Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Rough Idle, Check Engine Light is On, Spark Plug Issue - connected?
Reply
Thread Tools
Old 08-25-2010, 09:58 AM   #1
bikeguy
Traverse City, Michigan
2000 Explorer 2dr
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I've got a 2000 Explorer Sport (2dr) w/ 4.0 X-Vin OHV with 126xxx miles and I've got a few engine issues I'm trying to diagnose, wondering if the issues I'm having are connected - mechanic hasn't been a big help.
Here's what I'm seeing:
- Check Engine Light has been on for some time, scanned codes, says I have a large vacuum leak (can't remember what the exact code was). Per mechanic's suggestions, I've replaced the gas cap 2x, hasn't fixed problem. I'm wondering if there is a valve in the vacuum system that has gone bad?
- New Motorcraft plugs & wires. Plugs have needed replaced at least once a year. Center electrodes get worn down to almost a nub/fine point and cylinder will start missing badly. Usually the offending plug will be on the lean side and codes will indicate a cylinder is running lean. Every time it's happened, it's been a different plug that goes bad - never in the same cylinder twice.
- At start-up, truck idles rough when cold. At/below idle, idles roughly, chugs
- rev the throttle in neutral or accelerate over 2000-2500, cleans rough idle out and truck starts/runs great while warm.
- Slowly losing coolant from radiator, can't determine where. Not seeing any leaks or drips, doesn't leak while sitting. I will occasionally smell a puff of coolant via the heater/ac ducts when starting the truck (mostly when truck is warm), but that's about it. Truck doesn't appear to be smoking in engine compartment or excessively out tailpipe. I've pulled plugs a number of times in the last year and there has been no evidence of coolant on the plugs. Truck has not overheated to my knowledge. Wondering if I have a leaking heater hose or something like that? Got my fingers crossed, really hoping it's not a head gasket leak - need to run a compression test soon.
bikeguy is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-25-2010, 11:50 AM   #2
specialized7
saskatoon
99 SPORT
Vehicle Specs
Quoted: 0 Post(s)
Upper and lower intake gaskets, id get someone to pressure test the system.
__________________
97 Limited 4x4 31x10.5 (CRASHED)
99 Sport 4x4 Lifted 33x12.5's (SOLD)
2001 Trd Tacoma 4x4 3" BL
specialized7 is offline   Reply With Quote
Reply
Tags
bad spark plugs, check engine light, coolant leak, rough idle
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
