#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Remove front driveshaft on AWD Mountaineer
Reply
Thread Tools
Old 10-04-2010, 11:14 AM   #1
cbrock
Athens, GA
05 Infiniti G35 Coupe 6MT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I believe I have a bad transfer case causing a thumping noise when in motion. Is it safe to completely remove the front drive shaft and only rely on RWD from here on out? Or at least until I can afford a new xfer case. One local shop tells me that removing the front shaft will throw an error code and screw up the transmission but that is contrary to what I've read on here. I don't need the AWD since I live in GA where it snows once every 5 years, and no way I'm getting on the roads with other nutjobs in those conditions!!
If it is safe to remove, how do I go about doing so? I wasn't able to find any instructions by searching.
Any help is greatly appreciated in advance!!
-Chris
__________________
2005 Infiniti G35 Coupe 6MT - Magnaflow exhaust, K&N CAI
RIP 2002 Mercury Mountaineer 4.0L AWD
RIP 1991 Ford Explorer 4.0L 4x4 5-speed
cbrock is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-06-2010, 01:45 PM   #2
Mussin
Lima,Ohio
'02 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
My t-case went out on my 02 mounty and I removed the front drive shaft to see if it was the T- case. I drove it like this for 2 weeks no problems here.
Mussin is offline   Reply With Quote
Old 10-08-2010, 10:48 PM   #3
mountaineer02
SLC, UTAH
2002 MONTAINEER
Vehicle Specs
Quoted: 0 Post(s)
Yah, I thought I had a bad viscous coupling so i disconeccted mine aswell, I didnt seem to have any problems. theres like 6 small bolts that connect it to the transfer case( i recomend a universal socket joint and some extention) and starbit or something to take off the universal joint on the front diff.
mountaineer02 is offline   Reply With Quote
Old 10-08-2010, 11:42 PM   #4
muhl5443
Minnesota
muhl5443's Avatar
'98 XLT
Vehicle Specs
Quoted: 0 Post(s)
there are about 6-8 8mm bolts on the transfer case end and you will need a t30 torx bit to disconnect the u joint from the front diff. there are four bolts there.
__________________
'98 xlt 4.0 sohc
31" bf goodrich all terrain t/a tires
2" TT
REAR SHACKLES
message center mod
vent visors & bug deflector
muhl5443 is offline   Reply With Quote
Old 10-10-2010, 10:09 PM   #5
stuartr
Richlands, VA
Vehicle Specs
Quoted: 1 Post(s)
But will this throw a code or kill the tranny? I bet it would help the MPG on mine.
STU
__________________
Mountianeer family I have a 2002 and she has a 2008. Both AWD V6.
stuartr is offline   Reply With Quote
Old 10-11-2010, 09:47 PM   #6
imp
Missouri Ozarks
2004 XLT
Vehicle Specs
Quoted: 115 Post(s)
Quote:
STU
Your transmission will not have a clue that the front shaft is missing. I drove my '04 with the front shaft OFF the vehicle for quite awhile, no trouble code generated, no problems.
But, it strikes me that IF you are experiencing some problem within the transfer case, how will front shaft removal change anything in it? Everything in the AWD design turns ALL the TIME, so unless the noise is originating AT, or FORWARD of, the viscous clutch powering the front shaft, it seems doubtful conditions will change with the shaft removed.
If you go ahead, the transfer case end MUST be disconnected first, according to Ford Shop Manual, to avoid damaging the seal boot within the coupling, which consists of a funky-looking C-V joint. The shaft is connected to it by 6 bolts which are loc-tited in place at the factory; I broke 2 sockets loosening them. The front end of the shaft needs a Torx key to remove the 4 screws fastening the straps which secure the standard-type U-joint there.
I hate those Torx jobbies, so replaced mine with Grade 8 Socket Head Cap Screws- they are 1/4-inch 28 thread bolts, good old standard non-metric! The transf. case end ARE metric, I forget the size, but I replaced them with SHCS screws also. imp
imp is offline   Reply With Quote
Old 10-13-2010, 02:00 PM   #7
cbrock
Athens, GA
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks for the clarification fellas. I'm going to try and undertake this over the weekend and hopefully I don't screw anything up hah.
Also, does anyone know if there is a (harmonic?) balancer attached to the front driveshaft somehow? Friend and I were pressing in new upper and lower ball joints last weekend and couldn't figure out what some of the components were up front :/
__________________
Old 10-13-2010, 02:03 PM   #8
billybob3358
Chuckey, Tennessee
2001 Mercury Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
i took minb e out had no prob except if u dont put ur emergency brake on it will roll away
billybob3358 is offline   Reply With Quote
Old 11-29-2010, 08:41 PM   #9
Infinity08
Charlestown, IN
'08 Sport Trac LTD
Vehicle Specs
Quoted: 0 Post(s)
Is the transfer case sealed still with the drive shaft removed?
__________________
2002 Mounty
4.6 AWD
stock
Infinity08 is offline   Reply With Quote
Old 12-02-2010, 12:08 PM   #10
Infinity08
Charlestown, IN
'08 Sport Trac LTD
Vehicle Specs
Quoted: 0 Post(s)
Will the transfer case leak fluid with the drive shaft out?
__________________
2002 Mounty
4.6 AWD
stock
Old 12-02-2010, 12:19 PM   #11
worshiprocker
Mesa, AZ
1997 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
I was driving with out a front drive shaft and didn't have any problems.. but mine is 4x4 not AWD
__________________
1997 Explorer 4x4 67,000 miles
bone stock..........for now
worshiprocker is offline   Reply With Quote
Old 12-02-2010, 02:00 PM   #12
rhyno
Potomac, MD
rhyno's Avatar
1997 EB
Vehicle Specs
Quoted: 0 Post(s)
It is still sealed after the shaft is removed, and no it will not leak. (unless you have other issues that would cause it to leak)
__________________
2002 Limited
1997 Eddie (SOLD)
rhyno is offline   Reply With Quote
Old 02-23-2014, 05:42 PM   #13
zimm814
altoona, pa
2002 mercury mountaineer
Vehicle Specs
Quoted: 0 Post(s)
Did you notice any 1st gear problems? I removed my front driveshaft and my 1st gear doesn't respond well wondering if it was normal? drives fine after 1st.
zimm814 is offline   Reply With Quote
Old 02-23-2014, 05:57 PM   #14
sulaco83
West Norriton, PA
1998 Eddie Bauer 5.0 AWD
Vehicle Specs
Quoted: 4 Post(s)
Your transmission should shift the same as it did with the front shaft installed. Mine was out when I bought the truck and shifted absolutely fine. Sounds like something else is wrong.... maybe VC is slipping?
sulaco83 is offline   Reply With Quote
Old 09-16-2014, 03:03 PM   #15
raveoli67
2002 mountaineer
Vehicle Specs
Quoted: 0 Post(s)
same issue
trying this weekend..
raveoli67 is offline   Reply With Quote
Old 10-30-2014, 10:15 PM   #16
cwol97401
Duck Country Oregon
1997 Merc Mounty 5.0L
Vehicle Specs
Quoted: 20 Post(s)
new question on an old thread, I damaged my front left axle splines at the hub, if I remove the front axle, will I be able to drive the truck normally on the street without the front left tire jumping the axle on takeoff? and someone said that it is necessary to set the parking brake if it is removed, is this correct? because my parking brake hasn't worked for a while now
__________________
Yes this is my truck.
Yes it can tow yours.
Can is a question of ability.
cwol97401 is offline   Reply With Quote
Old 10-31-2014, 10:17 AM   #17
pet575
Kansas City, MO
2004 Limited
Vehicle Specs
Quoted: 26 Post(s)
How would you "jump the axle" if it is missing? It should drive normally without the axle. If you are that worried about it, disconnect the front driveshaft.
The parking brake has nothing to do with it.
pet575 is offline   Reply With Quote
Old 11-02-2014, 07:14 PM   #18
cwol97401
Duck Country Oregon
Vehicle Specs
Quoted: 20 Post(s)
My wheel is currently jumping the axle at the hub. That is why I want to disconnect the front driveline. It started when the wrong size spare got put on it and drove for 12 miles
__________________
Old 01-29-2015, 03:52 PM   #19
PeteD
Long Island, NY
2006 Explorer 4.0 XLT 4x4
Vehicle Specs
Quoted: 2 Post(s)
Red face Worth disconnecting front drive shaft if hub/Bearing is about to fail?
cwol97401, I think I may have the same issue as you have (or hopefully had, I know the last posts to this thread are a few months old)
It seems my front hub(s) and possibly CV joints are bad, have been for about the last 3k making bearing, growling, humming sound under acceleration, and now an increasingly worse jumping sensation.
Odd thing is, once I get to 30 and I set the cruise control, it quiets down but isnt silent, however the awful clunking stops once cruise control is set.
I need to wait 1 week until I will be able to replace my hubs/CV Joints, but right now I am hearing sounds which are really worrying me about potential bearing failure being imminent. I only drive around town and less than 10miles per day as of lately, so I really dont want to break down and I am trying to figure out if there is anything I could do to decrease wear to my front driveline.
I see I would need t30 star bit for i believe 6 bolts to remove u joint from t case, I am trying to see if there is anything other than this that I could do to disable my front end from receiving power with just the basic tools I carry, preferably after work here in the parking lot I would like to attempt it- I heard about the "BWM" Brown wire mod, I dont want to do anything too drastic but I am wondering, does anyone know if there is a fuse I could pull, or some other way around removing those star bits that wouldnt take too long or be too difficult to accomplish, with temps out there in the teens? thanks
PeteD is offline   Reply With Quote
Old 01-29-2015, 03:56 PM   #20
PeteD
Long Island, NY
Vehicle Specs
Quoted: 2 Post(s)
Also, wanted to mention I did make a post describing more of the bearing/hub issues I have had and why I am feeling this is very serious- 6 months ago I actually had my rear wheel snap off at the axle due to a previous bearing failure. Post is somewhat lengthy but here it is:
http://www.explorerforum.com/forums/...92#post3382292
I greatly appreciate any imput
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
