Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
2003 Ford Explorer 4.0L engine. Timing chain replacement.
Reply
Thread Tools
Old 10-22-2010, 03:03 PM   #1
darspencer
Brusly, La.
2003 Ford Explorer XL
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I hope someone here can help me. I am changing the timing chains in this engine and i am about to lose it. I have been to the library, on the internet, bought the manual and i just don't get it. Does anyone have a step by step diagram that they will be willing to share with me. I would be so grateful for any help.:
darspencer is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-22-2010, 03:15 PM   #2
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
Sohc v6?
I assume that you have the SOHC V6 engine. Are you attempting to replace both cassettes and the primary chain? If so, have you removed the engine from the vehicle?
2000StreetRod is offline   Reply With Quote
Old 10-22-2010, 03:27 PM   #3
darspencer
Brusly, La.
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Yes...trying to time it without the special tools, I need to know the cam positions.
Old 10-22-2010, 04:27 PM   #4
2000StreetRod
Greenville, SC
Vehicle Specs
Quoted: 45 Post(s)
timing cam positions
CAUTION: If the camshafts or crankshaft are rotated with the chains out of time or disconnected then the pistons can interfere with open valves.
rotate crankshaft until #1 piston is at TDC
right camshaft should have timing slot below axis of camshaft and parallel to head surface that mates with valve cover
left camshaft should have camshaft "nub" for camshaft position sensor above axis of camshaft and timing slot below axis of camshaft and parallel to head surface that mates with valve cover
Old 10-22-2010, 05:02 PM   #5
darspencer
Brusly, La.
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
2003 Ford Explorer XL Timing Chain 4.0
Thank a lot man. i really appreciate it.
Old 10-24-2010, 09:31 PM   #6
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 411 Post(s)
Welcome to this forum! I've moved your thread into the stock 2002-2005 section.
BrooklynBay is offline   Reply With Quote
Old 09-08-2012, 08:13 PM   #7
jmcgarvie
summerville sc
2003 ford explorer sport
Vehicle Specs
Quoted: 0 Post(s)
dose it matter
ok i timed the same engine with the cams upside down from the way you describe but if you turn the engine over 360% it is the other way dose it matter when there is no distributor
jmcgarvie is offline   Reply With Quote
Old 10-25-2012, 10:10 PM   #8
mdumalaog
Vehicle Specs
Quoted: 0 Post(s)
the pic with the timing chain that is for the cylinders 4,5,6, correct? with the piston no. 1 at top dead center compression stroke?
mdumalaog is offline   Reply With Quote
Old 10-26-2012, 12:43 PM   #9
2000StreetRod
Greenville, SC
Vehicle Specs
Quoted: 45 Post(s)
left vs right
left (driver) side of engine are cylinders #4, 5 & 6.
right (passenger) side of engine are cylinders #1, 2 & 3.
left camshaft has the camshaft position sensor "nub"
Timing of both camshafts is with #1 piston at TDC on compression stroke.
Timing slot of camshafts (left & right) below axis of camshaft and parallel to head surface that mates with valve cover.
Reply
Tags
4.0 enging, repair and mantainence, timing chains
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
