Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Cost to replace shocks(maybe) at a dealership?
Reply
Thread Tools
Old 10-27-2010, 07:05 AM   #1
SeanEXP
NY
04 Explorer EB
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I believe my Explorer needs new shocks because every time I go over a bump I hear a squeak. I'm suspecting it could be shocks or something. I know ford is going to charge me an arm and leg today. But can I purchase the parts and have them fix it? Also does the part have to be Motorcraft? Or can it be other brands like Monroe, Rancho and etc? I don't want to give Ford a reason to void the warranty.
I like to do business with them since I am not that Mechanically when it comes to vehicle plus I don't have the space to work on the vehicle.
The squeak and be anything but when I hear a squeak, I usually think about suspension.... I was reading online and one said it could be the ball joints? Do they make noise when going over bumps if they are bad?....
I am looking up online about prices for this job and I see some for over $1,000....that has to be for shocks all the way around....$1,000 seems kinda high
After seeing these prices I hope it isn't the shocks...LOL
SeanEXP is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-27-2010, 07:32 AM   #2
jrford
Birmingham, MI
'10 Sport Trac
Vehicle Specs
Quoted: 2 Post(s)
first thing to check are the sway bar bushings. They will dry out and squeak, a trick to see if its them is to spray a lot of WD40 on the rubber bushings that mount to the frame. If the noise stops then you found the problem, (maybe). There has been discussion on what to do next, couple of options.
For Bad struts there are ways to tell: you can feel pavement cracks in the road? When you come to a hard stop does the hood bounce up/down a couple of times (worn) or just go down once and back up once (ok)? Are just some of the way to tell if they are shot.
With the '04 and maybe being over critical at 20k the ride was like poo; i could feel the 'Paint' let alone the cracks. I tried to get them replaced under warranty but no go, stealership wanted $850 for Motorcraft. Dealer will only use Motorcraft, you better off finding a local shop and if you have a good relationship they might let you bring Your parts, but don't hold your breath. Many post on struts. . .
Worn Ball joints, most obvious are cracked boots, any other tests it needs to be on a hoist.
Check the simple things first. . .
__________________
Jim
2010 Mercury Mountaineer Premier, V8 AWD, 35k
2010 Sport Trac Limited, V8 4WD, 80k
2004 EB Quad Buckets V8 AWD, 105k
jrford is offline   Reply With Quote
Old 10-27-2010, 07:39 AM   #3
SeanEXP
NY
04 Explorer EB
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thank you jrford, I will do this and let you know the outcome..thanks ago.
Old 10-27-2010, 08:43 AM   #4
rhyno
Potomac, MD
rhyno's Avatar
1997 EB
Vehicle Specs
Quoted: 0 Post(s)
Yep, same thing on my explorer. It tends to get worse as the weather starts to turn cooler. Grease those rubber bushings underneath the front end. That worked for me.
__________________
2002 Limited
1997 Eddie (SOLD)
rhyno is offline   Reply With Quote
Old 10-27-2010, 09:33 AM   #5
kylecolb
Oshkosh, WI
2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
I had a squeak in my front end and first thing I checked were the coil spring bushings and sway bar bushings. I knew it had to of been a bushing (was 99% sure it was) because when I drove in rain or through puddles the squeak would stop, once it got dry it came back on any little bump.
Sprayed almost a bottle of WD40 on the bushings and nothing worked. Took it to my mechanic and he dropped the sway bar because he said it was most likely the bushings there and covered them in marine grease. Still no help.
He took the sway bar bushings out and put new ones in and no more squeak.
Cost 70 for diagnosis in dropping the sway bar the first time and trying to grease them and put the bar back in. Then 28$ for the new bushings. Then 70$ for an hour of labor to drop the sway bar again and install the new bushings. Total was around 177$, Worth it to me for to get that awful sound gone.
__________________
Proud Explorer Owner Since May 2010
2002 Ford Explorer XLT 4.0 V6
Just began modifying the Explorer October 2010 and loving every minute of it!
kylecolb is offline   Reply With Quote
Old 10-27-2010, 04:58 PM   #6
jakedrew
wisconsin
04 xlt
Vehicle Specs
Quoted: 3 Post(s)
More then likely it is the sway bar bushings. The wd 40 will work for a little bit.
You dont need any room to work on the car- just lay under it .
Good luck and keep us updated.
jakedrew is offline   Reply With Quote
Old 10-28-2010, 12:06 AM   #7
zach84
Cecil County, MD
03 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
If you are going to replace the struts you could get the ranchero lift struts for around 800.00 for all four and they will give you some lift to
zach84 is offline   Reply With Quote
Old 04-09-2014, 05:20 PM   #8
HumorousHumerus
New Brunswick
2001 Ford Explorer ST
Vehicle Specs
Quoted: 0 Post(s)
A great thing to check is the middle cab mounts. I spray mine with green cap rust check and it fixes them immediately. You really have to drench them.
HumorousHumerus is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
