Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
'97 AWD transfer case makes a banging noise.
Reply
Thread Tools
Old 10-22-2010, 04:08 PM   #1
thebings
Vehicle Specs
(Original Poster)
I have a '97 AWD explorer that has developed a loud banging noise coming from the front drive shaft or the transfer case. I removed the front shaft and the noise stopped (car is on lifts) however the shaft seems to be ok. The rubber boot is good and when I flex/rotate the joint, I don't feel any binding. Should I go ahead and replace the shaft or do you think the noise was coming from the transfer case. Like others have pointed out, the t-case is still turning even without the shaft attached, but it does not have any load on it. Appreciate any advise and help. Thanks
Don
thebings is offline   Reply With Quote
Old 10-22-2010, 04:25 PM   #2
swetrid
Reading Pa
2001 Eddie Bauer
Vehicle Specs
front driveshaft definitely
__________________
Resident Ford Tech for the last 17 years, 2001 Eddie Bauer 5.0L, Cherry Bomb Cat back, 2010 Ecoboost Flex
swetrid is offline   Reply With Quote
Old 10-23-2010, 09:31 AM   #3
thebings
Vehicle Specs
(Original Poster)
A web site that sells the drive shaft says it is important to check the transfer case before installing a new shaft because a bad transfer case will destroy the new shaft. How would I check the transfer case?
Don
Old 10-23-2010, 09:39 AM   #4
Joey P
On my 5th Explorer
Lakewood, CO
Joey P's Avatar
1999 Ford Explorer EB 5.0
Vehicle Specs
does it happen only on acceleration? I had the same problem that happened only under acceleration and when I removed the shaft, it looked good, I replaced it and it ultimately ended up being the transfer case. I replaced the transfer case with a used one and I was good to go. I suspected the chain inside the AWD case was stretched out or something. How many miles on your vehicle?
__________________
There are two types of people in this world:
1.Those who get lemons and make lemonade.
2.Those who get lemons and squirt the juice in their eyes.
Updated Mug shot 2/12/09
Joey P is offline   Reply With Quote
Old 10-23-2010, 01:42 PM   #5
thebings
Vehicle Specs
(Original Poster)
Thanks for the reply Lil Bo Peep. No mine makes the banging during steady speed, slowing down, or accelerating. It will be really bad and then stop for a mile or two then start again. Turning into a drive way seems to make it worse. I have found a company that makes a repair kit for the CV, Rock Auto sells it for $102. I think I will install this kit and see what happens. Here is a link to the kit.
http://www.rockauto.com/catalog/moreinfo.php?pk=2425736
Don
Old 10-23-2010, 09:40 PM   #6
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Welcome to this forum! I've moved your thread into the transmissions & transfer cases section.
BrooklynBay is offline   Reply With Quote
Old 10-24-2010, 09:07 AM   #7
Joey P
On my 5th Explorer
Lakewood, CO
Joey P's Avatar
Vehicle Specs
Hmm. Yours is a 5.0 or a 4.0? Rebuilding the front drive shaft won't hurt either way. I'd check out the rear drive shaft too. Can you "feel" the banging sound under your feet when it happens? Around the location of the transfer case area? That kit you posted should be fine. Mine was a '96 5.0 and it had a different front drive shaft. It was a double cardan joint and not a cv on the front drive shaft.
__________________
Old 10-24-2010, 09:26 AM   #8
thebings
Vehicle Specs
(Original Poster)
It is the 5.0 liter. The AWD with the CV joint was the only option with the V-8 in '97. With the vehicle on blocks and underneath, it sounded like and felt like it was coming from the front drive shaft. Using a stethscope, it was not over pronounced at the transfer case or the front differential. Yes I plan to change the universal joints on the front and rear axle. Thanks for your reply.
Old 10-25-2010, 12:13 PM   #9
ponch68
San Antonio
'97 Explorer XLT
Vehicle Specs
Hope its the driveshaft, but I had the same issues with banging while accelerating, regardless of speed. My turned out to be the transfer case.
ponch68 is offline   Reply With Quote
Old 10-25-2010, 04:27 PM   #10
thebings
Vehicle Specs
(Original Poster)
I took the CV joint apart today and found a cracked inner race and one ball with rough nicks. Still waiting for my CV repair kit, I will post again when I get it installed but will be next week sometime. Thanks for all your input.
Don
Old 11-02-2010, 09:53 PM   #11
thebings
Vehicle Specs
(Original Poster)
Installed new CV joint today and happy to say it fixed the problem. The CV kit was good quality and easy to install.
Old 11-02-2010, 10:03 PM   #12
fast99f350
New Jersey
97 explorer xlt
Vehicle Specs
i have a question. What is the brown wire mod for the control tract?
fast99f350 is offline   Reply With Quote
Old 11-02-2010, 11:57 PM   #13
BrooklynBay
Brooklyn, NY
Vehicle Specs
Thanks for the update! Did you replace all of the CV joints or just the one that was damaged?
Old 11-03-2010, 07:56 AM   #14
thebings
Vehicle Specs
(Original Poster)
This was the CV joint on the aft end of the front drive shaft. The fwd end has a universal joint which I replaced. So I only replaced the one CV joint.
Old 11-18-2010, 04:38 PM   #15
Explorer Junky
Grand Rapids, Mi
1997 XLT 4 dr 5.0
Vehicle Specs
Don
I tried to get to this link and all it does is show me a picture. Can you send me a better link that will let me see price and maybe order. Mine clunks when shifting into gear and maybe the clunking noise I hear when driving down bumpy gravel and dirt roads? Either way, its got 200,000 on it! My wheel hubs are original, could that be it also????
Explorer Junky is offline   Reply With Quote
Old 11-18-2010, 10:47 PM   #16
thebings
Vehicle Specs
(Original Poster)
Here is the url to the mfg page.
http://www.dormanproducts.com/p-34479-932-201.aspx
Don
Old 11-18-2010, 10:50 PM   #17
thebings
Vehicle Specs
(Original Poster)
Tried to post a link to Rockauto where I bought mine but having trouble. Just go to rockauto.com and search for MFG name Dorman and part number 932201
Don
Old 11-19-2010, 11:40 AM   #18
Explorer Junky
Grand Rapids, Mi
1997 XLT 4 dr 5.0
Vehicle Specs
Thanks fellas! I just might have to order it this weekend. I got under there and grabbed the shaft by hand and gave it a good strong twist and it clanks, and clanks when shifting into gear. Also, had my reluctant wife ride with me and ask if she heard it on her side or mine and she said drivers. So, hope this is it. Then if that doesn't do it, then its the hub next!
Old 11-30-2010, 08:11 PM   #19
Thomsoningreen
Troutman, NC
1997 Explorer XLT 4WD
Vehicle Specs
orange CV rebuild anyone know how to put this together?
I have the said kit above but not sure how it goes together. Are the parts pressed together to assemble?
Thomsoningreen is offline   Reply With Quote
Old 11-30-2010, 10:13 PM   #20
thebings
Vehicle Specs
(Original Poster)
The domed end cover is a snug fit but not a pressed fit, it's just the gasket that holds it tight. I don't remember for sure but I think I held the bearing assemby by hand then tapped the end of the shaft (the end with the universal joint) on a piece of wood which broke loose this cover. Once the cover is removed, then you can remove the snap ring and pull off the bearing assembly. When I put the unit back into the vehicle, I tightened the bolts a little at a time to pull it back together straight. Hope this helps
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
