Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
what make and year will interchange with 96 explorer 4.0 4x4
Reply
Thread Tools
Old 10-10-2010, 02:00 PM   #1
t5535
Arkansas
98 xlt
Vehicle Specs
(Original Poster)
what make and year will interchange with 96 explorer 4.0 4x4???
t5535 is offline   Reply With Quote
Old 10-10-2010, 02:04 PM   #2
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
You have a 4R55E transmission. They were used in the 95 & 96 Explorers, 96 Aerostar (4.0L models), and many Rangers with a 4.0L.
BrooklynBay is online now   Reply With Quote
Old 10-10-2010, 08:43 PM   #3
jamieD
Eastern NC
1996 Eddie Bauer
Vehicle Specs
So was a 4r44e ever in the 2wd 1996 model? My dealer tells me that the "T" transmission is a 4r44e in my 1996.?.?.?
jamieD is offline   Reply With Quote
Old 10-10-2010, 09:03 PM   #4
BrooklynBay
Brooklyn, NY
Vehicle Specs
The 4R44E was used on the Aerostar & Ranger with a 3.0L. The Explorer never came with a 3.0L.
Old 10-10-2010, 09:07 PM   #5
gmanpaint
Torsion Bar Free
since 2010
gmanpaint's Avatar
94 XLT-95 FX4
Vehicle Specs
You wont have the 4r44e in the Explorer. "T" is used for both 4r & 5r, and also the a4ld.
I just removed a 4R55E from a 95 4.0.
__________________
The Black Hole
Pugly
gmanpaint is offline   Reply With Quote
Old 10-11-2010, 02:20 PM   #6
jamieD
Eastern NC
1996 Eddie Bauer
Vehicle Specs
Can you look at one and visually tell then if it is a 4r55e or a 5r55e? Can I then safely assume that my 1996 with a "T" code is a 4r55e?
Old 10-11-2010, 06:16 PM   #7
gmanpaint
Torsion Bar Free
since 2010
gmanpaint's Avatar
94 XLT-95 FX4
Vehicle Specs
Not including reverse...
4R= 4 speed including Overdrive
5R= 5 speed including Overdrive
5R55E wasnt available until '97.
The electronics in a '96 will not support a 5R without some major modifications.
The number of solenoids are different. You can see them from the sides of the trans right above the trans pan.
4R55E pics
http://www.explorerforum.com/forums/...&postcount=300
__________________
The Black Hole
Pugly
Old 10-11-2010, 06:33 PM   #8
jamieD
Eastern NC
1996 Eddie Bauer
Vehicle Specs
Ok, so to further clear up the muddy water, will a 5r valve body work on the 4r? My dealer's parts man must really be ignorant of this stuff. I have been ordering 4r44e parts for my now 4r55e tranny. I have been wanting to replace the valve body on mine and have been asking all these vb questions based on the 4r44e. What does interchange?
Old 10-11-2010, 06:40 PM   #9
BrooklynBay
Brooklyn, NY
Vehicle Specs
The EPC & TCC solenoids are different as well as the range sensor. The 97 & 01 5R55E have extra sensors.
Old 10-11-2010, 06:48 PM   #10
jamieD
Eastern NC
1996 Eddie Bauer
Vehicle Specs
Thanks for clearing this up. So, I basically have a tranny that was in the explorer lineup for only 2 years? My 1954 Ford Tractor is the same, has a lift system made for only 2 years and then it got improved. I must be so lucky!
Old 04-14-2011, 01:37 AM   #11
darkemp
Detroit Michigan
93 Explorer 4.0
Vehicle Specs
Question, will the 4.0 1993 motor mate up to a 4r44e?
im trying to fix some guys ranger booboo, cant seem to get the starter to engage the flexplate. 1996 ranger with 93 explorer motor bolted up to a 4r44e.
he had a starter from a 2.3 in there and i took it out and swapped it for a 4.0 starter but had no luck with getting it to engage the flexplate. i think im going to try bolting a 2.3 flexplate up in there seeing how i replaced the flexplate with a 4.0 out of 1996 ranger 4.0.
so complicated, if anyone knows anything about it let me know
darkemp is offline   Reply With Quote
Old 04-14-2011, 08:29 AM   #12
PopRichie77
Quakertown, PA
1999 Explorer XLT 4X4
Vehicle Specs
I would say the 1996 flex plate is the problem, you need the flex plate and starter that went with the 4R44E, there maybe a starter torque problem, don't know.
PopRichie77 is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
