Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
94 explorer codes 411 412
Reply
Thread Tools
Old 08-17-2010, 11:28 PM   #1
mxz583
mt.prospect, il
94 limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i have a 94 explorer that has rough idle and above idle is rough at times it will run smooth than rough has code 412 and 411 with KOER and sometimes with KOEO there is a code 211 some black smoke i had spare parts so swap out just about all senors still no inprovemet not sure what to try next fuel pump has 36 pounds and replace the fuel filter
mxz583 is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-18-2010, 12:12 AM   #2
rhauf
Ca
'93 and '91 explorer
Vehicle Specs
Quoted: 0 Post(s)
maybe you have a bad injector, is there more black smoke at idle and lower rpms?
__________________
Check out my Youtube page, many explorer and 4wheelin' videos
http://www.youtube.com/user/rhauf1
rhauf is offline   Reply With Quote
Old 08-18-2010, 12:35 AM   #3
Iron Weasel
Belen, New Mexico
1994 XLT 4x4
Vehicle Specs
Quoted: 2 Post(s)
Continuous Memory Diagnostic Trouble Code (DTC) 211 indicates two successive erratic Profile Ignition Pickup (PIP) pulses occurred, resulting in a possible engine miss or stall.
Possible causes:
Arcing secondary ignition components (coil, cap, rotor, wires, plugs, etc.).
On-board transmitter (2-way radio).
Loose wires/connectors.
Check the basic stuff for this one first. Spark plugs, wires, make sure you're getting a consistent spark from the coil pack. If everything is good with those, then you'll have to start troubleshooting the Crankshaft Position Sensor and the Camshaft position sensor.
DTC 411
Cannot control RPM during KOER self-test low RPM check.
DTC 412
Cannot control RPM during KOER self-test high RPM check.
Your IAC (Idle Air Control) motor is either gunked up something fierce or the solenoid is bad. Take the IAC off and give it a good cleaning, preferably do it a few times, then put it back on and see if the idle is any better. If the little rod inside the motor doesn't move freely, you might be looking at a new IAC motor.
Iron Weasel is offline   Reply With Quote
Old 08-18-2010, 05:12 AM   #4
mxz583
mt.prospect, il
94 limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have replaced the IAC so maybe its in the wiring, black smoke seem to be more at higher rpm what is is the best way to check the injectors
Old 08-19-2010, 06:16 AM   #5
mxz583
mt.prospect, il
94 limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I replaced the IAC and still getting codes 411, 412 not sure what to check next
Old 08-19-2010, 10:18 AM   #6
Iron Weasel
Belen, New Mexico
1994 XLT 4x4
Vehicle Specs
Quoted: 2 Post(s)
Wiring is a good place to start.
First off, start the engine up and let it run for a minute or two then disconnect the wiring harness from the IAC motor. Does the engine RPM drop?
If it does, turn the engine off and disconnect the PCM harness connector and check resistance between pin 21 and the IAC harness. You want to check the wire that's opposite of the retaining clip on the IAC harness. Resistance should be less than 5 ohms between pin 21 and the IAC harness.
If it is, leave the PCM and IAC harness disconnected and check resistance between pin 21 and pins 40, 46 and 60. Each one should be greater than 10k ohms.
If that's OK, check for power at pin 21 on the PCM harness. Test light would be quickest, but a meter between pin 21 and a ground should show less than 1 volt.
Less than 1 volt? Good, continue on to check for IAC signal at the PCM. Connect the PCM and IAC harness and then backprobe the pin 21 and 40 on the PCM. If you can't backprobe the harness, then insert a small needle into the wire and do it that way. Increase engine RPM to about 3k and check voltage, you should be between 3 - 11.5 volts. If you don't have that and all the wiring checked out, you have a bad PCM.
If voltage is within range then check the idle....it should be consistent and not fluctuating wildly. If it idles all over the place, then you could have a vacuum leak causing extra air to enter the engine.
All in all, it's rather odd that you're getting both low and high self-check failures. Those are the only two codes you're getting though, right?
Old 08-19-2010, 09:55 PM   #7
mxz583
mt.prospect, il
94 limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks Iron Weasel for your help, just got home from driving kids to college will check out what you described tomorrow. The only other code that has come up is with Key On Engine Off 211 but that has seem to have gone away.
Old 08-19-2010, 10:05 PM   #8
mxz583
mt.prospect, il
94 limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
the other thing i dont understand is why when you hold the idle at let say 2000 rpm it runs fine then is will start to miss like you just pull off two spark plug wires then go back to running fine again and still get no codes just 411 and 412 i would think with a miss like that i would get more codes
Old 08-20-2010, 12:22 AM   #9
Iron Weasel
Belen, New Mexico
1994 XLT 4x4
Vehicle Specs
Quoted: 2 Post(s)
The 211 DTC could be pointing you towards the cause of the miss. The fun part is tracking down the offending part.
Here's a document that can help you narrow down the 211 code the next time it comes up.
https://docs.google.com/document/edi...thkey=CLiQpOkP
Old 08-20-2010, 06:13 AM   #10
mxz583
mt.prospect, il
94 limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Iron Weasel the document link does not go anywere but to google the is no doc thanks
Old 08-20-2010, 09:52 AM   #11
Iron Weasel
Belen, New Mexico
1994 XLT 4x4
Vehicle Specs
Quoted: 2 Post(s)
I checked it with Google Chrome, Internet Explorer 8, and Firefox and it came up correctly each time.
https://docs.google.com/document/edi...FZakkp5o&hl=en
Try that link, if it doesn't work, send me a PM with your email address and I'll convert it to a PDF file and send it to you.
Old 08-20-2010, 09:34 PM   #12
mxz583
mt.prospect, il
94 limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
iron weasel i think i need to find a breakout box i still have a bad miss above idel but no codes should i still check things out like the document states even if there is no code 211
Old 08-21-2010, 12:39 AM   #13
Iron Weasel
Belen, New Mexico
1994 XLT 4x4
Vehicle Specs
Quoted: 2 Post(s)
If you want to spend the money on one, go for it.....they run anywhere from $500 - $700 for a EEC-IV breakout box.
You can accomplish the same thing, though not as easily, by either backprobing the terminals or piercing them with a needle.
I updated the diagnostic document and added the PCM connector pinout as well as the list of what each pin is, hopefully that will help you out a bit more.
Here's the link to the revised document:
https://docs.google.com/document/edi...CxCrPkG4&hl=en
Old 08-26-2010, 05:16 PM   #14
mxz583
mt.prospect, il
94 limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
iron weasel thanks for the help it turn out to be the pcm the only problem i have now it cranks longer then usual before it starts any thought on this i have installed a new fuel pump
Old 08-26-2010, 07:50 PM   #15
Iron Weasel
Belen, New Mexico
1994 XLT 4x4
Vehicle Specs
Quoted: 2 Post(s)
Does it start and run without any other issues?
If so, I wouldn't worry about it. Mine takes a couple seconds to start up and it runs just fine and doesn't have any codes in it.
Old 08-26-2010, 07:56 PM   #16
waskly
Crooklyn NY!
Vehicle Specs
Quoted: 4 Post(s)
4.0 or 5.0?
waskly is offline   Reply With Quote
Old 08-26-2010, 08:30 PM   #17
mxz583
mt.prospect, il
94 limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
it runs fine. it is a 4.0 i retested the fuel pressure and and when i turn the key off it drops like a rock if i hit the tank presure will hold a few times then go back not holding it is a new pump maybe the ckeck vavle is bad
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
