#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Where is the idle control valve on an '05 Explorer?
Reply
Thread Tools
Old 09-19-2010, 01:56 PM   #1
Tbonemoore1
Richmond, VA
2005
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have a 2005 Explorer that I am trying to replace the Idle Air Control Valve on, and I can't find where it is on the motor. I have a repair manual and have called and visited numerous parts stores and no one has been able to help. The motor is a 4.0 SOHC, and the valve is supposed to be where the breather attaches to the throttle body, or somewhere close, but the Motorcraft part that I bought to replace the factorypart doesn't seem to exist anywhere on the engine. I have checked to make sure that the part is the correct one, and have found that it is the only one available. Does anyone have an idea of where the part is?
Thanks,
Tbonemoore1 is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-19-2010, 02:07 PM   #2
waskly
Crooklyn NY!
Vehicle Specs
Quoted: 4 Post(s)
if you are drive by wire, and i think 05 is, you dont have an iac.
waskly is offline   Reply With Quote
Old 09-19-2010, 02:12 PM   #3
Tbonemoore1
Richmond, VA
2005
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks. Why would the engine code definition say that it is a faulty IAC Vavle? What else could it be that would cause an idle problem?
Old 09-19-2010, 02:14 PM   #4
waskly
Crooklyn NY!
Vehicle Specs
Quoted: 4 Post(s)
whats the code?
Old 09-20-2010, 11:30 PM   #5
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Welcome to this forum! I've moved your thread into the stock 2002-2005 section.
BrooklynBay is online now   Reply With Quote
Old 09-28-2010, 07:38 PM   #6
ChrisR
globe, az
2005 XLT
Vehicle Specs
Quoted: 0 Post(s)
according to my chiltons 2004 and later models do not have an IAC valve.
ChrisR is offline   Reply With Quote
Old 09-29-2010, 05:45 PM   #7
imp
Missouri Ozarks
2004 XLT
Vehicle Specs
Quoted: 115 Post(s)
Quote:
This appears to be accurate info. My own '04 has no Idle Air Control or Idle Speed Control as it was earlier called. Ford Engineers seem to have decided that the system of driving the throttle plate with a motor ("Drive By Wire") is accurate and sensitive enough to open and close the plate that slight amount necessary to control idle speed as engine load changes due to accessory loading (alternator, A/C, etc.).
It seems to work! imp
imp is online now   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
