Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
annoing noise! please read!
Reply
Thread Tools
Old 08-30-2010, 10:07 PM   #1
mlcase27
lagrange indiana
94 xlt
Vehicle Specs
(Original Poster)
Hi, I have a 94 explorer and just recently I have been getting a real load noise coming from the front end. It almost sounds like the growl of big beefy tires on the road but I have regular tires on it. When I drive strait you can hear it and when I turn left it gets even louder but if I turn right it seems to go away? Could it be the tires and if so which side? Also, I have checked all my fluids and they are all good. Please help!
mlcase27 is offline   Reply With Quote
Old 08-30-2010, 10:47 PM   #2
1998Explodasport
Brockton, Ma
2001 Explorer Sport
Vehicle Specs
Sounds like you might have a bad wheel bearing.
__________________
2001 Explorer Sport SOHC
1995 SHO ATX
1998Explodasport is offline   Reply With Quote
Old 08-31-2010, 12:04 PM   #3
mlcase27
lagrange indiana
94 xlt
Vehicle Specs
(Original Poster)
I checked both sideds and repacked the passenger side, they all looked ok
Old 08-31-2010, 09:08 PM   #4
1998Explodasport
Brockton, Ma
2001 Explorer Sport
Vehicle Specs
Maybe the tires are chopped.
__________________
1995 SHO ATX
Old 09-01-2010, 07:23 AM   #5
little x
SW VA
'91 XL
Vehicle Specs
Try switching which side the tires are on and see if the symptoms get worse while turning right and better while turning left now.
little x is offline   Reply With Quote
Old 09-01-2010, 08:26 AM   #6
jds3403
Ex Beater
new bern
'99 5.0
Vehicle Specs
I would really look twice at the bearing and inspect the race for any damage the naked eye cannot see minor imperfections that lead to bearing failure it might be a tire as well and that is easier to check, swap tires! if the noise switches sides then there's your answer. Check your ball joints on the left side for any lateral play if they allow the tire to move noticeably at all then they might be changing the geometry of the tire's contact path on the road causing the noise so check tires, ball joints and bearings however if it was me, depending on how much the bearing is I would replace the bearing assembly regardless of how it looked to my naked eye.
jds3403 is offline   Reply With Quote
Old 09-01-2010, 08:52 AM   #7
Puremuscle
Vehicle Specs
Had the exact same situation and did all the checks you did. Wheel bearings were the problem.
Puremuscle is offline   Reply With Quote
Reply
Tags
end, front, loud, noise, tire
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
