Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
2000 Merc. Mountaineeer o2 sensor location
Reply
Thread Tools
Old 08-26-2010, 03:58 PM   #1
rrzany
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have a 2000 mountaineer 5.0 v8 and the drivers side upstream o2 is bad and i have no idea where it is. i have taken the tire and wheel well off and i cant find it. can someone help me? thanks
rrzany is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-26-2010, 04:00 PM   #2
Dan Whitaker
One fast putty tat
Raytown MO (Kansas City suburb)
Dan Whitaker's Avatar
No Mounty no more.
Vehicle Specs
Quoted: 21 Post(s)
Got search?
It works wonders
__________________
P r i c k me, do I not bleed Ford Blue.
Dan Whitaker is offline   Reply With Quote
Old 08-26-2010, 04:04 PM   #3
rrzany
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i just did search and i couldnt find anything. do you know the sensor is at? ive seen people say take the wheel off and its there but i didnt see it.
Old 08-26-2010, 04:27 PM   #4
SparkyJeff
Minneapolis, MN
'00 5.0L Mountaineer
Vehicle Specs
Quoted: 2 Post(s)
Bank 1 is the side of the engine with the number one cylinder. For the 5.0 Liter Ford Engine this means the passenger side, sensor 1 means that it is the first sensor that the exhaust reaches as it exits the engine and travels rearward toward the back end, it is between the catalytic converter and the engine exhaust manifold/header. you've already jacked up the truck and taken the wheel off, support the truck with a jack stand and crawl under there. Its not a tiny sensor, you will see it. start by checking the electrical connection of the sensor, try to wiggle it, pull it apart put it back together what have you. Then clear the code by either disconnecting the battery for a while, or using a scan tool. that may do the trick for you. good luck
Edit: by the way, it is screwed into the exhaust pipe, not the engine, not the car body, it's not the egr tube which is on top of the exhaust manifold in the engine bay, get under the truck safely, It is not hiding from you although it's not right out in the open where it can be damaged by every little piece of road debris, so it might be hard to get a wrench on it to turn it out.
SparkyJeff is offline   Reply With Quote
Old 08-26-2010, 04:32 PM   #5
rrzany
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
its the drivers side sensor and the only sensors i found where in the exhaust pipe and no matter who i ask i get different answers. i took the battery cables off and im letting them sit for a while. whoever invented o2 sensors is cleaning up
Old 08-26-2010, 04:34 PM   #6
SparkyJeff
Minneapolis, MN
Vehicle Specs
Quoted: 2 Post(s)
Quote:
those sensors in the exhaust pipe are the oxygen sensors
Old 08-26-2010, 04:42 PM   #7
SparkyJeff
Minneapolis, MN
Vehicle Specs
Quoted: 2 Post(s)
You're right about that
http://www.bosch.com.au/content/language1/html/4566.htm
Old 08-26-2010, 04:48 PM   #8
rrzany
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
yea i know. those are the only ones that i could find. its the upstream ones i cant find.
Old 08-26-2010, 04:52 PM   #9
SparkyJeff
Minneapolis, MN
Vehicle Specs
Quoted: 2 Post(s)
the upstream sensor is the one that is after the exhaust header and before the cat converter.
Old 08-26-2010, 04:53 PM   #10
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 699 Post(s)
Dude
the driver side (bank 2) sensor 1 ( upstream) is right under the dang transmission to engine mating point. You probably bumped your head on it.
The remaining 3- 02 sensors are all on the passenger side of the transmission.
__________________
Jon
9 mile skid, on a ten mile ride. Hot as a pistol but cool inside.
2000 Mountaineer
1998 Mountaineer "Turdle"-gone
1993 Convertible "Vitamin D Wagon" Sold also
Turdle is offline   Reply With Quote
Old 08-26-2010, 05:11 PM   #11
rrzany
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
so they are not in the manifold but in the pipe because the ones in the pipe (close to engine) are the ones i changed. so the downstream are down towards the end of the exhaust? me and my old man both crawled under and only saw the two previously mentioned.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
