| Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well. |
Thread Tools |
#1 |
Wannabe Elite Explorer
range
98 ranger will not shift from park while running
last nigh after work I attempted to shift from park & it wouldn't went to off & shifted to N re started & found I had no brake lights/ no wipers & no teurn signals/ all fuses check good / any advice
#2 |
Reading Pa
2001 Eddie Bauer
It could be brake light switch or broken wiring at the switch upon inspection.
__________________ Resident Ford Tech for the last 17 years, 2001 Eddie Bauer 5.0L, Cherry Bomb Cat back, 2010 Ecoboost Flex |
#3 |
Michigan
03 Ranger FX4 LII 5.0 S/C
Check for a loose/corroded/broken ground wire under the hood, driver side inner fender, about halfway back near the electrical distribution box.
__________________ Bob 2003 Ranger FX4 Level II, 5.0L V8, 4R70W, BW4406 T/C, Aussie Locker front, Torsen rear Torque Monsters, Magnaflow, duals; Explorer EATC, steering wheel controls, consoles Bilstein 7100 reservoir shocks, Cadillac/Mustang SVO rear discs, Duff traction bars CarDomain Ford owners' manuals ONLINE, then click on "Glovebox" |
#4 |
Ocean Shores, WA
1996 Ranger
It is your turn signal switch; easy enough to replace.
#5 |
brake interlock switch
hi had same issue its the brake interlock switch. The switch is connected to your brake pedal and booster. Easy fix. As a temporary emergency fix you can pull the fuse for it and it then will shift but you have no brake lights.
#6 |
Jackson, NJ
94 limited on 35's
Hey teds1:
1st.. welcome. 2nd... You're about 14 months late to the party. Check the date that he started the thread.
__________________ 94 limited: 4.0l, 5spd swap, 6" skyjacker lift, 35x14.5 thornturds, 4.56s. 5.0 swap started (94 cobra 5.0, zf 5spd, np205) 95 xlt: stockish (SOHC swap, 30,000miles and I blew up the 3rd 4r55e...now collecting parts for a Cummins swap.) Cummins 4BT swap thread Ranger bed trailer build |
#7 |
So.Calif.(San Fernando Valley)
'94 Ranger, '90 Bronco II
I think watkinskb is the one who really missed the party lol.
__________________ '90 Bronco II XLT 5" lift (Skyjacker jeep coils), locked D35 & 8.8", 5.13s, double T-case, 35x12.50s & cut fenders '94 Ranger XLT 6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s |
| Thread Tools | |
