Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
torquing heads
Reply
Thread Tools
Old 08-08-2010, 12:16 AM   #1
thomas.baker
cullman alabama
93 eddie bauer
Vehicle Specs
(Original Poster)
torquing heads
could someone please explain and tell me exactly how to "tork" the head bolts
thomas.baker is offline   Reply With Quote
Old 08-09-2010, 05:31 PM   #2
thomas.baker
cullman alabama
93 eddie bauer
Vehicle Specs
(Original Poster)
bump cmon schools about to start and i need some transportation
Old 08-09-2010, 05:34 PM   #3
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Your going to need the book to get the torque specs (I don't have them memorized) but you alternate tightening the head bolts and the intake (lower) manifold bolts. The Final step of the head bolts is actually not done with a torque wrench. The final is you put on the wrench (breaker bar works well) and you then turn it 80-85 degrees. Thats a little less than 1/4 a turn.
They do make a special wrench with an indicator to tell you when you got to 80 degrees but its not worth buying.
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is online now   Reply With Quote
Old 08-09-2010, 05:37 PM   #4
Turdle
Old and in the way
Humboldt, Kansas
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quote:
Originally Posted by Maniak View Post
Your going to need the book to get the torque specs (I don't have them memorized) but you alternate tightening the head bolts and the intake (lower) manifold bolts. The Final step of the head bolts is actually not done with a torque wrench. The final is you put on the wrench (breaker bar works well) and you then turn it 80-85 degrees. Thats a little less than 1/2 a turn.
~Mark
Not jumping on you mark, but don't you mean <1/4 turn?
90 degrees is 1/4 turn. 360 is one turn.
__________________
Jon
2000 Mountaineer
Turdle-gone
Vitamin D Wagon Sold also
Turdle is offline   Reply With Quote
Old 08-09-2010, 05:39 PM   #5
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Fixed. wierd. As I typed it I knew I was typing 1/2 and knew I had to change what I was typing to 1/4 turn as I was typing and then never did. See what happens when you try to answer a thread on EF while you have a 30 second pause in testing the code you just wrote
~Mark
__________________
Old 08-09-2010, 05:52 PM   #6
Turdle
Old and in the way
Humboldt, Kansas
Turdle's Avatar
2000 Mounty
Vehicle Specs
Then We should delete these silly posts huh?
or we could go back on track and throw in a video
http://www.wonderhowto.com/how-to-us...wrench-280581/
__________________
Jon
2000 Mountaineer
Turdle-gone
Old 08-09-2010, 05:55 PM   #7
YBCold
702 LΛ§ V£GΛ§ NV / МØΠΤΣΓΓΣΨ ΜΧ
91 ×∟┬
Vehicle Specs
i got a schematic i will upload in a bit lemme find it...
__________________
http://www.youtube.com/user/unaffiliatedperson
---)()(MUGSHOT()(---
All I wanted was a pepsi, just one pepsi! and she wouldnt give it to me just a pepsi!
YBCold is offline   Reply With Quote
Old 08-09-2010, 06:03 PM   #8
YBCold
91 ×∟┬
Vehicle Specs
thsts the sequence. also got the AZ online repair guide and haynes book for more info
__________________
Old 08-09-2010, 06:18 PM   #9
Explorer Junky
Grand Rapids, Mi
1997 XLT 4 dr 5.0
Vehicle Specs
Quote:
If thats the sequence, then why is Maniak talking about including the lower intake? I have never heard of including the lower before, just the head bolts!
Explorer Junky is offline   Reply With Quote
Old 08-09-2010, 06:32 PM   #10
YBCold
91 ×∟┬
Vehicle Specs
the lower intake is important because the coolant feed throught the lowerintake and it has a mating surface with the heads and a gasket. so it too needs to be torqued in a sequence
__________________
Old 08-09-2010, 06:36 PM   #11
Explorer Junky
Grand Rapids, Mi
1997 XLT 4 dr 5.0
Vehicle Specs
I understand that. But AFTER you torque the heads on right? NOT during!
Old 08-09-2010, 06:36 PM   #12
YBCold
91 ×∟┬
Vehicle Specs
only my haynes book has the tighning sequence hope the pic my cell phone camera took is good enough. hold up lemme uplaod to photobucket
__________________
Old 08-09-2010, 06:37 PM   #13
YBCold
91 ×∟┬
Vehicle Specs
im not sure yet. coz my book says something bout the sealent drying quickly. so probly at the same time. im pretty sure.
__________________
Old 08-09-2010, 06:41 PM   #14
YBCold
91 ×∟┬
Vehicle Specs
yup hand tight, then put the rtv and gasket for intake , then hand tight, then alternately and in sequence do the manifold and heads.
__________________
Old 08-09-2010, 06:43 PM   #15
YBCold
91 ×∟┬
Vehicle Specs
left side of the picture i think is the front of the car
__________________
Old 08-09-2010, 07:14 PM   #16
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Ill dig up where it says both. Basically you make a head bolt pass then intake then head bolt etc.
I cant remember if it was the fsm or chiltons where i first read that.
~Mark
__________________
Old 08-09-2010, 08:00 PM   #17
YBCold
91 ×∟┬
Vehicle Specs
i have the haynes . i will see if i can find a scanner or just transpose verbatim when i have the time i figure
__________________
Old 08-09-2010, 09:57 PM   #18
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
From the "instructions" in the chiltons....
~Mark
__________________
Old 08-09-2010, 10:24 PM   #19
Explorer Junky
Grand Rapids, Mi
1997 XLT 4 dr 5.0
Vehicle Specs
~Mark
You are blowing my mind!! Do you have a picture of what they consider the "mating joints"?
Old 08-09-2010, 10:41 PM   #20
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
I use "right stuff" (rtv type stuff, but better) on the china wall in front and back. Thats the "wall" type thing that is on the block that runs from head to head.
By mating surface, I think they are telling you to make sure you put RTV at the joint where the head/block and intake will all meet.
~Mark
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
