Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Explorer windshield washer not working
Reply
Thread Tools
Old 09-21-2010, 12:10 PM   #1
snowpond97
cocoa beach fl
2003 eddie bauer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hello,
I have a 2003 Ford Eddie Bauer Explorer and my windshield washer pump is running but not pumping so to change out pump do you just pull the suction side of the pump from the reservoir? It looks like it snaps in via a seal/rubber gromment? Also with both rear and front discharge hose disconnected should fluid pour out? (which it does not) Possible reservoir clog?
Thanks,
Snowpond97
snowpond97 is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-21-2010, 12:26 PM   #2
matt0248
Chicago
02 XLT V8
Vehicle Specs
Quoted: 1 Post(s)
I would expect fluid to come out of you disconnect the hose from the pump. See if you can blow through the hose, to elimate that from being plugged.
matt0248 is offline   Reply With Quote
Old 09-21-2010, 03:17 PM   #3
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Changing the pump is not difficult at all. When I get home I'll point you to one of my posts about it. You could also search my posts ans see if you can find it.
Posted via Mobile Device
BigRondo is offline   Reply With Quote
Old 09-21-2010, 05:58 PM   #4
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Found it! Check out this thread:
http://www.explorerforum.com/forums/...d.php?t=286771
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
Old 09-29-2010, 06:02 PM   #5
snowpond97
cocoa beach fl
2003 eddie bauer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
BigRondo,
Sorry I did not get right back to you but you were right on the money. It was a bad pump and your diagram was most helpful. Thanks for you help, it is greatly appreciated.
Regards,
Snowpond97
Old 09-29-2010, 07:51 PM   #6
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Quote:
Originally Posted by snowpond97 View Post
BigRondo,
Regards,
Snowpond97
Glad to help.
__________________
Old 12-05-2010, 10:03 AM   #7
Critz
Cleveland, Ohio
2003 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
replaced pump; still no washer fluid - Any suggestions? Couldn't find fuse, for the washer pump??? Any suggestions would be greatly appreciated.
Critz is offline   Reply With Quote
Old 12-06-2010, 11:44 AM   #8
Cobra Jet
Vincentown, NJ
2004 XLS
Vehicle Specs
Quoted: 1 Post(s)
Quote:
Be more clear w/ your response...
When you say still no washer fluid after replacing the pump - is the pump turning ON (can you hear it "buzz")?
Was the pump replaced w/ a new pump or used?
If the pump is not turning on, then you need to check fuses, the actual harness connection at the pump and/or the multi function control stalk.
If the pump IS turning on, but is not pumping fluid to the windshield, then you should check for any holes, leaks or loose washer hoses under the hood and going to the washer resevoir.
If all hoses are good and the pump is "on" - then I'd suspect the impellar fell off of the pump, in which case, it cannot pull fluid into pump.
__________________
- Phil
1994 Cobra #0013
2011 Genesis Coupe
Cobra Jet is offline   Reply With Quote
Old 12-24-2010, 07:35 AM   #9
Critz
Cleveland, Ohio
2003 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
Cobra Jet;
Yes brand new pump from Auto Zone; hoses look good. The pump doesn't make any sound or turn on...etc.
Not sure where to locate the fuse for this....I have checked all the fuses on the interior fuse block as well as the one under the hood.
From what i can see all the fuses are good. If you are able to point me to a specific fuse for the washer motor - it would be greatly appreciated.
On an additional side note the rear wiper doesn't turn on at all.
How would i check if the 'multi-function' control stalk has not gone bad?? The only thing working properly is the actually front windshield wipers.
Again any suggestions are greatly appreciated.
Old 12-24-2010, 11:49 AM   #10
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Cobra Jet;
I don't know how to check the Multi Function Switch. Here is the thread for replacing it: http://www.explorerforum.com/forums/...d.php?t=279556
Here is some info from my owner's manual. If you don't have an owner's manual, it can be downloaded here.
I apologize for the size of the pics but I wanted you to be able to see them.
There are 2 fuses related to the wipers/washers in the fuse panel located in the passenger compartment. #8 is a 30A Fuse for the front & rear washer relays and the front wiper control. #9 is a 15A Fuse for the rear wiper coil and contact:
There are 2 relays related to the washers located on the reverse side of the fuse panel. #4 is the relay for the front washer pump. #6 is the relay for the rear washer pump:
There are 2 relays related to the wipers located in the power distribution box located under the hood. #54 is the wiper run/park relay. #59 is the wiper high/low relay:
There is a relay related to the wipers in the rear relay box located on the rear quarter side passenger trim panel. To access this box you must remove the trim panel. #17 is the rear wipers relay:
I hope this helps out. Good luck with the fix.
Merry Christmas and Happy New Year.
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
