Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Modified 2002 - 2005 Explorers
Notices
Modified 2002 - 2005 Explorers Questions related to modified 2002 - 2005 Explorers and Mountaineers. For Sport Trac and Sport models use the 1995-2001 forum. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap.
What plugs and wires to use
Reply
Thread Tools
Old 09-05-2010, 09:56 AM   #1
murdered05X
greenville ,sc
murdered05X's Avatar
2005 xlt
Vehicle Specs
(Original Poster)
Having miss-fire and was going to change my spark plugs and coils. What is the best choice for an explorer with 80K and its a 4.6?
__________________
Slowly murdered out
2005 xlt 4.6 getting murdered.
2.5/2inch rb lift
17x9 black moto metal 951 with 265/70/17
96 cobra 48000 0riginal miles. built by rick @ ats. putting 898/745 down on t-trim at 23#
murdered05X is offline   Reply With Quote
Old 09-05-2010, 03:42 PM   #2
CALDWELL
Philadelphia Airport, PA
2005 V6 Silver XLT
Vehicle Specs
your best bet for plugs, is going to be sticking with Motorcraft Plugs. and if you want to improve your ignition, then maybe buy some larger wires ?
__________________
DANNY#2
SILVER 05 XLT
Stage 2 Intake ~ Exhaust ~ Henson Performance Tunes ~ Luminic's Bulbs ~ Sound System ~ Bull Bar ~ Black Headlight Housings ~ 20% Tint ~ FD Lights/Siren ~ Remote Start
CALDWELL is offline   Reply With Quote
Old 09-06-2010, 12:58 AM   #3
MillerTimeX17
Firestone, CO
05 XLT
Vehicle Specs
yeah stick with Motorcraft platinums
__________________
mods:Full Intake w/ K&N Filter, Electric Fan, FM 50 SUV, 3" Body, 2.5" Truxxx, 16x8 Vision Wheel 375 Warriors, 285/75/16 Cooper Discoverer STTs, 4 pairs of HIDs and full LED Swap, Alpine IXA W407 7" Double Din Touchscreen, Alpine 6.5" components, 2 12" Type R's, 1180w rms total
Elite Registry
MillerTimeX17 is offline   Reply With Quote
Old 09-06-2010, 09:11 AM   #4
Limited02
Wanna Race?
Gardner, KS
Limited02's Avatar
'02 Limited V8
Vehicle Specs
I was talking with James Henson last week about the ignition system and he recommended stock #401-Champion Copper Plugs. As far as buying new wires, you really can't, you have to buy new boots that go on the COP's. Have you ever changed the plugs on a 4.6 before?
I've changed my plugs less than 5,000 miles ago, but I am going to be giving the copper plugs a try soon because mine hasn't been the same since I last changed them.
__________________
"Spending money I don't have, on parts I don't need, to impress people I don't know"
2002 4.6 4x4, K&N CAI, Henson tuned, FM70 and 20" Boss 306's
Limited02 is offline   Reply With Quote
Old 09-06-2010, 09:13 AM   #5
waskly
Crooklyn NY!
Vehicle Specs
cop boots, they are held in with a 7mm you have no wires. also coils get water in them shorting them out. factory plugs should be good for up to 100k
and if its a 3 valve best to leave the plugs in.
waskly is offline   Reply With Quote
Old 09-06-2010, 09:34 AM   #6
mshuler009
Centerville, Ohio
1998 Explorer
Vehicle Specs
As far as a wastespark ignition system goes (coil pack) I suggest using double platinums. The way that ignition system works is two plugs are fired at once, one on the compression stroke, the other on exhaust stroke. One spark jumpes the conventional way (electrode to ground) and the other ground strap to electrode. The problem with using copper or single platinum plugs lies in the fact that tip erosion occurs due to wear. Well each time a plug fires a little bit of material follows the spark. Would you want standard ground strap material basically covering the platinum? I know several Ford Senior Master Techs who said they've solved a lot of driveability concerns by installing double platinum autolites. Standard distributor ignition- single platinum or copper plugs. COP ignition- it's really your choice, I'd go with platinums just for longevity.
__________________
'98 4.0 OHV Explorer
Ford Certified Technician
NASCAR Technical Institute Alumni
mshuler009 is offline   Reply With Quote
Old 09-06-2010, 01:44 PM   #7
murdered05X
greenville ,sc
2005 xlt
Vehicle Specs
(Original Poster)
ok? so copper or platinum? also why am i hearing that i shouldnt change my plugs til 100k? i figured i might as well do it since im changing some coils
__________________
Slowly murdered out
2.5/2inch rb lift
Old 09-06-2010, 01:54 PM   #8
waskly
Crooklyn NY!
Vehicle Specs
Quote:
factory plugs are for 100k.
Old 09-06-2010, 02:49 PM   #9
mshuler009
Centerville, Ohio
1998 Explorer
Vehicle Specs
Copper Plugs are 30k; Anything else is 100k Just curious but why are you changing your coils? That's an expensive route to take right off the bat.....
__________________
Old 09-06-2010, 07:31 PM   #10
Limited02
Wanna Race?
Gardner, KS
Limited02's Avatar
'02 Limited V8
Vehicle Specs
That's my understanding as mshuler009 has said. Copper plugs do not last as long, but being copper, their conductivity of electricity is better than other plugs. Iridium and and Platinum have higher melting points, allowing them to last longer(100k) I always change my plugs every 2 years anyway, so I'm going to be giving Coppers a try and see what happens.
For what it's worth, I have run Platinums and changed them out after about 30k and the little electrode tip was worn at an angle on most of them. So they would have been history before 100k.
__________________
Old 09-06-2010, 07:50 PM   #11
murdered05X
greenville ,sc
2005 xlt
Vehicle Specs
(Original Poster)
i am changing them bc im getting missfire in the number 5 and 8 cylinders
__________________
Slowly murdered out
2.5/2inch rb lift
Old 09-06-2010, 07:52 PM   #12
mshuler009
Centerville, Ohio
1998 Explorer
Vehicle Specs
Actually they all conduct electricity the same; inside every plug is a resistor. The resistors vary from manufacturer to manufacturer but they are there to equalize the resistance of the plug itself....that's why ignition oscilloscopes are so reliable; they count on the varying resistance in the secondary circuit to be the condition of the parts...not the design.
__________________
Old 09-06-2010, 07:53 PM   #13
mshuler009
Centerville, Ohio
1998 Explorer
Vehicle Specs
do you have codes for cyl. 5 and 8 or did you come to that diagnosis another way? Sorry to be nosey
__________________
Old 09-07-2010, 07:58 AM   #14
matt0248
Chicago
02 XLT V8
Vehicle Specs
With the 4.6 and individual coils for each plug you only need single tip platinum plugs. These coil do fail and since they have to be removed to do the plugs get two new motorcraft coils and put them on #5 and #8 cylinders. I have worked on many a 4.6 with misfires and it usually ended up with the coils being bad.
matt0248 is offline   Reply With Quote
Old 09-09-2010, 05:21 PM   #15
murdered05X
greenville ,sc
2005 xlt
Vehicle Specs
(Original Poster)
well the code came to number 8 and i got a new motorcraft coil and a new motorcraft platinum plug because the plug was wet. she runs fine now!
__________________
Slowly murdered out
2.5/2inch rb lift
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
