#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Rear alignment question.
Reply
Thread Tools
Old 10-19-2010, 08:54 PM   #1
JOHN62
new york
2004 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Unhappy Rear alignment question.
I have a 2004 Ford Explorer XLT (my third Explorer)
The alignment guy said my rear wheels were out of alignment and wore my tires unevenly from the inside. He told me my only option was to get two new tires and come back for a 4 wheel alignment.
Can't I just reverse the tires and let them wear evenly (they still had a lot of tread left). What could happen if I let it go for a while.
JOHN62 is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-19-2010, 09:18 PM   #2
Glen4X4
Lewistown, Pa
2000 XLS
Vehicle Specs
Quoted: 3 Post(s)
Welcome To The Forum! I do not know too much about 3rd gens but I wouldn't think the rear would be too adjustable, are your struts/shocks bad on it? And yes you can reverse the tires IF they're not rotational and IF they are then you would need to swap the way they are on the rims, but keep in mind while cornering you will be putting pressure on the outside still which is unsafe. But for the best alignment new tires are a must.
__________________
96 Explorer XLT Gone
03 Silverado 1500 LS 4X4
00 Subaru Outback Limited SDN
Glen4X4 is offline   Reply With Quote
Old 10-19-2010, 09:26 PM   #3
NHarris
Gillette, Wyoming
04 Wrangler, 08 Ranger
Vehicle Specs
Quoted: 3 Post(s)
Welcome to the forum! Yes you can reverse the tires. Like Glen4X4 said about the corning is very true. The alignment and new tires are the best choice of the two options.
__________________
Nate H
2008 Ford Ranger FX4
2008 Ford Taurus Sport
NHarris is offline   Reply With Quote
Old 10-19-2010, 09:42 PM   #4
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Welcome to this forum! I've moved your thread into the stock 2002-2005 section.
BrooklynBay is offline   Reply With Quote
Old 10-19-2010, 11:02 PM   #5
waskly
Crooklyn NY!
Vehicle Specs
Quoted: 4 Post(s)
first thing first, jack up the rear tires, and check end play, are they lose falling off? the rear are tracking tires so they don't get edge wear.
see if you need something fixed in the rear, if everything is tight, you cant wiggle the wheel on the truck put tires on it, and then a 4 wheel alignment.
also those could of been front tires prior to a rotation and are shot. in any case, if you have 4x4 not 4x2 you need same 4 tires with about the same thread wear.
waskly is offline   Reply With Quote
Old 10-20-2010, 09:41 PM   #6
imp
Missouri Ozarks
2004 XLT
Vehicle Specs
Quoted: 115 Post(s)
Quote:
Originally Posted by Glen4X4 View Post
..... I do not know too much about 3rd gens but I wouldn't think the rear would be too adjustable, ........
FYI, 3rd. gen. independent suspension has ALL KINDS of places where adjustment, or lack of it, due to worn bushings, bent parts, etc., can cause tire problems not seen on solid-axle rear ends like in the "old days". imp
imp is offline   Reply With Quote
Old 10-21-2010, 08:16 PM   #7
Glen4X4
Lewistown, Pa
2000 XLS
Vehicle Specs
Quoted: 3 Post(s)
That's why I said I don't know much about it. Eitherway for the most accurate alignment new tires are a must so the the vehicle sits right.
__________________
Old 10-21-2010, 09:13 PM   #8
imp
Missouri Ozarks
2004 XLT
Vehicle Specs
Quoted: 115 Post(s)
Sorry, I didn't mean to sound sarcastic, but rather helpful. Agree, no point in doing alignment of suspension while sitting on "crooked" tires! imp
Old 10-22-2010, 12:14 AM   #9
muzzymaniac
Kent, NY
04 Explorer XLT 4.0L
Vehicle Specs
Quoted: 0 Post(s)
What exactly do the worn tires look like?
Here's some help
http://www.procarcare.com/includes/c...dtirewear.html
muzzymaniac is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
