Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Ranger - Mazda B-Series Forum > Ford Ranger - Mazda B-Series Forum
Notices
Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well.
TPS test procedure on a 1995 Ford Ranger.
Reply
Thread Tools
Old 08-13-2010, 08:50 AM   #1
deacporter
Victoria, TX
95 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Question TPS test procedure on a 1995 Ford Ranger.
Hello this is James from Texas. I have a 1995 Ford Ranger XLT and want to test the TPS. I found the procedure for testing the Explorer TPS and am wondering if this applies to my Ranger as well. With the throttle closed the reading was 2 volts. With it wide open it exceeded 10 volts. While going from closed to WO the voltage did increase smoothly. Can someone tell me what the value should be?
deacporter is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-13-2010, 10:35 AM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 426 Post(s)
Welcome to this forum! I've moved your thread into the Ranger section. The test procedure should be the same. Move the sweep very slowly to see if there are dead spots.
BrooklynBay is offline   Reply With Quote
Old 08-13-2010, 01:26 PM   #3
deacporter
Victoria, TX
95 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Unhappy TPS Test for 1995 Ford Ranger
I performed the test and as previuosly stated the voltage moved smoothly up and down with no drop outs. The only thing was the voltage readings were higher than stated in the test procedure listed. Is this ok?
Old 08-13-2010, 05:01 PM   #4
rwenzing
Michigan
03 Ranger FX4 LII 5.0 S/C
Vehicle Specs
Quoted: 2 Post(s)
There is no way that the TPS sensor voltage going to the PCM should be outside of 0 ~ 5V because the PCM supplies it with 0v ground and 5V reference.
Typical readings:
Closed throttle: 0.53~1.27v (usually near 1.0v)
Wide open throttle: 4.0~4.8v (usually around 4.5v)
Are you testing the TPS when it is fully connected in the vehicle or are you supplying it artificially with ~12V? It should be checked between the gray/white to the gray/green with everything connected normally and the ignition turned on.
__________________
Bob
2003 Ranger FX4 Level II, 5.0L V8, 4R70W, BW4406 T/C, Aussie Locker front, Torsen rear
Torque Monsters, Magnaflow, duals; Explorer EATC, steering wheel controls, consoles
Bilstein 7100 reservoir shocks, Cadillac/Mustang SVO rear discs, Duff traction bars
rwenzing is offline   Reply With Quote
Old 08-14-2010, 09:09 AM   #5
deacporter
Victoria, TX
95 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I double-checked everything and this is what I get.
Old 08-14-2010, 09:33 AM   #6
rwenzing
Michigan
Vehicle Specs
Quoted: 2 Post(s)
With the TPS unplugged and the ignition on, what is the voltage across the brown/white and the gray/red at the TPS harness connector?
__________________
Bob
Old 08-14-2010, 09:44 PM   #7
deacporter
Victoria, TX
95 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
The voltage is zero.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
