Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Aerostar Tech Forum > Aerostar Forum
Notices
Aerostar Forum The Ford Aerostar shares a lot of common parts with the Ford Explorer. Besides that a lot of our members own an Aerostar and an Explorer.
How do I remove a bolt from the fan near the clutch?
Reply
Thread Tools
Old 10-08-2010, 11:17 AM   #1
csmoonchild
salisbury,n.c.
1993 aerostar van
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Question How do I remove a bolt from the fan near the clutch?
how to get bolt off of clutch fan on aerostars 1993 3.0
csmoonchild is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-08-2010, 11:40 AM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 414 Post(s)
Welcome to this forum! I've moved your post into its own thread with a new title. You need a box wrench or a ratchet set to remove the bolt. Are you replacing the plastic fan blades or the fan clutch?
BrooklynBay is offline   Reply With Quote
Old 10-09-2010, 09:46 PM   #3
FORDBOYpete
East Central Florida USA
95 Aerostar XLTN 4.0 RWD
Vehicle Specs
Quoted: 0 Post(s)
There are two ways to remove a fan clutch from your Aerostar water pump shaft. Either purchase a correct wrench for year & size you need, to do it correctly, or choose some alternative method that most likely will make you wish you bought a wrench in the first place.
Most Auto Parts Suppliers sell a Fan Clutch Hub Removal "tool", a slim, but durable open end wrench type affair which fits & works well if you get the correct size. I know there are different sizes and I know once I got the correct one for my 4.0L the job became a Breeze. After that nothing broke, I did not skin my knuckles, I did not "round off" the flats on the hex nut or anything any more.
WIth a tool you simply place it squarely on hex nut, lock or prevent your serpentine belt from rolling, then break the nut loose unthread it and remove your fan. Remember to support your fan & clutch so as to avoid damaging your radiator while removing the fan clutch assy.
You also can use the tool to retighten nut on reassembly. Hope this helps.
CIAO
FBp
__________________
"Everybody has to believe something, so I believe I'll have another beer" w.c. Fields early 20th Century
FORDBOYpete is offline   Reply With Quote
Old 10-09-2010, 10:45 PM   #4
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 414 Post(s)
This tool is specifically designed to work on the 3.0L engines to hold the pulley in place: http://www.explorerforum.com/reviewp...ct/376/cat/all
This tool set is used to turn the shaft connecting it together: http://www.explorerforum.com/reviewp...ct/372/cat/all
Old 10-10-2010, 11:12 AM   #5
FORDBOYpete
Vehicle Specs
Quoted: 0 Post(s)
YUP !
That's definitely the tool set that does the job the best & only way. . . . IMHO.
Thanx Brooklyn Bay, Great Illustration BTW
FBp
__________________
Old 10-10-2010, 01:40 PM   #6
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 414 Post(s)
By the way, the holding tool in the second illustration is used on the 4.0L pulley, and comes as part of that set. The 3.0L needs an offset tool such as the one in the first illustration.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
