I have Ford PDF files for the Neutral Tow Kits. If you have a V6, you only need to install an LED Idiot Light on the dash. If you have a V8, you also need to install a switch. However, you don't need the micro switch shown in the instructions, you just need a plain toggle switch to "jump" two wires.
I made and installed my own for under $12. (Ford wanted $499 to install). The hardest part was finding a dealer that is capable of re-programming the ECM to "allow" Neutral Tow. I had to drive over 130 miles to get mine done.
Send me and Email and I'll send you the PDF and where you can buy the materials. ross0737 at aol dot com. I just need the year and engine size.
Info I have found and to make it easier to search for I'll post the chart here. I'll get the full TSB's posted in the FAQ stickys.
Additional from FordFleet.com:
2009 Explorer & Sport Trac V6 4x4 only with dealer-installed Neutral Tow Kit (Part #1L2Z-7H332-AB)
2009 Explorer & Sport Trac V8 4x4 only with dealer-installed Neutral Tow Kit (Part #6L2Z-7H332-A)
I also just acquired a copy of the installation instruction sheet for the 3L2Z-7H332-AA kit. PM me if you'd like a copy.
I hope this thread is still alive. I attempted to get the NTK from the local Ford dealer for our 2000 Limited V6 about 5 years ago. They ran the VIN number thru their system and said "sorry, does not apply to your car". So I gave up at that time. We continued to tow our 1996 XLT manual trans explorer behind the RV. Now the 96 has been a good vehicle but has over 300K miles and the end is in sight.
This thread has given us new hope that we might find a dealer that would be able to do the reprogramming. Maybe not our local dealer. Did I see a post from a Tennessee member that found a knowledgeable dealer?
Also would appreciate the list of the hardware parts needed for the kit.
Thanks, Mike
Yuba City, CA
I have them for the other two part numbers but not the 1L2Z-7H332-AB. If you locate a copy I'd appreciate it if you'd send me a copy.
Edit: Loren R sent me a copy of that so if you'd like it just PM me your email address or contact him at the info from one of his earlier posts.
I'm in the same boat. 2011 4x4 automatic. Good luck.Hi folks,
New here and I have a new to me 2010 Ford Ranger XLT 4x4 with automatic transmission. I, like others, want it as a toad but can't get what I need to put in a "Neutral Tow Kit" for for flat towing. I've searched several sites and this seems to be the best and most informed I have found.
My question is, Does anyone still have the instructions needed to in stall the old Ford part #3L2Z-7H332-AA? I'm sure I can find an LED light and hook it up but the reprograming is another issue. Any help I can get would be appreciated because if I can't get it done I've got to find something else for a toad and I really don't want to. I've owned 2 Explores, 2 Rangers, drove a city owned Ranger for my work truck, and now have this nice clean 2010 Ranger. Our other car is 2019 Explorer Sport, I like my Fords.
