#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Explorer cuts off when idling
Reply
Thread Tools
Old 08-17-2010, 11:15 AM   #1
osiris_9510
Fayetteville, NC
2001 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Red Exp Explorer cuts off when idling
Hey everyone
I have a 2001 Ford Explorer (XLT, V6 SOHC 2WD, 151K miles) that just cuts off when idling. It won't always do this, I'd say 1 out of 10 stoplights. And when it does cut off, its a pain in the *** to get it to crank up again. The engine will turn over, but it seems as if its not getting fuel. One day I nearly killed the battery trying to get it to start up again, thankfully it finally started again. I never run it low on fuel, there's always at least a 1/4 tank. It idles at around 800-1000RPMs. I have noticed that just before (1-2 seconds before) it sputters just a little bit. And if I slam the gas pedal down (I only do this in the parking lot while its in park) it won't cut off. Check engine light does not come in, though it did before the tune up.
I have (in this order):
Run 2 cans of injector cleaner through it
Tuned it up (spark plugs and wires, good ones, it was missing a little bit anyway. Check Engine light would come on once a week)
Replaced coil pack
Replaced fuel filter
I'm no mechanic, but a few people have told me it could be a hose. So, I looked for a loose vacuum hose but I can't find anything that's loose or disconnected. Can someone tell me where to look for a hose that could be causing the problem? Could it be a problem with the intake? I thought it could be an injector or sensor but surely a light would come on if it were one of those. Any other ideas?
osiris_9510 is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-17-2010, 06:09 PM   #2
SoNic67
Newport News, VA
2001 V8 (Eddie Bauer) AWD
Vehicle Specs
Quoted: 456 Post(s)
If pressing the gas pedal keeps it running, replace the IAC valve. Two screws and a conenctor, located on the top of the engine.
If that is not helping, try to replace the gas filter (you need a special too for that).
SoNic67 is offline   Reply With Quote
Old 08-18-2010, 09:31 AM   #3
osiris_9510
Fayetteville, NC
2001 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thank you for the reply. I have already replaced the fuel filter.
If it were a bad IAC valve wouldn't the Check Engine light come on?
Old 08-18-2010, 11:59 AM   #4
Joe Dirt
Joe Dirt's Avatar
07 Camry
Vehicle Specs
Quoted: 6 Post(s)
Bad sensors do not always trip CEL's...
__________________
If we confess our sins, He is faithful and just and will forgive us our sins and purify us from all unrighteousness. 1 John 1:9
Joe Dirt is offline   Reply With Quote
Old 08-19-2010, 07:28 PM   #5
SoNic67
Newport News, VA
Vehicle Specs
Quoted: 456 Post(s)
Quote:
On mine didn't. I was 42$.
Old 08-20-2010, 11:47 AM   #6
osiris_9510
Fayetteville, NC
2001 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks guys, will try this weekend. Getting tired of driving the wife's car with the kitty license plate on the front.....
Old 09-02-2010, 04:42 PM   #7
osiris_9510
Fayetteville, NC
2001 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Well, it's fixed, sort of....
Its not cutting off any more (on its own), but if I park it and cut it off, 1 time out of 5 it won't start up again. I can smell fuel vapors, so I know its getting fuel. And it will turn over and over, but it simply will not crank. If I let it sit for 10 minutes (taking the key out, etc) and come back, it will start up the first time. Again, this is only about 20% of the time. When it *does* start up, it comes right on without a hitch. There are no other problems with it, it runs great otherwise. No check engine lights come on, mechanic put a meter on it and it gives no error codes. Its not weak when its going down the road, it won't ever bog down. It just won't start about 20% of the time. Please help! I'm really stuck on this one.
It does idle high (1200-1500 RPMs).
*Run 2 cans of injector cleaner through it
Tuned it up (spark plugs and wires, good ones, it was missing a little bit anyway. Before tune-up, Check Engine light would come on once a week. Now it does not come on.)
*Replaced coil pack
*Replaced fuel filter
*Replaced IAC valve
(2001 Ford Explorer XLT 2WD, 4.0 SOHC)
Old 09-02-2010, 04:46 PM   #8
osiris_9510
Fayetteville, NC
2001 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I forgot to add, when it would cut off on its own while idling, it would also give me trouble starting up again. Not always, just some of the time.
Old 09-02-2010, 07:29 PM   #9
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
MAF & CKP sensors
I suggest that you clean the MAF sensor with MAF sensor cleaner.
An intermittently faulty crankshaft position (CKP) sensor can result in similar characteristics. You might try disconnecting and reconnecting the electrical connector to clean the contacts some.
2000StreetRod is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
