking at ahead of time.
Started several weeks ago I noticed a rattling sound from my 97 Explorer 4.0 V6, Auto, 4WD. At first it wasn't all that bad and it sounded like an exhaust rattle, except the sound appeared to be coming from the driver side exhaust manifold. Just a couple days ago I noticed after the truck had set and idled for about 15 minutes the rattle was starting to get really loud. If I reved up the engine the noise would quit. I assume it was oil pressure building and the chain was tightening up.
The noise definately sounds like it is coming from the driver side area, maybe under or behind the EGR.
It looks like I am going to have no choice but to pull the intake manifold off and take a look at the tensioner for the driver side. From the looks of the picture you posted, I should be able to view the plastic guide as well. If the guide is broke or all chewed up then I guess I have no choice but to tear down the front of the engine. Otherwise I will replace the tensioner only and see IF that fixes the problem.
_____________
Right now the engine is running fine, except for the rattle which only happens at certain times.
IF I have to tear down the engine and replace the tensioners, guides, etc. do I have to remove the chains to do this? Since the engine is running fine right now, and thus the timing hasn't taken a walk on me yet, it would be great if I could leave the chains on to avoid having to reset the timing. Can I just replace the guides and tensioners?
If not, is it true I have to have special tools to reset the timing? If I do have to reset the timing, does the engine have to come out in order to use the special tools to set the timing? I hate the idea of having to pull the engine out just to reset timing. If I had to do that I might as well rebuild the whole engine.
I've always liked Ford vehicles, but when it comes to the timing on this engine Ford needs a good kick in the rear end.
steadyhand is offline   Reply With Quote
Old 07-25-2010, 09:19 AM   #2
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
2000 Sport SOHC 2WD
Vehicle Specs
about timing chain issues
I don't have time to respond properly right now but the following link may help:
SOHC V6 timing chain comments
You'll have to remove the valve cover to inspect the left timing chain guide assembly.
You can replace the left guide assembly without retiming but it is very risky. I've been discussing it with another member who will attempt soon. There's a thread about it I'll post a link to later.
__________________
My Helpful Threads, Registry, 16.4/23 mpg, 3900 lbs, 5R55E, 3.73:1, 175 rwhp, Henson custom tune, CAI, Spectre air filter, Lightning 90mm MAF, 75mm throttle body, A/F ratio meter, synthetic oils, Accusump, 2 row radiator, 3+1 leaf springs, .75 inch drop, Edelbrock IAS lowering shocks, engine oil & ATF temp gauge & remote filters & coolers, remote crank
2000StreetRod is online now   Reply With Quote
Old 07-25-2010, 03:30 PM   #3
2000StreetRod
Greenville, SC
2000 Sport SOHC 2WD
Vehicle Specs
guide replacement - no retiming
Since you have to remove the upper intake manifold to replace the left hydraulic tensioner, it won't cost you anything but time to remove the left valve cover and inspect the guide assembly.
Below is the link to the thread that describes replacing the primary tensioner and guide as well as the left guide assembly without retiming the camshafts. I emphasize that this is a risky process and I recommend at least checking the timing once complete before cranking or running the engine.
Timing Chain Pictures!?!
If your 1997 SOHC still has the original timing components then there is a good chance that the left guide assembly and the primary tensioner are broken.
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
