#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
One fix for rear window washer not working
Reply
Thread Tools
Old 09-16-2010, 12:08 AM   #1
workman482
Dothan, AL
'04 XLS
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US One fix for rear window washer not working
Hello everyone. Thought I would contribute a little knowledge gained on my '04 XLS. Especially since someone else's thread helped me with a A/C problem. I didn't find another thread for this gen of Explorer so I figured I would go ahead and put it on here.
Just purchased my Explorer and got it home before I realized that the rear window washer didn't work. Whenever I tried to use it the fluid looked like it was dumping from behind my passenger side rear tire. Upon further inspection I found that it was leaking from a seam in the fender well. After some research online I found that the front and rear window washers work off of the reservoir in the front so I knew it wasn't a problem with a reservoir in the rear, had to be a split or break in the line. The following is the steps (with pics) that I took to fix my problem.
Before you can get to the hose you need to take off some the plastic fascia in the cargo area.
Here are the tools that I used through out the process:
I used the screwdriver to press in and pry the clips loose. They shouldn't need a lot of pressure.
The first step is to remove the piece on the bottom, (all the pieces snap into place, no screws.)
Once you have that removed you must now remove the piece at the top:
http://i683.photobucket.com/albums/v...s/_MG_4932.jpg
Once the top piece is removed, you now have to remove the plastic piece covering the passenger rear corner:
http://i683.photobucket.com/albums/v...s/_MG_4930.jpg
Now that all that is out of the way you can get to the actual piece of plastic that is covering the line. There is no need to remove it all the way. Just undo enough snaps to reach the tubing:
http://i683.photobucket.com/albums/v...s/_MG_4929.jpg
Here is what the actual problem was:
http://i683.photobucket.com/albums/v...915_133955.jpg
The line wasn't broken or split, it had just come apart. Every time I tried to use it like this it was dumping washer fluid down into the body and onto some electrical work as seen here:
http://i683.photobucket.com/albums/v...915_134023.jpg
If needed you can get down there with a paper towel or rag to get the water out. you definitely don't want to let the water just sit in there as it can cause corrosion.
Here is what I did to my tubing once I put it back together to keep it from coming apart again. You could also use a small hose clamp if you have one handy.
http://i683.photobucket.com/albums/v...s/_MG_4927.jpg
Well, once you put the hose back together you just have to snap everything back in place.
Reminder: When you get done, as well as when your snapping the plastic back in, make sure the rubber seal isn't pinched under the plastic anywhere as it could cause leaks and wind noise.
Well I hope I didn't bore anyone and someone finds this useful. Thanks for your time.
workman482 is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-16-2010, 12:21 AM   #2
xTOM153x
West Islip Long Island
2003 XLT
Vehicle Specs
Quoted: 9 Post(s)
Thank You for doing this my rear windshield wiper fluid doesn't come out hopefully this is the problem I thought it might be motor but it still makes the noise for it to come out but nothing happens
xTOM153x is offline   Reply With Quote
Old 09-16-2010, 01:16 AM   #3
workman482
Dothan, AL
'04 XLS
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US
NP. I just hope it helps.
Old 09-16-2010, 04:23 PM   #4
xTOM153x
2003 XLT
Vehicle Specs
Quoted: 9 Post(s)
Hey finally took a good look at it and pulled the trim off the back and found that it was connected back there but turned out to be in the engine bay it was disconnected and was collecting water in a corner until I had it going for a bit then started to drip and heard it. Plugged it back in and put a zip tie around it and works great. Thanks
Old 09-16-2010, 04:32 PM   #5
workman482
Dothan, AL
'04 XLS
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US
Yeah, you'd think Ford would have put zip-ties or hose clamps on there from the factory. Oh well. At least it was an easy fix. Glad the thread helped.
Old 07-09-2014, 03:28 PM   #6
xhomerjayx
new york, ny
2002 xlt
Vehicle Specs
Quoted: 1 Post(s)
Hey can you post the pictures again please? I have the same issue and I want to fix it. Thank you very much
xhomerjayx is offline   Reply With Quote
Old 06-12-2015, 05:22 PM   #7
bowhunter543
2004 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
This is just the problem I am having. Can't access your pics. Do you still have them?
bowhunter543 is offline   Reply With Quote
Reply
Tags
rear window, washer
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
