| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Explorer Audio & Navigation Audio and navigation systems. CD, DVD, MP3, GPS, Video, Mobile Computer, Speakers, Amplifiers. |
Thread Tools |
#1 |
Wannabe Elite Explorer
2004 XLT
Radio volume is out of control.
I have a 2004 XLT, 4x4 with what appears to be the Audiophile Premium, 6 CD, separate subwoofer system. I recently developed a problem with the volume control.
When I attempt to turn the volume DOWN using the control knob, the volume INCREASES. Attempts to further decrease cause the volume to increase even more. I can hit the mute buttton, then attempt to reduce the volume, and it usually goes down. Short of an exorcism, does any one have any ideas or recommendations for fixing this problem? |
#2 |
Aerostar Forum Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Welcome to this forum! I've moved your thread into the audio & navigation section.
#3 |
Deltona, FL
97 Ex XLT & 84 Ranger
If it is a knob and not a button for the volume control, you can try to spray some electrical contact cleaner around and behind the knob (with the power off) and turn the knob back and forth several times to work it in.. do that a couple times and it might help. I have had to do that with equalizers with "sliders" to get static out and control back into them. You can pick that up at lowes or home depot for a few bucks. Hope this helps!
#4 |
Cedar Rapids, IA
04 Eddie Bauer & 13 Ltd
Now my 2004 is doing the same thing as Flyboy's. Seems like the volume potentiometer is going bad.
Not so sure about contact cleaner around plastic (lexan). Last time I tried that on an electrical switch it started to fall apart from the reaction of the chemical to the plastic. The faceplace is easily removed from the head unit. I would like to replace the faceplate circuit board which is where the volume potentiometer is mounted. Anybody know where I can pick up a new faceplate for a 4L2T-18C815-CE for a decent price? |
#5 |
Melbourne Beach, FL
'04 Explorer
me three: demon possesed volume button
I have the exact problem - volume sometimes only increases no matter which way the knob is turned. Very scary. Additionally, my steering wheel controls sometimes also go crazy - e.g., down volume will change the radio station.
Any thoughts? |
#6 |
Cedar Rapids, IA
A week ago I popped off the steering wheel airbag and removed the switch assembly. Very easy and took only a few minutes. Cleaned what I could with alcohol on the connector and blew compressed air around the switch itself. It has been work fine since.
Just got a new circuit board yesterday from an on-line audio dealer. Cost me $30 plus shipping. I plan on installing that today. That should only take me 20 minutes to do. My theory is that he volume potentiometer is bad. I will update the thead after some run time on the new circuit board. |
#7 |
Melbourne Beach, FL
'04 Explorer
Thanks
Looking forward to hearing how the circuit board fix works for you!
Also - how difficult was it to pop off the steering wheel airbag and remove the switch assembly. Any tips on how to do that? |
#8 |
Cedar Rapids, IA
Precaution: Disconnect negative lead on battery and wait 5 minutes for airbag system to de-energize.
Pop of the 2 small access cover plugs on the backside of the steering wheel. Use small straight screwdriver or a pick. Remove the 2 airbag screws, I think they were 8 mm. Disconnect air bag electrical connector and set aside. The radio control and cruise control switch assemblies are right there. There were 2 screws for each switch and 1 connector. Piece of cake. |
#9 |
Cedar Rapids, IA
New board is in and working well. The volume control/know feels tighter and truer. So far so good. I picked up the board for $30 from S.P.L. ELECTRONICS / Stereos on the Go.
http://oem-auto-accessory.com Toll Free #1-866-380-0529 |
#10 |
2004 XLT
That sounds like a good solution worth trying - not too expensive and time consuming. Any problems getting the faceplate off?
Thnaks for the name of the company. I'll give them a call. I'd assume they need the model and serial numbers to make a good match. Any problems gtetting the new circuit board mounted? Thanks, flyboy 229 |
#11 |
Virginia Beach, Va
00 4x4 Mounty
You can take the knob off and spray electrical contact cleaner with a straw into it while turning it back and fourth and lightly blow with compressed air to dry. That fixed one I had.
__________________ 1998 Mountaineer 5.0 2wd - Mac intake, Ported intake, FMS headers, 3" Exhaust, E-fan, SCT tuned, Baumenn Shift Kit, MSD, 4.10 l/s, Lowered 3/2 on 18x9 Cobra r's, HID's 2002 F250 Crew Cab SB 7.3 Diesel 4x4 - 4" MBRP exhaust, AIH delete, SCT Livewire 2001 Ranger ext cab 4x4 - 5.0/4r70/4406 swap in progress (2) 97 Mountaineers for parts 98 Sport for Parts My eBay auctions |
#12 |
Melbourne Beach, FL
'04 Explorer
Fix still fixed?
Hey FordFool2,
Just checking in - you have had your fix for a while. All is still good, right? I finally have some time to attack my problem. but wanted to make sure you were still happy with your replacement circuit board. Thanks! |
#13 |
Cedar Rapids, IA
Board is working great. Not a single problem. Works like new again.
#14 |
Denver, CO
It is the rotary encoder (volume knob )
If your handy with a soldering iron, you can remove and replace the rotory encoder that is used for the volume knob. I own an F250 Super Duty with a 6 disc in dash, but I know most of the Ford stereos use the same encoders. You'll need one that has the on/off momentary push button switch. I got one off eBay for $1.49 and it's been working great for the last 5 years.
Get the numbers off of the one in your radio and make a note of the number of leads it has, then just google to find out the specs. You can also go to Mouser electronics at mouser dot com once you have the number. Cleaning works on some for a while, but the permanent fix is a new encoder. good luck |
#15 |
Denver, CO
The one that worked for me was the Panasonic EVQ-WTEF2515B Mechanical Rotary Encoder.
The length of the shaft was too long, so I just cut it down shorter. Don't use a dremel or anything that spins fast as the heat will destroy the part. I found out the hard way on another project years ago. You can always find one with the same specs with a shorter shaft too. |
#16 | |
Lehi, UT
2004 Explorer Eddie Bauer
Volume Control Circuit Board
Thanks for posting. This fix worked for me! Volume controls working perfectly. Easy fix!
Quote:
| Tags |
| radio, volume control |
| Thread Tools | |
