Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Soft Brakes???
Reply
Thread Tools
Old 08-01-2010, 01:50 PM   #1
erald01
canton, mi
1998 Explorer 5.0
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Soft Brakes???
Okay so i have been doing some major naintnance on my 1998 5.0 EB edition explorer. My rear brakes were starting to make noisy so i figured i would change the pads and the rotors. Changed the rotors and the pads, and when i started to drive the truck i noticed the break pedal is very soft and to break the pedal has to travel pretty far. I didnt do anything else but change the brakes, i tried bleedin them but no luck since the bleedin nipples are seized. I have no leaks because i checked the fluid every day for a week and it's still the same level.
How do you guys bleed ur brakes when the bleeding nipples are seized?? Why my brakes feels soft, could be a bad caliper somewhere in the back?? Btw the truck has 156,000 miles. Any tip is apprecited, thanx
erald01 is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-01-2010, 03:58 PM   #2
safn1949
Mankato, Minnesota
M60A1 my first offroader
Vehicle Specs
Quoted: 2 Post(s)
Ok,it could be a caliper piston is stuck and here is how you find out which side.Get a pair of vise grips and gently clamp off one rubber brake line in the rear,be careful as you can easily damage the lines.
Now try your brakes,if they are solid now then you have a problem with the caliper or (extremely rare) the wrong brake pads.Try one side at a time to see if it makes a difference.
The brake pad thing I have seen once in my time,some dope put the wrong pads on his Honda and the brakes were soft,he brought it to us and we did the above only to find the pads would not move in the caliper so they simply bent and sprang back when the brake was applied.
__________________
1994 XLT,4.0,3.73 LS
149,000 miles.
Need a Panasonic Toughbook? I have them,email me for details.
safn1949 is offline   Reply With Quote
Old 08-01-2010, 05:14 PM   #3
erald01
canton, mi
1998 Explorer 5.0
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
k thanx ill def try that, as for pads i know its the right ones lol...what about if there is air in the lines, how can i loosen up the bleedin nipples?
Old 08-01-2010, 08:33 PM   #4
Mbrooks420
High Voltage.
Erie, Pennsylvania
Mbrooks420's Avatar
1998 Mountaineer
Vehicle Specs
Quoted: 2 Post(s)
Spray the bleeders with wd-40 for a few days. Then apply some heat. Use the proper 6 pt socket, and you will probably be able to break them free. You can also heat, and spray with wd-40, or PB Blaster. Sometimes the heat helps wick in the penetrating oil.
__________________
1998 Mounty 5.0 AWD TT/Shackles/rear AirLift springs 31x10.5 Kelly TSR's
1995 Subaru Legacy AWD Sedan RIP---Killed by an suicidal deer
1972 El Camino---Project Dirty Old Chevy---Fresh Marine Longblock .060 over, Forged crank RV Cam 454/th400 swap, Hooker Headers, fresh coat of white
1999 KTM 300exc RaceTech Suspension, Rekluse Slipper Clutch, single track killer
Mbrooks420 is offline   Reply With Quote
Old 08-01-2010, 08:38 PM   #5
safn1949
Mankato, Minnesota
Vehicle Specs
Quoted: 2 Post(s)
If it's air and the bleeder breaks,just go get a rebuilt caliper.I wouldn't think they would cost that much.
__________________
149,000 miles.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
