Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Front drive shaft TC dust boot
Reply
Thread Tools
Old 09-22-2010, 05:48 PM   #1
rollinstone
1997 Ford Explorer XLT
Vehicle Specs
Quoted: 8 Post(s)
(Original Poster)
This has to do with the dust boot that covers the universal joint coming out of the transfer case.
History: April 2009 took the truck in to have the front drive line inspected...noises. Determined that the left bearing and short shaft needed replacement. Also decided to have the front drive shaft rebuilt. The rebuild includes a new dust boot. The original boot was shredded...don't know for how long.
Nine-ten months later I was under the car and noticed the new dust boot was torn again, slinging lube. Took it back in to the same shop and they sent it out to have it redone by the same guys. Altho out of warranty, the drive-line shop rebuilt it at no charge...nice guys!
OK, so 3 months go by and I'm under the truck again and same thing...shredded dust boot! Damn! Back to the shop and the shop owner put his own same gen Ex on the lift to compare and what does he find? Right...a shredded boot on his own Ex rebuilt by the same drive-line shop!
Needless to say, they're talking. Don't know where it's all gonna end up. Does anyone have a clue why this damage keeps recurring? I can only assume that they're doing a shaft balance, etc...I mean, they've been in business a long time...same location for lotsa years.
Two trucks, same problem? Too weird!
__________________
Gary S. 97 XLT AWD 5.0L
rollinstone is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-22-2010, 08:06 PM   #2
imp
Missouri Ozarks
2004 XLT
Vehicle Specs
Quoted: 122 Post(s)
This would be a '97 model? My '96 had common ordinary U-Joints at all four points on both front & rear shafts, so evidently, or perhaps because mine was not a V-8, your '97 has possibly a constant velocity joint on the transfer case end of the front shaft?
My '04 has a C-V there, but it is an unusual-looking thing with an internal seal boot which is hardly visible at all; if it were shredded, you would have to get in & look real close.
So, I'm writing with hopes someone will clarify this, as I would really like to know what type of joint we are talking about here.....imp
imp is offline   Reply With Quote
Old 09-23-2010, 02:48 PM   #3
gavin
Anchorage, Alaska
gavin's Avatar
'97 Explorer XLT AWD 5.0L
Vehicle Specs
Quoted: 6 Post(s)
96-97.5 V8 Explorers had a double-cardan front driveshaft.
This was replaced with the CV driveshaft, due to NVH (noise-vibration-harshness) caused by the angles of the front driveshaft with the double-cardan joint.
as for the OP, I've never had a ripped boot on my front shaft. Well, I did once, but I caused the tear.
Was the shaft inspected when received from the driveline shop, to verify the boot was, in fact, replaced? Maybe they never replaced the boot, since it cannot be replaced without replacing the whole cv cup.
__________________
Daily Driver: 1997 V8 Explorer - K&N FIPK, Granatelli MAF, 3" Body Lift, WAR-153 Shackles, Torsion Twist, custom-built skidplate. 4.56s, Ion Alloy 133's, 33x12.5 Interco TrXus STS.
1986 Bronco2: RIP
gavin is online now   Reply With Quote
Old 09-23-2010, 06:47 PM   #4
rollinstone
Vehicle Specs
Quoted: 8 Post(s)
(Original Poster)
Quote:
The boot was replaced during the original rebuild and replaced again when I took it in the second time.
__________________
Old 09-23-2010, 08:47 PM   #5
imp
Missouri Ozarks
2004 XLT
Vehicle Specs
Quoted: 122 Post(s)
This was replaced with the CV driveshaft, due to NVH (noise-vibration-harshness) caused by the angles of the front driveshaft with the double-cardan joint..........
My '96 XLT had no double-Cardan, just single U-Joints, both ends, same series as rear shaft-, it was a 4.0L OHV V-6. There must have been driveline angle issues with the V-8?
BTW, the double-Cardan design is a constant-velocity joint. These were in some years used at both ends in expensive cars (Caddy & Lincoln).
Old 09-23-2010, 09:04 PM   #6
gavin
Anchorage, Alaska
gavin's Avatar
Vehicle Specs
Quoted: 6 Post(s)
yes.
I have a double-cardan front shaft that has horrible NVH. It's due to the shaft angles. The t-case output is actually angled up, rather than down towards the pinion.
I haven't bothered to follow or research the 4.0's, since I don't have one.
__________________
1986 Bronco2: RIP
Old 09-24-2010, 03:41 PM   #7
rollinstone
Vehicle Specs
Quoted: 8 Post(s)
(Original Poster)
My shop today told me the drive-line shop he sends his work to says they told him there is now a boot replacement kit. So, we might just go for the boot replacement...
BUT, they also found out that the 2nd Gen Ex V-8s has had a vibration problem with the front drive shaft and that there is supposed to be a modified front drive shaft fix.
We're still looking into it. If every boot I replace is just going to tear down the road, I'm thinking the shaft mod might be the way to go. Stay tuned.
__________________
Old 09-24-2010, 04:32 PM   #8
gavin
Anchorage, Alaska
gavin's Avatar
Vehicle Specs
Quoted: 6 Post(s)
Quote:
the NVH caused by the front shaft was only in the 96-97.5 V8 Explorers with the double-cardan front shaft.
The "redesigned" shaft also included a different t-case to accept the CV shaft.
edit: ok so there was a different TSB that affected 1996 V8s which required a reprogramming of the transmission along with additional bracing for the t-case.
TSB 962416
TSB BC0534961108
TSB BC5225961001
all 3 are related.
97 only show
TSB BC0534961108
TSB BC5225961001
__________________
1986 Bronco2: RIP
Old 10-08-2010, 03:44 PM   #9
rollinstone
Vehicle Specs
Quoted: 8 Post(s)
(Original Poster)
OK...got the dust boot replaced for parts only cost. While it was on the rack we noticed that, yes...the TC case does not angle down toward the front differential...looks like about a 2-3 degree angle difference as the front drive shaft connects between the TC case and differential.
Also noticed that the TC case end of the drive shaft is not centered coming out of the TC case...looks like it sits just off-center in about the 7 o'clock position.
So, does this offset mean that after repeated revolutions the boot is going to shred? As you see from the beginning of this thread, mine's been shredding for no apparent reason.
I will be inspecting the dust boot weekly to try to pen point when/if it shreds again. I'm curious how many other '97 AWDs have experienced this. My local Ford dealership said they'd never heard of this being a problem...no TSB's, nada.
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
