| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35 |
Thread Tools |
#1 |
Wannabe Elite Explorer
VA
'93 XLT 4x4
Rear Differential Fluid Change- 1st Generation Explorer
I am planning on replacing the rear differential fluid for a 1993 Ford Explorer 4WD. Since it is RWD most of the time, I am changing the fluid for my friend. To my horror she has informed me that it has never been changed (and the vehicle is at 185,000+ miles). I looked at the Haynes manual and it makes the procedure look simple. I have changed differential fluid before.
However, it appears where my fill plug is located is blocked by the fuel tank with the drive shaft blocking the middle of the differential. I can't even see the fill plug but it was getting dark. It is supposed to be on the driver's side of the differential and on the front facing the drive shaft. This is correct, yes? Even when I do manage to find it, how on earth do I get at it? There isn't enough clearance in there to do anything and if it is stuck, good luck getting a breaker bar in there. -Techniker |
#2 |
south jersey
'98 XLT x2
i have a 2nd gen but if i recall thats where it was on my friends 1st gen. it should just be a 3/8s ratchet that screws it off, use a 3/8s extension to get to it if you don't have enough clearance as well as putting it up on jack stands if you have to. and the plug shouldn't be on there that tight my rear fluid wasnt changed til 120k miles and it still came right off, hit it with some pb blaster if you have too i doubt a breaker bar should be needed.
__________________ 98' XLT, 4.0 SOHC, war shackles 2 in TT, 31" destination AT's,cherry bomb vortex, Aussie locker, Custom snorkel. Basketball pole front bumper. 98 XLT, 4.0 being parted out, pm me for parts>>>. My ex-build thread-http://www.explorerforum.com/forums/...d.php?t=311851 |
#3 | |
VA
'93 XLT 4x4
Quote:
-Techniker |
| Thread Tools | |
