Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
water pump relacement 98 4.0 sohc
Reply
Thread Tools
Old 08-14-2010, 01:32 PM   #1
rainbow9
avon new york
98 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US water pump relacement 98 4.0 sohc
Hello again , I am going to attempt a water pump relacement on my 98 explorer with a 4.0 sohc..240,000 miles. It leaking from around the pump gasket from what I can see. The truck runs hot under load but temp is good any other time.
There is a thread with pics and step by step but it look like a 96 explorer w/V6 not sohcV6 like mine..any difference in the procedure??
Any tips or other step by steps in here to help out. I simply can't afford a shop right now. I have done some tough repairs on this truck, it still runs great, tranny good,motor has very little Mobil 1 syn burning off yet
Thanks alot!!!
rainbow9 is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-15-2010, 08:29 AM   #2
rainbow9
avon new york
98 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hi again . I was reading about a water pump "weep hole". could it be leaking from this hole because the thermostat is stuck ??
Thanks hoipng for a response
Old 08-15-2010, 09:14 AM   #3
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
weep hole
water that leaks past the bearing seal escapes via the weep hole. If it is leaking then the pump needs to be replaced.
Be careful with anything attached to the thermostat housing. It is made of plastic, cracks easily, and is expensive to replace.
You will need the Ford tool to loosen the viscous fan clutch nut. They are available at most local auto parts shops. The big nut loosens counter-clockwise.
2000StreetRod is offline   Reply With Quote
Old 08-15-2010, 09:25 AM   #4
Xplorer82
OH.
'97 XLT... '98 Eddie...
Vehicle Specs
Quoted: 1 Post(s)
Thanks alot!!!
the water pump is pretty easy to replace. my first tip would be to buy a prestone back flush kit($7.00), install it and back flush the system out via the directions on the box (if you never done it before). that way all the crap gets thrown through the old water pump and not the new one.. you will need the fan clutch set as 2000streetrod stated above and/or make your own version of them for future removal.
with that being said, here is the thread i followed to do my water pump.
http://www.explorerforum.com/forums/...r+pump+removal
remember back flush the system out (and reserve tank as well) before you start the process.
edit...... another tip, cover the Knock sensor with some rags before you unbolt the water pump otherwise it will get a coolant soaked bath. and of course plug the holes and wire wheel the block off where the new gasket is going to go. i cleaned mine w/acetone before applying the gasket sealant to make sure it got the best hold.
if i think of more i'll be back.
__________________
┌П┐(-_-)┌П┐
'98 Eddie Bauer. 4x4, 4.0L SOHC. 190k miles and counting, Flowmaster 50 series, Amsoil Ea air filter, 31x10.5" Sumitomo All-Terrain & the dreaded rattle.
R.I.P : '97 XLT - it was a good 8yrs..
Xplorer82 is offline   Reply With Quote
Old 08-16-2010, 06:41 PM   #5
rainbow9
avon new york
98 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
wow, Thanks for all the tips!!!
I am definetly going for it, just waiting on another car so I can pull this hog into the garage and get busy.
This board is the best, I'll check back in when I get her fixed up
Old 08-16-2010, 08:08 PM   #6
vegasjoe1969
Las Vegas, Nevada
vegasjoe1969's Avatar
95 XLT
Vehicle Specs
Quoted: 0 Post(s)
You can also use the oil filter removal tool made of rubber traps to hold the pulley, make sure to get the largest one.....
http://www.harborfreight.com/2-piece...set-94119.html
it is easier to use than the 2-piece tool that 2000streetrod mentioned, as far as I experienced it since I just did the same thing 10 days ago....
vegasjoe1969 is offline   Reply With Quote
Old 08-16-2010, 10:29 PM   #7
Xplorer82
OH.
Vehicle Specs
Quoted: 1 Post(s)
not a problem
one thing i forgot to mention about installing the back flush kit "T" is to drain the coolant before you cut into the hose mentioned in the directions on the back of the box. otherwise once you cut that line, coolant will be everywhere. then proceed with the back flush followed by the water pump removal.
and be careful to not hit the radiator to hard with your tools. i ended up w/a few dings, nothing major.
__________________
┌П┐(-_-)┌П┐
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
